Toon Energy Readings on Domoticz
Mooseknuckle
Post by Mooseknuckle »
Yes I use cron. Sorry but this is the only way I know to get the info. There are commands to set the state but I don't know if there are commands to get the state from toon. Getting it from toon would make this a lot more dynamic.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
kurniawan77
Re: Toon Energy Readings on Domoticz
Post by kurniawan77 »
Mooseknuckle wrote:Hi,
Well there is a way but i simply don't have the know hows....
https://github.com/rvdm/toon/blob/master/Toon.py
i see request urls like "https://toonopafstand.eneco.nl/toonMobi ... eToonState" but u have to be logged in to it. And as we are already logged in through Domoticz..... but i get stuck over here
Would be a lot easier if this was implemented in Domticz @gizmocuz :)
zwaz
Post by zwaz »
is this al working without a subscription by Eneco? Can domoticz also change the temp. in the room and make a program for the whole week? This so i can buy one on marktplaats with an subscription by another supplieer.
Mooseknuckle
I could be wrong but I don't think it will work without eneco. At the moment Domoticz does not communicate with Toon directly but via Eneco because there is no api available for toon yet.
PD0SBH
Post by PD0SBH »
The bash script to check the temperature setpoint and activate a virtual switch done in LUA. This script also makes sure only 1 scene is active at a time.
-- script_time_toon_state.lua
-- Read the Toon Thermostat Setpoint Temperature and (de)activate 4 Dummy
-- switches in Domoticz to represent the current Active State.
-- Name of the switch with the temperature setpoint.
sThermostatSetPointName = 'Huiskamer Instelling'
-- Temperature SetPoints.
sTemperatureHome = '20.00'
sTemperatureComfort = '20.50'
sTemperatureAway = '15.00'
sTemperatureSleep = '16.00'
-- Names of the 4 switches.
-- Home, Away, Comfort, Sleep
sSceneHome = 'Toon Scene Thuis'
sSceneAway = 'Toon Scene Home'
sSceneComfort = 'Toon Scene Comfort'
sSceneSleep = 'Toon Scene Slapen'
-- Toon Thermostat SetPoint:
sThermostatSetPoint = otherdevices_svalues[sThermostatSetPointName]
--print("SetPoint: Temperature is " .. sThermostatSetPoint .. " ");
-- Toon Scene Home
if (sThermostatSetPoint == sTemperatureHome) then
        --print("SetPoint means scene Home");
        if (otherdevices[sSceneHome] == 'Off') then
                print("Setting Toon SceneHome On")
                commandArray[sSceneHome]='On'
        if (otherdevices[sSceneAway] == 'On') then
                print("Setting Toon SceneAway Off")
                commandArray[sSceneAway]='Off'
        if (otherdevices[sSceneComfort] == 'On') then
                print("Setting Toon SceneComfort Off")
                commandArray[sSceneComfort]='Off'
        if (otherdevices[sSceneSleep] == 'On') then
                print("Setting Toon SceneSleep Off")
                commandArray[sSceneSleep]='Off'
-- Toon Scene Comfort
elseif (sThermostatSetPoint == sTemperatureComfort) then
        --print("SetPoint means scene Comfort");
        if (otherdevices[sSceneComfort] == 'Off') then
                print("Setting Toon SceneComfort On")
                commandArray[sSceneComfort]='On'
        if (otherdevices[sSceneHome] == 'On') then
                print("Setting Toon SceneHome Off")
                commandArray[sSceneHome]='Off'
-- Toon Scene Away
elseif (sThermostatSetPoint == sTemperatureAway) then
        --print("SetPoint means Scene Away");
        if (otherdevices[sSceneAway] == 'Off') then
                print("Setting Toon SceneAway On")
                commandArray[sSceneAway]='On'
-- Toon Scene Sleep
elseif (sThermostatSetPoint == sTemperatureSleep) then
        --print("SetPoint means Scene Sleep");
        if (otherdevices[sSceneSleep] == 'Off') then
                print("Setting Toon SceneSleep On")
                commandArray[sSceneSleep]='On'
kurniawan77
How funny... i have made this ....(thanks to Mooseknuckle)
#!/bin/sh
# Configure settings as desired
# SETTINGS:
# Domoticz IP and Port
DOMO_IP="192.168.129.110"
DOMO_PORT="8080"
# Device idx in Domoticz
TOON_SETPOINT_IDX="6"
TOON_COMFORT_IDX="32"
TOON_HOME_IDX="33"
TOON_SLEEP_IDX="31"
TOON_AWAY_IDX="28"
TOON_OFF_IDX="37"
# Toon program setpoints
TOON_COMFORT_SP="21.0"
TOON_HOME_SP="20.5"
TOON_SLEEP_SP="19.0"
TOON_AWAY_SP="17.5"
