Math operators and Blocking
ebretteville
- Domoticz version: 2.3530
Re: Math operators and Blocking
But actually you can't use user variables or devices....
ebretteville
Thx?!Mesomorf wrote: Friday 10 November 2017 6:21Please! Can you PM me what files you moddified in Domoticz to get open up math? I tried myself and found some references in the www folder but without success.
ebretteville
With loops, to be placed at /home/pi/domoticz/www/ in a file named eventsframe.html
eventsframe.html
<html>
<head>
<meta charset="utf-8">
<script type="text/javascript" src="js/blockly_compressed.js"></script>
<script type="text/javascript" src="js/blocks_compressed.js"></script>
<script type="text/javascript" src="js/en_compressed.js"></script>
<script type="text/javascript" src="js/jquery-1.12.0.min.js"></script>
<script src="js/bootstrap.min.js"></script>
<script src="js/bootbox.min.js"></script>
<script type="text/javascript" src="js/jquery-ui.min.js"></script>
<script type="text/javascript" src="js/noty/jquery.noty.js"></script>
<script type="text/javascript" src="js/noty/layouts/top.js"></script>
<script type="text/javascript" src="js/noty/layouts/topRight.js"></script>
<script type="text/javascript" src="js/noty/themes/default.js"></script>
<script type="text/javascript" charset="utf-8" src="js/domoticz.js"></script>
<script type="text/javascript" src="js/domoticzblocks_messages_en.js"></script>
<script type="text/javascript" src="js/domoticzblocks.js"></script>
<script src="js/i18next-1.8.0.min.js"></script>
<script type="text/javascript" src="js/bootbox.min.js"></script>
<script type="text/javascript" src="js/ace/ace.js"></script>
<script type="text/javascript" src="js/ace/ext-language_tools.js"></script>
<link rel="stylesheet" href="css/bootstrap.css">
<link href="css/bootstrap-responsive.css" rel="stylesheet" media="screen">
<link type="text/css" rel="stylesheet" href="css/ui-darkness/jquery-ui.min.css" />
<link type="text/css" rel="stylesheet" href="css/style.css" />
<style>
html, body {
background-color: transparent;
background: transparent;
margin: 0;
padding: 0;
overflow: hidden;
.blocklySvg {
height:100%;
width: 100%;
.blocklyTreeRow {
color:black;
#saveTable
{ border-spacing: 8px;
padding:2px 2px 2px 2px;
#aceDiv {
position: relative;
height: 700px;
</style>
<script>
var editor;
function init() {
Blockly.inject(document.getElementById('blocklyDiv'),
path: './',
toolbox: document.getElementById('toolbox'),
zoom: {
controls: true,
wheel: true,
startScale: 1.0,
maxScale: 3,
minScale: 0.3,
scaleSpeed: 1.2
trashcan: true
window.parent.blocklyLoaded(Blockly);
editor = ace.edit("aceDiv");
editor.setTheme("ace/theme/xcode");
editor.setOptions({enableBasicAutocompletion: true, enableSnippets: true, enableLiveAutocompletion: true});
load_blocks();
function opSymbol(operand) {
switch(operand)
case 'EQ':
operand = ' == ';
break;
case 'NEQ':
operand = ' ~= ';
break;
case 'LT':
operand = ' < ';
break;
case 'GT':
operand = ' > ';
break;
case 'LTE':
operand = ' <= ';
break;
case 'GTE':
operand = ' >= ';
break;
default:
return operand;
function parseXml(xml) {
if ($(xml).children().length > 1) {
return "err:Please make sure there is only a single block structure";
var firstBlockType = $(xml).find("block").first().attr("type");
if (firstBlockType.indexOf("domoticzcontrols_if") == -1) {
return "err:Please start with a control block";
var elseIfCount = 0;
if (firstBlockType == "domoticzcontrols_ifelseif")
var elseIfString = $(xml).find("mutation:first").attr("elseif");
elseIfCount = parseInt(elseIfString);
elseIfCount++;
var json = {};
json.eventlogic = []
for (var i=0;i<elseIfCount;i++)
conditionActionPair = parseXmlBlocks(xml,i);
var oneevent = {};
oneevent.conditions = conditionActionPair[0].toString();
oneevent.actions = conditionActionPair[1].toString();
json.eventlogic.push(oneevent);
return json;
function parseXmlBlocks(xml,pairId) {
var boolString = "";
function GetValueText(value, variableType) {
if (variableType.indexOf("switchvariables") >= 0) {
