Re: Math operators and Blocking
Posted: Sunday 12 November 2017 16:34
But actually you can't use user variables or devices....
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Thx?!Mesomorf wrote: Friday 10 November 2017 6:21Please! Can you PM me what files you moddified in Domoticz to get open up math? I tried myself and found some references in the www folder but without success.
<html>
<head>
<meta charset="utf-8">
<script type="text/javascript" src="js/blockly_compressed.js"></script>
<script type="text/javascript" src="js/blocks_compressed.js"></script>
<script type="text/javascript" src="js/en_compressed.js"></script>
<script type="text/javascript" src="js/jquery-1.12.0.min.js"></script>
<script src="js/bootstrap.min.js"></script>
<script src="js/bootbox.min.js"></script>
<script type="text/javascript" src="js/jquery-ui.min.js"></script>
<script type="text/javascript" src="js/noty/jquery.noty.js"></script>
<script type="text/javascript" src="js/noty/layouts/top.js"></script>
<script type="text/javascript" src="js/noty/layouts/topRight.js"></script>
<script type="text/javascript" src="js/noty/themes/default.js"></script>
<script type="text/javascript" charset="utf-8" src="js/domoticz.js"></script>
<script type="text/javascript" src="js/domoticzblocks_messages_en.js"></script>
<script type="text/javascript" src="js/domoticzblocks.js"></script>
<script src="js/i18next-1.8.0.min.js"></script>
<script type="text/javascript" src="js/bootbox.min.js"></script>
<script type="text/javascript" src="js/ace/ace.js"></script>
<script type="text/javascript" src="js/ace/ext-language_tools.js"></script>
<link rel="stylesheet" href="css/bootstrap.css">
<link href="css/bootstrap-responsive.css" rel="stylesheet" media="screen">
<link type="text/css" rel="stylesheet" href="css/ui-darkness/jquery-ui.min.css" />
<link type="text/css" rel="stylesheet" href="css/style.css" />
<style>
html, body {
background-color: transparent;
background: transparent;
margin: 0;
padding: 0;
overflow: hidden;
.blocklySvg {
height:100%;
width: 100%;
.blocklyTreeRow {
color:black;
#saveTable
{ border-spacing: 8px;
padding:2px 2px 2px 2px;
#aceDiv {
position: relative;
height: 700px;
</style>
<script>
var editor;
function init() {
Blockly.inject(document.getElementById('blocklyDiv'),
path: './',
toolbox: document.getElementById('toolbox'),
zoom: {
controls: true,
wheel: true,
startScale: 1.0,
maxScale: 3,
minScale: 0.3,
scaleSpeed: 1.2
trashcan: true
window.parent.blocklyLoaded(Blockly);
editor = ace.edit("aceDiv");
editor.setTheme("ace/theme/xcode");
editor.setOptions({enableBasicAutocompletion: true, enableSnippets: true, enableLiveAutocompletion: true});
load_blocks();
function opSymbol(operand) {
switch(operand)
case 'EQ':
operand = ' == ';
break;
case 'NEQ':
operand = ' ~= ';
break;
case 'LT':
operand = ' < ';
break;
case 'GT':
operand = ' > ';
break;
case 'LTE':
operand = ' <= ';
break;
case 'GTE':
operand = ' >= ';
break;
default:
return operand;
function parseXml(xml) {
if ($(xml).children().length > 1) {
return "err:Please make sure there is only a single block structure";
var firstBlockType = $(xml).find("block").first().attr("type");
if (firstBlockType.indexOf("domoticzcontrols_if") == -1) {
return "err:Please start with a control block";
var elseIfCount = 0;
if (firstBlockType == "domoticzcontrols_ifelseif")
var elseIfString = $(xml).find("mutation:first").attr("elseif");
elseIfCount = parseInt(elseIfString);
elseIfCount++;
var json = {};
json.eventlogic = []
for (var i=0;i<elseIfCount;i++)
conditionActionPair = parseXmlBlocks(xml,i);
var oneevent = {};
oneevent.conditions = conditionActionPair[0].toString();
oneevent.actions = conditionActionPair[1].toString();
json.eventlogic.push(oneevent);
return json;
function parseXmlBlocks(xml,pairId) {
var boolString = "";
function GetValueText(value, variableType) {
if (variableType.indexOf("switchvariables") >= 0) {
var fieldA = $(value).find("field")[0];
return "device["+$(fieldA).text()+"]";