TOON_OFF_SP="6.0"	# This is just an extra program/ switch in Domoticz
# End of Settings!
temp=`curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_SETPOINT_IDX" | grep -oP '(?<="SetPoint" : ").*(?=",)'`
if expr "$temp" '=' "$TOON_COMFORT_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_COMFORT_IDX" | grep "Status" | grep "On" > /dev/null
		if [ $? -eq 0 ] ; then
		echo "Comfort already ON"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_COMFORT_IDX&switchcmd=On"
			fi
elif expr "$temp" '!=' "$TOON_COMFORT_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_COMFORT_IDX" | grep "Status" | grep "Off" > /dev/null
		echo "Comfort already OFF"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_COMFORT_IDX&switchcmd=Off"
			fi
	fi
if expr "$temp" '=' "$TOON_HOME_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_HOME_IDX" | grep "Status" | grep "On" > /dev/null
		echo "Thuis already ON"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_HOME_IDX&switchcmd=On"
			fi
elif expr "$temp" '!=' "$TOON_HOME_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_HOME_IDX" | grep "Status" | grep "Off" > /dev/null
		echo "Thuis already OFF"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_HOME_IDX&switchcmd=Off"
			fi
	fi
if expr "$temp" '=' "$TOON_SLEEP_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_SLEEP_IDX" | grep "Status" | grep "On" > /dev/null
		echo "Slapen already ON"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_SLEEP_IDX&switchcmd=On"
			fi
elif expr "$temp" '!=' "$TOON_SLEEP_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_SLEEP_IDX" | grep "Status" | grep "Off" > /dev/null
		echo "Slapen already OFF"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_SLEEP_IDX&switchcmd=Off"
			fi
	fi
if expr "$temp" '=' "$TOON_AWAY_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_AWAY_IDX" | grep "Status" | grep "On" > /dev/null
		echo "Away already ON"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_AWAY_IDX&switchcmd=On"
			fi
elif expr "$temp" '!=' "$TOON_AWAY_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_AWAY_IDX" | grep "Status" | grep "Off" > /dev/null
		echo "Away already OFF"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_AWAY_IDX&switchcmd=Off"
			fi
	fi
if expr "$temp" '=' "$TOON_OFF_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_OFF_IDX" | grep "Status" | grep "On" > /dev/null
		echo "OFF already ON"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_OFF_IDX&switchcmd=On"
			fi
elif expr "$temp" '!=' "$TOON_OFF_SP"
then
	curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$TOON_OFF_IDX" | grep "Status" | grep "Off" > /dev/null
		echo "OFF already OFF"
		curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$TOON_OFF_IDX&switchcmd=Off"
			fi
fi
HansieNL
Post by HansieNL »
I wanna add Toon scene buttons to set the temperature. So I got few questions.
1. Where exactly to put the scripts?
2. What (virtual) hardware, switches and scenes do I have to setup?
Blah blah blah
jjnj
Post by jjnj »
I just made a couple of switches for home, away, sleeping and comfort. Those switches are also in use for Alarm etc. But when for example home is switched on a http command will trigger: json.htm?type=command&param=thermostatstate&idx=6&state=1
The state is the warming scene you want to set.