var fieldA = $(value).find("field")[0];
return "device["+$(fieldA).text()+"]";
else if (variableType.indexOf("uservariables") >= 0) {
return "variable["+$(fieldA).text()+"]";
else if (variableType == "temperaturevariables") {
return "temperaturedevice["+$(fieldA).text()+"]";
else if (variableType == "humidityvariables") {
return "humiditydevice["+$(fieldA).text()+"]";
else if (variableType == "dewpointvariables") {
return "dewpointdevice["+$(fieldA).text()+"]";
else if (variableType == "barometervariables") {
return "barometerdevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("utilityvariables") >= 0) {
return "utilitydevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("weathervariables") >= 0) {
return "weatherdevice["+$(fieldA).text()+"]";
else if (variableType.indexOf("zwavealarms") >= 0) {
return "zwavealarms["+$(fieldA).text()+"]";
else {
var fieldB = $(value).find("field")[0];
if ($(fieldB).attr("name") == "State") {
return '"'+$(fieldB).text()+'"';
else if ($(fieldB).attr("name") == "TEXT") {
else if ($(fieldB).attr("name") == "NUM") {
return $(fieldB).text();
return "unknown comparevariable "+variableType;
function parseLogicCompare(thisBlock){
var locOperand = opSymbol($($(thisBlock).children("field:first")).text());
var valueA = $(thisBlock).children("value[name='A']")[0];
var variableTypeA = $(valueA).children("block:first").attr("type");
var valueB = $(thisBlock).children("value[name='B']")[0];
var variableTypeB = $(valueB).children("block:first").attr("type");
var varTextA=GetValueText(valueA,variableTypeA);
var varTextB=GetValueText(valueB,variableTypeB);
var compareString = varTextA;
compareString += locOperand;
compareString += varTextB;
return compareString;
function parseLogicTimeOfDay(thisBlock) {
var compareString = "";
var valueTime = $(thisBlock).children("value[name='Time']")[0];
var timeBlock = $(valueTime).children("block:first");
if (timeBlock.attr("type")=="logic_timevalue") {
var valueA = $(timeBlock).children("field[name='TEXT']")[0];
var hours=parseInt($(valueA).text().substr(0,2));
var minutes=parseInt($(valueA).text().substr(3,2));
var totalminutes=(hours*60)+minutes;
compareString = 'timeofday '+locOperand+' '+totalminutes;
else if (timeBlock.attr("type")=="logic_sunrisesunset") {
var valueA = $(timeBlock).children("field[name='SunriseSunset']")[0];
compareString = 'timeofday '+locOperand+' @'+$(valueA).text();
else if (timeBlock.attr("type").indexOf("uservariables") >= 0) {
var fieldA = $(timeBlock).find("field[name='Variable']")[0];
var valueA = "variable["+$(fieldA).text()+"]";
compareString = 'timeofday '+locOperand+' tonumber(string.sub('+valueA+',1,2))*60+tonumber(string.sub('+valueA+',4,5))';
function parseLogicWeekday(thisBlock) {
var valueA = $(thisBlock).children("field[name='Weekday']")[0];
var compareString = 'weekday '+locOperand+' '+$(valueA).text();
function parseSecurityStatus(thisBlock) {
var valueA = $(thisBlock).children("field[name='Status']")[0];
var compareString = 'securitystatus '+locOperand+' '+$(valueA).text();
function parseValueBlock(thisBlock,locOperand,Sequence) {
var firstBlock = $(thisBlock).children("block:first");
if (firstBlock.attr("type")=="logic_compare") {
var conditionstring = parseLogicCompare(firstBlock);
return conditionstring;
else if (firstBlock.attr("type")=="logic_weekday") {
var conditionstring = parseLogicWeekday(firstBlock);
else if (firstBlock.attr("type")=="logic_timeofday") {
var conditionstring = parseLogicTimeOfDay(firstBlock);
else if (firstBlock.attr("type")=="logic_operation") {
var conditionstring = parseLogicOperation(firstBlock);
else if (firstBlock.attr("type")=="security_status") {
var conditionstring = parseSecurityStatus(firstBlock);
function parseLogicOperation(thisBlock){
var locOperand = ' '+$($(thisBlock).children("field:first")).text().toLowerCase()+' ';
var conditionA = parseValueBlock(valueA,locOperand,"A");
var conditionB = parseValueBlock(valueB,locOperand,"B");
var conditionstring = "("+conditionA+" "+locOperand+" "+conditionB+")";