else if (variableType.indexOf("uservariables") >= 0) {
return "variable["+$(fieldA).text()+"]";
else if (variableType == "temperaturevariables") {
return "temperaturedevice["+$(fieldA).text()+"]";
else if (variableType == "humidityvariables") {
return "humiditydevice["+$(fieldA).text()+"]";
else if (variableType == "dewpointvariables") {
return "dewpointdevice["+$(fieldA).text()+"]";
else if (variableType == "barometervariables") {
return "barometerdevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("utilityvariables") >= 0) {
return "utilitydevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("weathervariables") >= 0) {
return "weatherdevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("zwavealarms") >= 0) {
return "zwavealarms["+$(fieldA).text()+"]";
else {
var fieldB = $(value).find("field")[0];
if ($(fieldB).attr("name") == "State") {
return '"'+$(fieldB).text()+'"';
else if ($(fieldB).attr("name") == "TEXT") {
else if ($(fieldB).attr("name") == "NUM") {
return $(fieldB).text();
return "unknown comparevariable "+variableType;
function parseLogicCompare(thisBlock){
var locOperand = opSymbol($($(thisBlock).children("field:first")).text());
var valueA = $(thisBlock).children("value[name='A']")[0];
var variableTypeA = $(valueA).children("block:first").attr("type");
var valueB = $(thisBlock).children("value[name='B']")[0];
var variableTypeB = $(valueB).children("block:first").attr("type");
var varTextA=GetValueText(valueA,variableTypeA);
var varTextB=GetValueText(valueB,variableTypeB);
var compareString = varTextA;
compareString += locOperand;
compareString += varTextB;
return compareString;
function parseLogicTimeOfDay(thisBlock) {
var compareString = "";
var valueTime = $(thisBlock).children("value[name='Time']")[0];
var timeBlock = $(valueTime).children("block:first");
if (timeBlock.attr("type")=="logic_timevalue") {
var valueA = $(timeBlock).children("field[name='TEXT']")[0];
var hours=parseInt($(valueA).text().substr(0,2));
var minutes=parseInt($(valueA).text().substr(3,2));
var totalminutes=(hours*60)+minutes;
compareString = 'timeofday '+locOperand+' '+totalminutes;
else if (timeBlock.attr("type")=="logic_sunrisesunset") {
var valueA = $(timeBlock).children("field[name='SunriseSunset']")[0];
compareString = 'timeofday '+locOperand+' @'+$(valueA).text();
else if (timeBlock.attr("type").indexOf("uservariables") >= 0) {
var fieldA = $(timeBlock).find("field[name='Variable']")[0];
var valueA = "variable["+$(fieldA).text()+"]";
compareString = 'timeofday '+locOperand+' tonumber(string.sub('+valueA+',1,2))*60+tonumber(string.sub('+valueA+',4,5))';
function parseLogicWeekday(thisBlock) {
var valueA = $(thisBlock).children("field[name='Weekday']")[0];
var compareString = 'weekday '+locOperand+' '+$(valueA).text();
function parseSecurityStatus(thisBlock) {
var valueA = $(thisBlock).children("field[name='Status']")[0];
var compareString = 'securitystatus '+locOperand+' '+$(valueA).text();
function parseValueBlock(thisBlock,locOperand,Sequence) {
var firstBlock = $(thisBlock).children("block:first");
if (firstBlock.attr("type")=="logic_compare") {
var conditionstring = parseLogicCompare(firstBlock);
return conditionstring;
else if (firstBlock.attr("type")=="logic_weekday") {
var conditionstring = parseLogicWeekday(firstBlock);
else if (firstBlock.attr("type")=="logic_timeofday") {
var conditionstring = parseLogicTimeOfDay(firstBlock);
else if (firstBlock.attr("type")=="logic_operation") {
var conditionstring = parseLogicOperation(firstBlock);
else if (firstBlock.attr("type")=="security_status") {
var conditionstring = parseSecurityStatus(firstBlock);
function parseLogicOperation(thisBlock){
var locOperand = ' '+$($(thisBlock).children("field:first")).text().toLowerCase()+' ';
var conditionA = parseValueBlock(valueA,locOperand,"A");
var conditionB = parseValueBlock(valueB,locOperand,"B");
var conditionstring = "("+conditionA+" "+locOperand+" "+conditionB+")";
var ifBlock = $($(xml).find("value[name='IF"+pairId+"']")[0]).children('block:first');