And because I don't know lua yet I just made a blockly: when home is switches, the other switches are switches off of another was on, so only one switch is active and you will know which one
HansieNL
Post by HansieNL »
What I have done so far...
1 Created dummy hardware
2 Created 4 virtual on/off switches (Thermostaat Comfort, Thuis, Slapen en Weg)
3 Set the on action http command to send when set the switch to on. (Maybe it's better to do that in blocky?)
When I set switch to on, the switch icon change from grey to color and the warming scene state is sent. So this part is working ok. :D
I like the other switches to be switched to off now.
I can't get this working in blocky. :cry:
@ jjnj Is it possible to send me a screenshot of your blocky event?
Blah blah blah
jjnj
Post by jjnj »
I cant right now, not on a pc. It's just the following, if thuis is on do: weg, slapen, comfort off. And just put the json command on the switch itself (at least I think this is easier)
HansieNL
Post by HansieNL »
Got it working. I did setup an event as you told me how to do and that works, but now I use the lua script from PD0SBH. The script also set the switch if setpoint is changed on Toon thermostat.
Thanks for helping.
Blah blah blah
kkc1983
Domoticz version: Stable
Post by kkc1983 »
Is it also possible to read out the city heating (Stadsverwarming)?
HansieNL
Post by HansieNL »
Because I'm new to Domoticz and just got my Hue lamps an Toon thermostat I got a question. Now I've setup 2 dummy hardware entries. Is that ok or should I delete one and create all virtual sensors from the same dummy hardware?
Blah blah blah
HansieNL
Post by HansieNL »
The picture is a screenshot of my hardware and Toon is added (Idx 6).I've added ToonSetpoints as dummy hardware, because want to have on/off switches for the setpoints.
My question is about the dummy hardware (idx 5 wdrechtemp and idx 7 toonsetpoints). Is just one dummy hardware entry ok and create all virtual sensors from there?
Blah blah blah
voorstad
Post by voorstad »
Has anyone looked into the ToonAPI already?
http://www.toonapi.com/
Is this of any use for Domoticz?
voorstad
Post by voorstad »
voorstad wrote:Has anyone looked into the ToonAPI already?
Too early. I now see there will be a ToonAPI launchparty on december 4:
https://www.eventbrite.com/e/launch-par ... 9332385686
kurniawan77
Anyone updated to 3.2.10 already?
rharmsen
Post by rharmsen »
I found some more information about the API here: https://api-tst.quby.nl/store/
Hope this will get better the 3th of december (they moved the launchparty)
AlwinHummels
Post by AlwinHummels »
PD0SBH wrote:The bash script to check the temperature setpoint and activate a virtual switch done in LUA. This script also makes sure only 1 scene is active at a time.
I try to get your script working but it fails or I do it wrong (I think the last)
Can you please tel me how to setup so it will work on my installation.
I've Domoticz 2.3674 on a Raspberry Pi
I put your script (copy past) on the scripts/lua folder
I made a dummy hardware and called that "Toon setpoints" ( what type do I have to set for virtual sensor)
After that i went to the switches tab and created some switches called: Toon Scene Thuis, Toon Scene Weg, Toon Scene Comfort, Toon Scene Slapen
Are those namings correct?
Did I miss something here. becouse the licht bulp goes on an off when I click on any switch I created but nothing happens I can put them all on or off but putting one one doesn't switch the others off.
Also my toon doesný react on this.
Please help
On my log I see:
2015-11-26 10:47:42.129 Error: ToonThermostat: Error getting current state!
what does that mean and how can I fix this?