var ifBlock = $($(xml).find("value[name='IF"+pairId+"']")[0]).children('block:first');
if (ifBlock.attr("type")=="logic_compare") {
// just the one compare, easy
var compareString = parseLogicCompare(ifBlock);
boolString += compareString;
else if (ifBlock.attr("type")=="logic_operation") {
// nested logic operation, drill down
var compareString = parseLogicOperation(ifBlock);
else if (ifBlock.attr("type")=="logic_timeofday") {
var compareString = parseLogicTimeOfDay(ifBlock);
else if (ifBlock.attr("type")=="logic_weekday") {
var compareString = parseLogicWeekday(ifBlock);
else if (ifBlock.attr("type")=="security_status") {
var compareString = parseSecurityStatus(ifBlock);
var setArray = [];
var doBlock = $($(xml).find("statement[name='DO"+pairId+"']")[0]);
$(doBlock).find('block').each (function(){
if ($(this).attr('type') == 'logic_set') {
var valueA = $(this).find("value[name='A']")[0];
var fieldA = $(valueA).find("field")[0];
var blockA = $(valueA).children("block:first");
if (blockA.attr("type").indexOf("uservariables") >= 0) {
var setString = "commandArray[Variable:"+$(fieldA).text()+"]";
var valueB = $(this).find("value[name='B']")[0];
var fieldB = $(valueB).find("field")[0];
var blockB = $(valueB).children("block:first");
var dtext=GetValueText(valueB,variableTypeB);
setString += '='+dtext+'';
setArray.push(setString);
else {
var setString = "commandArray["+$(fieldA).text()+"]";
if ((blockB.attr("type")=="logic_states") && ($(fieldB).attr("name") == "State")) {
setString += '="'+$(fieldB).text()+'"';
else if ((blockB.attr("type")=="logic_setlevel") && ($(fieldB).attr("name") == "NUM")) {
setString += '="Set Level '+$(fieldB).text()+'"';
else {
//not handled
//alert('A Type: ' + blockA.attr("type") + ', B Type: ' + blockB.attr("type") + ', FieldB: ' + $(fieldB).attr("name"));
//else if ((blockB.attr("type")=="math_number") && ($(fieldB).attr("name") == "NUM")) {
// setString += '="'+$(fieldB).text()+'"';
// setArray.push(setString);
else if ($(this).attr('type') == 'logic_setafter') {
var valueC = $(this).find("value[name='C']")[0];
var fieldC = $(valueC).find("field")[0];
var blockBType=blockB.attr("type");
var fieldBName=$(fieldB).attr("name");
if ((blockBType=="logic_states") && (fieldBName == "State")) {
setString += '="'+$(fieldB).text()+' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="logic_setlevel") && (fieldBName == "NUM")) {
setString += '="Set Level '+$(fieldB).text()+' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="math_number") && (fieldBName == "NUM")) {
setString += '="'+$(fieldB).text()+'';
setString += ' AFTER '+ $(fieldC).text()+'"';
else if ((blockBType=="text") && (fieldBName == "TEXT")) {
else if ($(this).attr('type') == 'logic_setdelayed') {
setString += '="'+$(fieldB).text()+' FOR '+ $(fieldC).text()+'"';
setString += '="Set Level '+$(fieldB).text()+' FOR '+ $(fieldC).text()+'"';
else if ($(this).attr('type') == 'logic_setrandom') {
setString += '="'+$(fieldB).text()+' RANDOM '+ $(fieldC).text()+'"';
setString += '="Set Level '+$(fieldB).text()+' RANDOM '+ $(fieldC).text()+'"';
else if ($(this).attr('type') == 'send_notification') {
var subjectBlock = $(this).find("value[name='notificationTextSubject']")[0];
var bodyBlock = $(this).find("value[name='notificationTextBody']")[0];
var notificationBlock = $(this).children("field[name='notificationPriority']")[0];
var soundBlock = $(this).children("field[name='notificationSound']")[0];
var subsystemBlock = $(this).children("field[name='notificationSubsystem']")[0];
var sFieldText = $(subjectBlock).find("field[name='TEXT']")[0];
var sTT=GetValueText(subjectBlock,$(subjectBlock).children("block:first").attr("type")).replace(/\,/g, ' ');
var bTT=GetValueText(bodyBlock,$(bodyBlock).children("block:first").attr("type")).replace(/\,/g, ' ');
var pTT=$(notificationBlock).text();
var aTT=$(soundBlock).text();
var subTT=$(subsystemBlock).text();
// message separator here cannot be # like in scripts, changed to $..