if (ifBlock.attr("type")=="logic_compare") {
// just the one compare, easy
var compareString = parseLogicCompare(ifBlock);
boolString += compareString;
else if (ifBlock.attr("type")=="logic_operation") {
// nested logic operation, drill down
var compareString = parseLogicOperation(ifBlock);
else if (ifBlock.attr("type")=="logic_timeofday") {
var compareString = parseLogicTimeOfDay(ifBlock);
else if (ifBlock.attr("type")=="logic_weekday") {
var compareString = parseLogicWeekday(ifBlock);
else if (ifBlock.attr("type")=="security_status") {
var compareString = parseSecurityStatus(ifBlock);
var setArray = [];
var doBlock = $($(xml).find("statement[name='DO"+pairId+"']")[0]);
$(doBlock).find('block').each (function(){
if ($(this).attr('type') == 'logic_set') {
var valueA = $(this).find("value[name='A']")[0];
var fieldA = $(valueA).find("field")[0];
var blockA = $(valueA).children("block:first");
if (blockA.attr("type").indexOf("uservariables") >= 0) {
var setString = "commandArray[Variable:"+$(fieldA).text()+"]";
var valueB = $(this).find("value[name='B']")[0];
var fieldB = $(valueB).find("field")[0];
var blockB = $(valueB).children("block:first");
var dtext=GetValueText(valueB,variableTypeB);
setString += '='+dtext+'';
setArray.push(setString);
else {
var setString = "commandArray["+$(fieldA).text()+"]";
if ((blockB.attr("type")=="logic_states") && ($(fieldB).attr("name") == "State")) {
setString += '="'+$(fieldB).text()+'"';
else if ((blockB.attr("type")=="logic_setlevel") && ($(fieldB).attr("name") == "NUM")) {
setString += '="Set Level '+$(fieldB).text()+'"';
else {
//not handled
//alert('A Type: ' + blockA.attr("type") + ', B Type: ' + blockB.attr("type") + ', FieldB: ' + $(fieldB).attr("name"));
//else if ((blockB.attr("type")=="math_number") && ($(fieldB).attr("name") == "NUM")) {
// setString += '="'+$(fieldB).text()+'"';
// setArray.push(setString);
else if ($(this).attr('type') == 'logic_setafter') {
var valueC = $(this).find("value[name='C']")[0];
var fieldC = $(valueC).find("field")[0];
var blockBType=blockB.attr("type");
var fieldBName=$(fieldB).attr("name");
if ((blockBType=="logic_states") && (fieldBName == "State")) {
setString += '="'+$(fieldB).text()+' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="logic_setlevel") && (fieldBName == "NUM")) {
setString += '="Set Level '+$(fieldB).text()+' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="math_number") && (fieldBName == "NUM")) {
setString += '="'+$(fieldB).text()+'';
setString += ' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="text") && (fieldBName == "TEXT")) {
else if ($(this).attr('type') == 'logic_setdelayed') {
setString += '="'+$(fieldB).text()+' FOR '+ $(fieldC).text()+'"';
setString += '="Set Level '+$(fieldB).text()+' FOR '+ $(fieldC).text()+'"';
else if ($(this).attr('type') == 'logic_setrandom') {
setString += '="'+$(fieldB).text()+' RANDOM '+ $(fieldC).text()+'"';
setString += '="Set Level '+$(fieldB).text()+' RANDOM '+ $(fieldC).text()+'"';
else if ($(this).attr('type') == 'send_notification') {
var subjectBlock = $(this).find("value[name='notificationTextSubject']")[0];
var bodyBlock = $(this).find("value[name='notificationTextBody']")[0];
var notificationBlock = $(this).children("field[name='notificationPriority']")[0];
var soundBlock = $(this).children("field[name='notificationSound']")[0];
var subsystemBlock = $(this).children("field[name='notificationSubsystem']")[0];
var sFieldText = $(subjectBlock).find("field[name='TEXT']")[0];
var sTT=GetValueText(subjectBlock,$(subjectBlock).children("block:first").attr("type")).replace(/\,/g, ' ');
var bTT=GetValueText(bodyBlock,$(bodyBlock).children("block:first").attr("type")).replace(/\,/g, ' ');
var pTT=$(notificationBlock).text();
var aTT=$(soundBlock).text();
var subTT=$(subsystemBlock).text();
// message separator here cannot be # like in scripts, changed to $..
// also removed commas as we need to separate commandArray later.