2015-11-26 10:40:40.385 Domoticz V2.3691 (c)2012-2015 GizMoCuz
2015-11-26 10:40:40.387 Build Hash: 7d2e770, Date: 2015-11-25 19:34:13
2015-11-26 10:40:40.388 System: Raspberry Pi
2015-11-26 10:40:40.390 Startup Path: /home/pi/domoticz/
2015-11-26 10:40:40.912 Sunrise: 08:19:00 SunSet:16:37:00
2015-11-26 10:40:40.912 EventSystem: reset all events...
2015-11-26 10:40:41.010 Active notification subsystems: (0/10)
2015-11-26 10:40:41.092 Webserver started on port: 8080
2015-11-26 10:40:41.147 Webserver started on port: 443
2015-11-26 10:40:41.176 Started shared server on: 0.0.0.0
2015-11-26 10:40:42.356 Incoming connection from: 192.168.192.10
2015-11-26 10:40:43.201 ToonThermostat: Worker started...
2015-11-26 10:40:43.205 EventSystem: reset all events...
2015-11-26 10:40:43.207 EventSystem: reset all device statuses...
2015-11-26 10:40:43.232 EventSystem: Started
2015-11-26 10:41:09.858 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:41:09.864 (Toon) Temp (Room Temperature)
2015-11-26 10:41:40.298 (Toon) General/kWh (Slaapkamer-Pi)
2015-11-26 10:41:40.307 (Toon) General/kWh (Lamp woonkmr)
2015-11-26 10:41:40.321 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:41:40.325 (Toon) P1 Smart Meter (Gas)
2015-11-26 10:42:10.711 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:42:10.717 (Toon) Temp (Room Temperature)
2015-11-26 10:42:40.868 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:43:11.026 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:43:11.032 (Toon) Temp (Room Temperature)
2015-11-26 10:43:11.041 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:43:41.219 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:44:11.372 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:44:11.378 (Toon) Temp (Room Temperature)
2015-11-26 10:44:11.387 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:45:11.701 (Toon) General/kWh (Slaapkamer-Pi)
2015-11-26 10:45:11.709 (Toon) General/kWh (Lamp woonkmr)
2015-11-26 10:45:11.714 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:45:11.719 (Toon) Temp (Room Temperature)
2015-11-26 10:45:41.890 (Toon) General/kWh (Slaapkamer-Pi)
2015-11-26 10:45:41.899 (Toon) General/kWh (Lamp woonkmr)
2015-11-26 10:46:12.053 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:46:12.059 (Toon) Temp (Room Temperature)
2015-11-26 10:46:51.296 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:46:51.303 (Toon) Temp (Room Temperature)
2015-11-26 10:46:51.313 (Toon) P1 Smart Meter (Gas)
2015-11-26 10:48:13.494 (Toon) General/kWh (Slaapkamer-Pi)
2015-11-26 10:48:13.501 (Toon) General/kWh (Lamp woonkmr)
2015-11-26 10:48:13.506 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:48:13.512 (Toon) Temp (Room Temperature)
2015-11-26 10:48:43.681 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:49:13.873 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:49:13.879 (Toon) Temp (Room Temperature)
2015-11-26 10:50:14.182 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:50:14.188 (Toon) Temp (Room Temperature)
2015-11-26 10:50:51.358 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:50:51.364 (Toon) Temp (Room Temperature)
2015-11-26 10:51:51.696 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:51:51.705 (Toon) Temp (Room Temperature)
2015-11-26 10:51:51.713 (Toon) P1 Smart Meter (Energy)
2015-11-26 10:51:51.717 (Toon) P1 Smart Meter (Gas)
2015-11-26 10:52:52.020 (Toon) Thermostat (ToonThermostat)
2015-11-26 10:52:52.025 (Toon) Temp (Room Temperature)
2015-11-26 10:52:52.034 (Toon) P1 Smart Meter (Energy)
sj3fk3
Post by sj3fk3 »
http://www.toonapi.com/ is released to the public! I'm going to look into a node-red implementation, direct domoticz support would also be great of course :)