// also removed commas as we need to separate commandArray later.
var setString = 'commandArray["SendNotification"]="'+sTT+'$'+bTT+'$'+pTT+'$'+aTT+'$'+subTT+'"';
else if ($(this).attr('type') == 'send_email') {
var subjectBlock = $(this).children("field[name='TextSubject']")[0];
var bodyBlock = $(this).children("field[name='TextBody']")[0];
var toBlock = $(this).children("field[name='TextTo']")[0];
var sSubject = $(subjectBlock).text().replace(/\,/g, ' ');
var sBody = $(bodyBlock).text().replace(/\,/g, ' ');
var sTo = $(toBlock).text();
var setString = 'commandArray["SendEmail"]="'+sSubject+'$'+sBody+'$'+sTo+'"';
else if ($(this).attr('type') == 'send_sms') {
var setString = 'commandArray["SendSMS"]="'+sSubject+'"';
else if ($(this).attr('type') == 'start_script') {
var pathBlock = $(this).children("field[name='TextPath']")[0];
var sPath = $(pathBlock).text().replace(/\,/g, ' ');
var paramBlock = $(this).children("field[name='TextParam']")[0];
var sParam = $(paramBlock).text().replace(/\,/g, ' ');
var setString = 'commandArray["StartScript"]="'+sPath+'$'+sParam+'"';
else if ($(this).attr('type') == 'open_url') {
var urlBlock = $(this).find("value[name='urlToOpen']")[0];
var urlText = $(urlBlock).find("field[name='TEXT']")[0];
var setString = 'commandArray["OpenURL"]="'+$(urlText).text()+'"';
else if ($(this).attr('type') == 'writetolog') {
var logBlock = $(this).find("value[name='writeToLog']")[0];
var blockInfo = $(logBlock).children("block:first");
var setString = "";
if (blockInfo.attr("type")=="text") {
var logText = $(blockInfo).find("field[name='TEXT']")[0];
setString = 'commandArray["WriteToLogText"]="'+$(logText).text()+'"';
else if (blockInfo.attr("type").indexOf("uservariables") >= 0) {
var userVar = $(blockInfo).find("field[name='Variable']")[0];
setString = 'commandArray["WriteToLogUserVariable"]="'+$(userVar).text()+'"';
else if (blockInfo.attr("type").indexOf("switchvariables") >= 0) {
var switchVar = $(blockInfo).find("field")[0];
setString = 'commandArray["WriteToLogSwitch"]="'+$(switchVar).text()+'"';
else if (blockInfo.attr("type").indexOf("variables") >= 0) {
var deviceVar = $(blockInfo).find("field")[0];
setString = 'commandArray["WriteToLogDeviceVariable"]="'+$(deviceVar).text()+'"';
else if ($(this).attr('type') == 'groupvariables') {
var fieldA = $(this).find("field[name='Group']")[0];
var fieldB = $(this).find("field[name='Status']")[0];
var setString = "commandArray[Group:"+$(fieldA).text()+"]";
else if ($(this).attr('type') == 'scenevariables') {
var fieldA = $(this).find("field[name='Scene']")[0];
var setString = "commandArray[Scene:"+$(fieldA).text()+"]";
else if ($(this).attr('type') == 'cameravariables') {
var fieldA = $(this).find("field[name='Camera']")[0];
var fieldB = $(this).find("field[name='Subject']")[0];
var fieldC = $(this).find("field[name='NUM']")[0];
var setString = "commandArray[SendCamera:"+$(fieldA).text()+"]";
setString += '="'+ $(fieldB).text()+'" AFTER ' + $(fieldC).text().replace(/\,/g, ' ');
else if ($(this).attr('type') == 'setpointvariables') {
var fieldA = $(this).find("field[name='SetPoint']")[0];
var fieldB = $(this).find("field[name='NUM']")[0];
var setString = "commandArray[SetSetpoint:"+$(fieldA).text()+"]";
var conditionArray = [];
conditionArray.push(boolString);
return [conditionArray,setArray];
function loadSelectedEvent(id) {
$.ajax({
url: "json.htm?type=events¶m=load&event="+id,
async: false,
dataType: 'json',
success: function(data) {
if (typeof data.result != 'undefined') {
if (data.editortheme != 'undefined') {
editor.setTheme(data.editortheme);
if (data.status=="OK") {