var setString = 'commandArray["SendNotification"]="'+sTT+'$'+bTT+'$'+pTT+'$'+aTT+'$'+subTT+'"';
else if ($(this).attr('type') == 'send_email') {
var subjectBlock = $(this).children("field[name='TextSubject']")[0];
var bodyBlock = $(this).children("field[name='TextBody']")[0];
var toBlock = $(this).children("field[name='TextTo']")[0];
var sSubject = $(subjectBlock).text().replace(/\,/g, ' ');
var sBody = $(bodyBlock).text().replace(/\,/g, ' ');
var sTo = $(toBlock).text();
var setString = 'commandArray["SendEmail"]="'+sSubject+'$'+sBody+'$'+sTo+'"';
else if ($(this).attr('type') == 'send_sms') {
var setString = 'commandArray["SendSMS"]="'+sSubject+'"';
else if ($(this).attr('type') == 'start_script') {
var pathBlock = $(this).children("field[name='TextPath']")[0];
var sPath = $(pathBlock).text().replace(/\,/g, ' ');
var paramBlock = $(this).children("field[name='TextParam']")[0];
var sParam = $(paramBlock).text().replace(/\,/g, ' ');
var setString = 'commandArray["StartScript"]="'+sPath+'$'+sParam+'"';
else if ($(this).attr('type') == 'open_url') {
var urlBlock = $(this).find("value[name='urlToOpen']")[0];
var urlText = $(urlBlock).find("field[name='TEXT']")[0];
var setString = 'commandArray["OpenURL"]="'+$(urlText).text()+'"';
else if ($(this).attr('type') == 'writetolog') {
var logBlock = $(this).find("value[name='writeToLog']")[0];
var blockInfo = $(logBlock).children("block:first");
var setString = "";
if (blockInfo.attr("type")=="text") {
var logText = $(blockInfo).find("field[name='TEXT']")[0];
setString = 'commandArray["WriteToLogText"]="'+$(logText).text()+'"';
else if (blockInfo.attr("type").indexOf("uservariables") >= 0) {
var userVar = $(blockInfo).find("field[name='Variable']")[0];
setString = 'commandArray["WriteToLogUserVariable"]="'+$(userVar).text()+'"';
else if (blockInfo.attr("type").indexOf("switchvariables") >= 0) {
var switchVar = $(blockInfo).find("field")[0];
setString = 'commandArray["WriteToLogSwitch"]="'+$(switchVar).text()+'"';
else if (blockInfo.attr("type").indexOf("variables") >= 0) {
var deviceVar = $(blockInfo).find("field")[0];
setString = 'commandArray["WriteToLogDeviceVariable"]="'+$(deviceVar).text()+'"';
else if ($(this).attr('type') == 'groupvariables') {
var fieldA = $(this).find("field[name='Group']")[0];
var fieldB = $(this).find("field[name='Status']")[0];
var setString = "commandArray[Group:"+$(fieldA).text()+"]";
else if ($(this).attr('type') == 'scenevariables') {
var fieldA = $(this).find("field[name='Scene']")[0];
var setString = "commandArray[Scene:"+$(fieldA).text()+"]";
else if ($(this).attr('type') == 'cameravariables') {
var fieldA = $(this).find("field[name='Camera']")[0];
var fieldB = $(this).find("field[name='Subject']")[0];
var fieldC = $(this).find("field[name='NUM']")[0];
var setString = "commandArray[SendCamera:"+$(fieldA).text()+"]";
setString += '="'+ $(fieldB).text()+'" AFTER ' + $(fieldC).text().replace(/\,/g, ' ');
else if ($(this).attr('type') == 'setpointvariables') {
var fieldA = $(this).find("field[name='SetPoint']")[0];
var fieldB = $(this).find("field[name='NUM']")[0];
var setString = "commandArray[SetSetpoint:"+$(fieldA).text()+"]";
var conditionArray = [];
conditionArray.push(boolString);
return [conditionArray,setArray];
function loadSelectedEvent(id) {
$.ajax({
url: "json.htm?type=events¶m=load&event="+id,
async: false,
dataType: 'json',
success: function(data) {
if (typeof data.result != 'undefined') {
if (data.editortheme != 'undefined') {
editor.setTheme(data.editortheme);
if (data.status=="OK") {
$("#eventName").val(data.result[0].name);
$("#interpreter").val(data.result[0].interpreter).prop('disabled', true);
$("#eventType").val(data.result[0].type);
if (data.result[0].eventstatus == '1') {
$("#eventActive").prop('checked', true);
else {
$("#eventActive").prop('checked',false);
if (data.result[0].interpreter == 'Blockly') {
ResizeBlockyWindow();
var xmltemp = data.result[0].xmlstatement;
var xml = Blockly.Xml.textToDom(xmltemp);
Blockly.mainWorkspace.clear();
Blockly.Xml.domToWorkspace( Blockly.mainWorkspace, xml );
$("#blockId").html(id);
else {
if (data.result[0].interpreter == 'dzVents') {
editor.getSession().setMode("ace/mode/lua");
$("#eventType").val(data.result[0].type).prop('disabled', true);
else {
editor.getSession().setMode("ace/mode/" + data.result[0].interpreter.toLowerCase());
$("#eventType").val(data.result[0].type).prop('disabled', false);
editor.setValue("");
editor.setValue(data.result[0].xmlstatement);
editor.gotoLine(1);
editor.scrollToLine(1, true, true, function () {});
ResizeAceWindow();
$('#btnSave').attr("class", "btnstyle3");
$('#btnDelete').attr("class", "btnstyle3");
else { bootbox.alert("Error loading event!");}
function delete_block() {
var id = document.getElementById("savedEvents").value;
if ((id!=null)&&(id!="")) {
bootbox.confirm($.t("Are you sure to delete this Event?\n\nThis action can not be undone..."), function(result) {
if (result==true) {
$.ajax({
url: "json.htm?type=events¶m=delete&event="+id,
async: false,
dataType: 'json',
if (typeof data != 'undefined') {
generate_noty('alert', '<b>Event Deleted<br>'+$("#eventName").val(), 2000);
load_blocks();
$("#eventName").val("");
$("#interpreter").val("Blockly").prop('disabled', false);
$("#eventType").val("All");
else {
bootbox.alert("Nothing selected!")