$("#eventName").val(data.result[0].name);
$("#interpreter").val(data.result[0].interpreter).prop('disabled', true);
$("#eventType").val(data.result[0].type);
if (data.result[0].eventstatus == '1') {
$("#eventActive").prop('checked', true);
else {
$("#eventActive").prop('checked',false);
if (data.result[0].interpreter == 'Blockly') {
ResizeBlockyWindow();
var xmltemp = data.result[0].xmlstatement;
var xml = Blockly.Xml.textToDom(xmltemp);
Blockly.mainWorkspace.clear();
Blockly.Xml.domToWorkspace( Blockly.mainWorkspace, xml );
$("#blockId").html(id);
else {
if (data.result[0].interpreter == 'dzVents') {
editor.getSession().setMode("ace/mode/lua");
$("#eventType").val(data.result[0].type).prop('disabled', true);
else {
editor.getSession().setMode("ace/mode/" + data.result[0].interpreter.toLowerCase());
$("#eventType").val(data.result[0].type).prop('disabled', false);
editor.setValue("");
editor.setValue(data.result[0].xmlstatement);
editor.gotoLine(1);
editor.scrollToLine(1, true, true, function () {});
ResizeAceWindow();
$('#btnSave').attr("class", "btnstyle3");
$('#btnDelete').attr("class", "btnstyle3");
else { bootbox.alert("Error loading event!");}
function delete_block() {
var id = document.getElementById("savedEvents").value;
if ((id!=null)&&(id!="")) {
bootbox.confirm($.t("Are you sure to delete this Event?\n\nThis action can not be undone..."), function(result) {
if (result==true) {
$.ajax({
url: "json.htm?type=events¶m=delete&event="+id,
async: false,
dataType: 'json',
if (typeof data != 'undefined') {
generate_noty('alert', '<b>Event Deleted<br>'+$("#eventName").val(), 2000);
load_blocks();
$("#eventName").val("");
$("#interpreter").val("Blockly").prop('disabled', false);
$("#eventType").val("All");
else {
bootbox.alert("Nothing selected!")
function load_blocks() {
var select = document.getElementById("savedEvents");
select.options.length = 0;
var interpreters = document.getElementById("interpreter");
interpreters.options.length = 0;
$.ajax({
url: "json.htm?type=events¶m=list",
async: false,
dataType: 'json',
var aInterpreters = data.interpreters.split(':');
$.each(aInterpreters, function(i,item){
var option = document.createElement("option");
option.text = item;
interpreters.appendChild(option);
$.each(data.result, function(i,item){
option.text = item.name;
option.value = item.id;
option.style.color = 'red';
if (item.eventstatus == '1') {
option.style.color = 'black';
else if (item.eventstatus == '2') {
option.style.color = 'purple';
select.appendChild(option);
function new_block() {
var eventInterpreter = $("#interpreter").val().toLowerCase();
$("#blockId").html("");
$("#eventType").prop('disabled', false);
$("#savedEvents").val("");
$("#interpreter").prop('disabled', false);
$('#btnDelete').attr("class", "btnstyle3-dis");
if ($("#interpreter").val() == "Blockly") {
else {
if (eventInterpreter == "dzvents") {
eventInterpreter = "lua";
$("#eventType").prop('disabled', true);
editor.getSession().setMode("ace/mode/" + eventInterpreter);
$.ajax({
url: "json.htm?type=events¶m=new&interpreter="+$("#interpreter").val()+"&eventtype="+$("#eventType").val(),
async: false,
dataType: 'json',
if (typeof data.template != 'undefined') {
editor.setValue(data.template);
editor.gotoLine(1);
ResizeAceWindow();
function save_block() {
var eventName = $("#eventName").val();
var eventInterpreter = $("#interpreter").val();
var id = "";
if (eventName) {
var exists = false;
var doSave = false;
$('#savedEvents option').each(function(){
if (this.text == eventName) {
exists = true;
id=this.value;
if (exists) {
var answer = confirm("Overwrite "+eventName+"?")
if (answer){
doSave = true;
else{
doSave = false;
else {doSave = true;}
if (doSave) {
var logicArray;
var editorTheme = "";
var xml = Blockly.Xml.workspaceToDom( Blockly.mainWorkspace );
var blockXml = Blockly.Xml.domToText( xml );
logicArray = parseXml(xml);
if (typeof(logicArray)=='string') {
var answerparts = logicArray.split(':');
if (answerparts[0]=="err") {
bootbox.alert(answerparts[1]);
return;
else if (typeof(logicArray)=='object') {
logicArray = JSON.stringify(logicArray)
else {
logicArray = "";
editorTheme = "&editortheme="+encodeURIComponent(editor.getTheme());
blockXml = editor.getValue();
var isActive = 0;
if ($('#eventActive').is(':checked')) {isActive = 1};
$http({
method: 'POST',
url: 'event_create.webem',
headers: {
'Content-Type': 'multipart/form-data'
data: {
interpreter: encodeURIComponent($("#interpreter").val()),
eventtype: encodeURIComponent($("#eventType").val()),
xml: encodeURIComponent(blockXml),
logicarray: encodeURIComponent(logicArray),
eventid: id,
eventstatus: isActive+editorTheme
transformRequest: function (data, headersGetter) {
var formData = new FormData();
angular.forEach(data, function (value, key) {
formData.append(key, value);
var headers = headersGetter();
delete headers['Content-Type'];
return formData;
.success(function (data) {
alert(data);
generate_noty('information', '<b>Event saved:<br>'+eventName, 2000);
if (data.status=="ERR") {
generate_noty('warning', '<b>Error while saving:<br>'+eventName, 2000);
load_blocks();
var selIndex = 0;
$("#savedEvents").prop("selectedIndex",selIndex);
selIndex++;
selIndex = 0;
$('#interpreter option').each(function(){
if (this.text == eventInterpreter)
$("#interpreter").prop("selectedIndex",selIndex);
selIndex++;
.error(function (data, status) {
bootbox.alert("Save aborted!")
var pdata="name="+encodeURIComponent(eventName)+"&interpreter="+encodeURIComponent($("#interpreter").val())+"&eventtype="+encodeURIComponent($("#eventType").val())+"&xml="+encodeURIComponent(blockXml)+"&logicarray="+encodeURIComponent(logicArray)+"&eventid="+id+"&eventstatus="+isActive+editorTheme;
$.post("event_create.webem", pdata, function(data) {
load_blocks();
var selIndex = 0;
selIndex++;
selIndex = 0;
selIndex++;
$.ajax({
url : "json.htm?type=events¶m=create&name="+encodeURIComponent(eventName)+"&interpreter="+encodeURIComponent($("#interpreter").val())+"&eventtype="+encodeURIComponent($("#eventType").val())+"&xml="+encodeURIComponent(blockXml)+"&logicarray="+encodeURIComponent(logicArray)+"&eventid="+id+"&eventstatus="+isActive+editorTheme,
async: false,
dataType: 'json',
load_blocks();
var selIndex = 0;
selIndex++;
selIndex = 0;
selIndex++;
else {
else {
bootbox.alert('no event name entered!');
function show_states() {
$.ajax({
url : "json.htm?type=events¶m=currentstates",
async: false,
dataType: 'json',
var devicestates = "<div style='overflow:scroll; overflow-x: hidden; height: 400px;'><table><thead><tr><th align='left' style='padding-right: 80px;'>Idx</th><th align='left' style='padding-right: 80px;'>Name</th><th align='left' style='padding-right: 80px;'>Current state</th><th align='left' style='padding-right: 80px;'>Last updated</th><th align='left' style='padding-right: 10px;'>sValues</th></tr></thead><tbody>";
if (item.name != "Unknown") {
var oneitem = '<tr><td> '+item.id+' </td><td> '+item.name+' </td><td> '+item.value +' </td><td> '+item.lastupdate+' </td><td> '+item.svalues+'</td></tr>';