function load_blocks() {
var select = document.getElementById("savedEvents");
select.options.length = 0;
var interpreters = document.getElementById("interpreter");
interpreters.options.length = 0;
$.ajax({
url: "json.htm?type=events¶m=list",
async: false,
dataType: 'json',
var aInterpreters = data.interpreters.split(':');
$.each(aInterpreters, function(i,item){
var option = document.createElement("option");
option.text = item;
interpreters.appendChild(option);
$.each(data.result, function(i,item){
option.text = item.name;
option.value = item.id;
option.style.color = 'red';
if (item.eventstatus == '1') {
option.style.color = 'black';
else if (item.eventstatus == '2') {
option.style.color = 'purple';
select.appendChild(option);
function new_block() {
var eventInterpreter = $("#interpreter").val().toLowerCase();
$("#blockId").html("");
$("#eventType").prop('disabled', false);
$("#savedEvents").val("");
$("#interpreter").prop('disabled', false);
$('#btnDelete').attr("class", "btnstyle3-dis");
if ($("#interpreter").val() == "Blockly") {
else {
if (eventInterpreter == "dzvents") {
eventInterpreter = "lua";
$("#eventType").prop('disabled', true);
editor.getSession().setMode("ace/mode/" + eventInterpreter);
$.ajax({
url: "json.htm?type=events¶m=new&interpreter="+$("#interpreter").val()+"&eventtype="+$("#eventType").val(),
async: false,
dataType: 'json',
if (typeof data.template != 'undefined') {
editor.setValue(data.template);
editor.gotoLine(1);
ResizeAceWindow();
function save_block() {
var eventName = $("#eventName").val();
var eventInterpreter = $("#interpreter").val();
var id = "";
if (eventName) {
var exists = false;
var doSave = false;
$('#savedEvents option').each(function(){
if (this.text == eventName) {
exists = true;
id=this.value;
if (exists) {
var answer = confirm("Overwrite "+eventName+"?")
if (answer){
doSave = true;
else{
doSave = false;
else {doSave = true;}
if (doSave) {
var logicArray;
var editorTheme = "";
var xml = Blockly.Xml.workspaceToDom( Blockly.mainWorkspace );
var blockXml = Blockly.Xml.domToText( xml );
logicArray = parseXml(xml);
if (typeof(logicArray)=='string') {
var answerparts = logicArray.split(':');
if (answerparts[0]=="err") {
bootbox.alert(answerparts[1]);
return;
else if (typeof(logicArray)=='object') {
logicArray = JSON.stringify(logicArray)
else {
logicArray = "";
editorTheme = "&editortheme="+encodeURIComponent(editor.getTheme());
blockXml = editor.getValue();
var isActive = 0;
if ($('#eventActive').is(':checked')) {isActive = 1};
$http({
method: 'POST',
url: 'event_create.webem',
headers: {
'Content-Type': 'multipart/form-data'
data: {
interpreter: encodeURIComponent($("#interpreter").val()),
eventtype: encodeURIComponent($("#eventType").val()),
xml: encodeURIComponent(blockXml),
logicarray: encodeURIComponent(logicArray),
eventid: id,
eventstatus: isActive+editorTheme
transformRequest: function (data, headersGetter) {
var formData = new FormData();
angular.forEach(data, function (value, key) {
formData.append(key, value);
var headers = headersGetter();
delete headers['Content-Type'];
return formData;
.success(function (data) {
alert(data);
generate_noty('information', '<b>Event saved:<br>'+eventName, 2000);
if (data.status=="ERR") {
generate_noty('warning', '<b>Error while saving:<br>'+eventName, 2000);
load_blocks();
var selIndex = 0;
$("#savedEvents").prop("selectedIndex",selIndex);
selIndex++;
selIndex = 0;
$('#interpreter option').each(function(){
if (this.text == eventInterpreter)
$("#interpreter").prop("selectedIndex",selIndex);
selIndex++;
.error(function (data, status) {
bootbox.alert("Save aborted!")
var pdata="name="+encodeURIComponent(eventName)+"&interpreter="+encodeURIComponent($("#interpreter").val())+"&eventtype="+encodeURIComponent($("#eventType").val())+"&xml="+encodeURIComponent(blockXml)+"&logicarray="+encodeURIComponent(logicArray)+"&eventid="+id+"&eventstatus="+isActive+editorTheme;
$.post("event_create.webem", pdata, function(data) {
load_blocks();
var selIndex = 0;
selIndex++;
selIndex = 0;
selIndex++;
$.ajax({
url : "json.htm?type=events¶m=create&name="+encodeURIComponent(eventName)+"&interpreter="+encodeURIComponent($("#interpreter").val())+"&eventtype="+encodeURIComponent($("#eventType").val())+"&xml="+encodeURIComponent(blockXml)+"&logicarray="+encodeURIComponent(logicArray)+"&eventid="+id+"&eventstatus="+isActive+editorTheme,
async: false,
dataType: 'json',
load_blocks();
var selIndex = 0;
selIndex++;
selIndex = 0;
selIndex++;
else {
else {
bootbox.alert('no event name entered!');
function show_states() {
$.ajax({
url : "json.htm?type=events¶m=currentstates",
async: false,
dataType: 'json',
var devicestates = "<div style='overflow:scroll; overflow-x: hidden; height: 400px;'><table><thead><tr><th align='left' style='padding-right: 80px;'>Idx</th><th align='left' style='padding-right: 80px;'>Name</th><th align='left' style='padding-right: 80px;'>Current state</th><th align='left' style='padding-right: 80px;'>Last updated</th><th align='left' style='padding-right: 10px;'>sValues</th></tr></thead><tbody>";
if (item.name != "Unknown") {
var oneitem = '<tr><td> '+item.id+' </td><td> '+item.name+' </td><td> '+item.value +' </td><td> '+item.lastupdate+' </td><td> '+item.svalues+'</td></tr>';
devicestates += oneitem;
devicestates += "</tbody></table></div>";
noty({
text: devicestates,
type: 'information',
modal: true,
buttons: [
{addClass: 'btn btn-primary', text: 'Ok', onClick: function($noty)
{$noty.close();
else {
bootbox.alert("Error getting current states, Is the Eventsystem Enabled?");
function block_export() {
function block_import() {
$(window).resize(function() {
if ($("#blocklyDiv").css("display") != "none") ResizeBlockyWindow();
if ($("#aceDiv").css("display") != "none") ResizeAceWindow();
function ResizeBlockyWindow()
if ($("#blocklyDiv").css("display") == "none") {
$("#aceDiv").css("display","none");
$("#blocklyDiv").css("display","");
$(".blocklyToolboxDiv").css("display","");
$("#blocklyDiv").css("width", $(window).width()-250);
$("#blocklyDiv").css("height", $(window).height()-20);
$("#savedEvents").css("height", $(window).height()-343);
function ResizeAceWindow()
if ($("#aceDiv").css("display") == "none") {
$("#blocklyDiv").css("display","none");
$(".blocklyToolboxDiv").css("display","none");
$("#aceDiv").css("display","");
$("#aceDiv").css("width", $(window).width()-250);
$("#aceDiv").css("height", $(window).height()-20);
function SetSaveButton()
($("#eventName").val() == '') ? $('#btnSave').attr('class', 'btnstyle3-dis') : $('#btnSave').attr('class', 'btnstyle3');
$(document).ready(function()
$.ajax({
url: "json.htm?type=command¶m=getlanguage",
async: false,
dataType: 'json',
if (typeof data.language != 'undefined') {
SetLanguage(data.language);
else {
SetLanguage('en');
error: function(){
</script>
</head>
<body onload="init()">
<xml id="toolbox" style="display: none">
<category name="Control">
<block type="domoticzcontrols_if"></block>
<block type="domoticzcontrols_ifelseif"></block>
</category>
<category name="Logic">
<block type="logic_compare"></block>
<block type="logic_operation"></block>
<!--<block type="logic_boolean"></block>-->
<block type="logic_states"></block>
<block type="logic_set"></block>
<block type="logic_setlevel"></block>
<block type="logic_setafter"></block>
<block type="logic_setdelayed"></block>
<block type="logic_setrandom"></block>
<block type="math_number"></block>
</category>
<category name="Loop">
<block type="controls_repeat_ext" id="PP1xWWodX6CKvEor(GH," x="88" y="38">
<value name="TIMES">
<shadow type="math_number" id="TYb81Ouygs*X/QdEF{3X">
<field name="NUM">10</field>
</shadow>
</value>
</block>
<block type="controls_whileUntil" id="1L(2$G7AU(]_Wz{Zp{4k" x="87" y="162">
<field name="MODE">WHILE</field>
</block>
<block type="controls_for" id="vN+!OA?Yeavhs`Md!}Lg" x="112" y="287">
<field name="VAR" id="0y$Gy/vso8ilq[q#q8;2" variabletype="">i</field>
<value name="FROM">
<shadow type="math_number" id="e:rn3b{;Ywi!Sfs00g7-">
<field name="NUM">1</field>
</shadow>
</value>
<value name="TO">
<shadow type="math_number" id="dDe#Gc3ZLs--t7pIJ/J7">
</shadow>
</value>
<value name="BY">
<shadow type="math_number" id="hu?8(8sHmHXo#_4VVcdP">
</shadow>
</value>
</block>
<block type="controls_forEach" id="+=m=;6*kSz+Yl3_}.%*3" x="137" y="412">
<field name="VAR" id="([JrHA^8_^!l~E*IhORs" variabletype="">j</field>
</block>
<block type="controls_flow_statements" id="##^tSSR`%R|h^=HV=+iQ" disabled="true" x="162" y="562">
<field name="FLOW">BREAK</field>
</block>
</category>
<category name="Math">
<field name="NUM">0</field>
</block>
<block type="math_arithmetic">
<field name="OP">ADD</field>
<value name="A">
<shadow type="math_number">
</shadow>
</value>
<value name="B">
</shadow>
</value>
</block>
<block type="math_single">
<field name="OP">ROOT</field>
<value name="NUM">
<field name="NUM">9</field>
</shadow>
</value>
</block>
<block type="math_trig">
<field name="OP">SIN</field>
<value name="NUM">
<field name="NUM">45</field>
</shadow>
</value>
</block>
<block type="math_constant">
<field name="CONSTANT">PI</field>
</block>
<block type="math_number_property">
<mutation divisor_input="false"></mutation>
<field name="PROPERTY">EVEN</field>
<value name="NUMBER_TO_CHECK">
</shadow>
</value>
</block>
<block type="math_round">
<field name="OP">ROUND</field>
<value name="NUM">
<field name="NUM">3.1</field>
</shadow>
</value>
</block>
<block type="math_on_list">
<mutation op="SUM"></mutation>
<field name="OP">SUM</field>
</block>
<block type="math_modulo">
<value name="DIVIDEND">
<field name="NUM">64</field>
</shadow>
</value>
<value name="DIVISOR">
</shadow>
</value>
</block>
<block type="math_constrain">
<value name="VALUE">
<field name="NUM">50</field>
</shadow>
</value>
<value name="LOW">
</shadow>
</value>
<value name="HIGH">
<field name="NUM">100</field>
</shadow>
</value>
</block>
<block type="math_random_int">
<value name="FROM">
</shadow>
</value>
<value name="TO">
</shadow>
</value>
</block>
<block type="math_random_float"></block>
</category>
<category name="Time">
<block type="logic_timeofday"></block>
<block type="logic_weekday"></block>
<block type="logic_timevalue"></block>
<block type="logic_sunrisesunset"></block>
</category>
<category name="Messages">
<block type="send_notification"></block>
<block type="send_email"></block>
<block type="send_sms"></block>
<block type="text"></block>
<block type="open_url"></block>
<block type="url_text"></block>
<block type="start_script"></block>
</category>
<category name="Security">
<block type="security_status"></block>
</category>
<category name="User variables">
<block type="uservariablesAF"></block>
<block type="uservariablesGL"></block>
<block type="uservariablesMR"></block>
<block type="uservariablesSZ"></block>
</category>
<category name="Debug/log">
<block type="writetolog"></block>
</category>
<category name="Devices">
<category name="Switches">
<block type="switchvariablesAF"></block>
<block type="switchvariablesGL"></block>
<block type="switchvariablesMR"></block>
<block type="switchvariablesSZ"></block>
</category>
<category name="Temperature">
<block type="temperaturevariables"></block>
</category>
<category name="Humidity">
<block type="humidityvariables"></block>
</category>
<category name="Dewpoint">
<block type="dewpointvariables"></block>
</category>
<category name="Barometer">
<block type="barometervariables"></block>
</category>
<category name="Weather">
<block type="weathervariables"></block>
</category>
<category name="Utility">
<block type="utilityvariables"></block>
<block type="utilityvariablesAF"></block>
<block type="utilityvariablesGL"></block>
<block type="utilityvariablesMR"></block>
<block type="utilityvariablesSZ"></block>
</category>
<category name="Scenes/groups">
<block type="scenevariables"></block>
<block type="groupvariables"></block>
</category>
<category name="Cameras">
<block type="cameravariables"></block>
</category>
<category name="SetPoints">
<block type="setpointvariables"></block>
</category>
<category name="ZWave Alarms">
<block type="zwavealarms"></block>
</category>
</category>
</xml>
<div id="maindiv" class="container-fluid">
<div class="row-fluid">
<table id="saveTable" border="0" cellpadding="0" cellspacing="0" width="100%">
<tr>
<td class=container" valign="top">
<menu type="context" id="acemenu">
<menu label="Editor Theme">
<menuitem label="Ambiance" type="radio" onclick="editor.setTheme('ace/theme/ambiance');"></menuitem>
<menuitem label="Chaos" type="radio" onclick="editor.setTheme('ace/theme/chaos');"></menuitem>
<menuitem label="Chrome" type="radio" onclick="editor.setTheme('ace/theme/chrome');"></menuitem>
<menuitem label="Cobalt" type="radio" onclick="editor.setTheme('ace/theme/cobalt');"></menuitem>
<menuitem label="Eclipse" type="radio" onclick="editor.setTheme('ace/theme/eclipse');"></menuitem>
<menuitem label="Merbivore" type="radio" onclick="editor.setTheme('ace/theme/merbivore');"></menuitem>
<menuitem label="Mono Industrial" type="radio" onclick="editor.setTheme('ace/theme/mono_industrial');"></menuitem>
<menuitem label="Monokai" type="radio" onclick="editor.setTheme('ace/theme/monokai');"></menuitem>
<menuitem label="Pastel on dark" type="radio" onclick="editor.setTheme('ace/theme/pastel_on_dark');"></menuitem>
<menuitem label="Terminal" type="radio" onclick="editor.setTheme('ace/theme/terminal');"></menuitem>
<menuitem label="Tomorrow" type="radio" onclick="editor.setTheme('ace/theme/tomorrow');"></menuitem>
<menuitem label="Vibrant_ink" type="radio" onclick="editor.setTheme('ace/theme/vibrant_ink');"></menuitem>
<menuitem label="XCode" type="radio" checked="checked" onclick="editor.setTheme('ace/theme/xcode');"></menuitem>
</menu>
<menuitem label="Auto Complete" type="checkbox" checked="true" onclick="editor.setOptions({enableLiveAutocompletion: this.getAttribute('checked')=='false'}); this.setAttribute('checked',this.getAttribute('checked')=='false');"></menuitem>
</menu>
<div id="aceDiv" class="ui-corner-all" style="display:none;" contextmenu="acemenu"></div>
<div id="blocklyDiv"></div>
</td>
<td style="width:250px" valign="top">
<label for="eventName">Event name:</label><br>
<input type="input" id="eventName" name="eventName" oninput="SetSaveButton();" onchange="SetSaveButton();" style="width: 12em; padding: .2em;" class="text ui-widget-content ui-corner-all" /><br>
<p>
<select name="interpreter" id="interpreter" class="ui-widget-content ui-corner-all" onchange="new_block();" style="width: 12em; padding: .2em; margin-top: 0.4em;">
<option selected="selected">Blockly</option>
<option>Lua</option>
<option>dzVents</option>
<option>Python</option>
</select>
<p>
<select name="eventType" id="eventType" class="ui-widget-content ui-corner-all" style="width: 12em; padding: .2em;">
<option selected="selected">All</option>
<option>Device</option>
<option>Security</option>
<option>Time</option>
<option>UserVariable</option>
</select>
<p>
<label for="eventActive">Event active:</label>
<input type="checkbox" id="eventActive" name="eventActive"/>
</p>
<p>
<a class="btnstyle3-dis" id="btnSave" href="javascript:save_block()">Save</a>
<a class="btnstyle3" href="javascript:new_block()">New</a>
</p>
<p>
<label for="savedEvents">Saved events:</label><br>
<select size="20" width="100%" style="width: 100%" id="savedEvents" name="savedEvents" onchange="loadSelectedEvent(this.value);"></select>
</p>
<p>
<a class="btnstyle3-dis" id="btnDelete" style="width: 80%" href="javascript:delete_block()">Delete selected</a></br>
<a class="btnstyle3" style="width: 80%; margin-top: 0.4em;" href="javascript:show_states()">Show current states</a>
</p>
<div id="blockId" style="display:none;"/>
</td>
</tr>
</table>
</div>
</div>
</body>
</html>
Tried the Math function. Made simple test to add a "1 + 1" value to variable, but it is not updating the variable. So no, it is not functional.
Attached file has been updatedWith loops, to be placed at /home/pi/domoticz/www/ in a file named eventsframe.html