devicestates += oneitem;
devicestates += "</tbody></table></div>";
noty({
text: devicestates,
type: 'information',
modal: true,
buttons: [
{addClass: 'btn btn-primary', text: 'Ok', onClick: function($noty)
{$noty.close();
else {
bootbox.alert("Error getting current states, Is the Eventsystem Enabled?");
function block_export() {
function block_import() {
$(window).resize(function() {
if ($("#blocklyDiv").css("display") != "none") ResizeBlockyWindow();
if ($("#aceDiv").css("display") != "none") ResizeAceWindow();
function ResizeBlockyWindow()
if ($("#blocklyDiv").css("display") == "none") {
$("#aceDiv").css("display","none");
$("#blocklyDiv").css("display","");
$(".blocklyToolboxDiv").css("display","");
$("#blocklyDiv").css("width", $(window).width()-250);
$("#blocklyDiv").css("height", $(window).height()-20);
$("#savedEvents").css("height", $(window).height()-343);
function ResizeAceWindow()
if ($("#aceDiv").css("display") == "none") {
$("#blocklyDiv").css("display","none");
$(".blocklyToolboxDiv").css("display","none");
$("#aceDiv").css("display","");
$("#aceDiv").css("width", $(window).width()-250);
$("#aceDiv").css("height", $(window).height()-20);
function SetSaveButton()
($("#eventName").val() == '') ? $('#btnSave').attr('class', 'btnstyle3-dis') : $('#btnSave').attr('class', 'btnstyle3');
$(document).ready(function()
$.ajax({
url: "json.htm?type=command¶m=getlanguage",
async: false,
dataType: 'json',
if (typeof data.language != 'undefined') {
SetLanguage(data.language);
else {
SetLanguage('en');
error: function(){
</script>
</head>
<body onload="init()">
<xml id="toolbox" style="display: none">
<category name="Control">
<block type="domoticzcontrols_if"></block>
<block type="domoticzcontrols_ifelseif"></block>
</category>
<category name="Logic">
<block type="logic_compare"></block>
<block type="logic_operation"></block>
<!--<block type="logic_boolean"></block>-->
<block type="logic_states"></block>
<block type="logic_set"></block>
<block type="logic_setlevel"></block>
<block type="logic_setafter"></block>
<block type="logic_setdelayed"></block>
<block type="logic_setrandom"></block>
<block type="math_number"></block>
</category>
<category name="Loop">
<block type="controls_repeat_ext" id="PP1xWWodX6CKvEor(GH," x="88" y="38">
<value name="TIMES">
<shadow type="math_number" id="TYb81Ouygs*X/QdEF{3X">
<field name="NUM">10</field>
</shadow>
</value>
</block>
<block type="controls_whileUntil" id="1L(2$G7AU(]_Wz{Zp{4k" x="87" y="162">
<field name="MODE">WHILE</field>
</block>
<block type="controls_for" id="vN+!OA?Yeavhs`Md!}Lg" x="112" y="287">
<field name="VAR" id="0y$Gy/vso8ilq[q#q8;2" variabletype="">i</field>
<value name="FROM">
<shadow type="math_number" id="e:rn3b{;Ywi!Sfs00g7-">
<field name="NUM">1</field>
</shadow>
</value>
<value name="TO">
<shadow type="math_number" id="dDe#Gc3ZLs--t7pIJ/J7">
</shadow>
</value>
<value name="BY">
<shadow type="math_number" id="hu?8(8sHmHXo#_4VVcdP">
</shadow>
</value>
</block>
<block type="controls_forEach" id="+=m=;6*kSz+Yl3_}.%*3" x="137" y="412">
<field name="VAR" id="([JrHA^8_^!l~E*IhORs" variabletype="">j</field>
</block>
<block type="controls_flow_statements" id="##^tSSR`%R|h^=HV=+iQ" disabled="true" x="162" y="562">
<field name="FLOW">BREAK</field>
</block>
</category>
<category name="Math">
<field name="NUM">0</field>
</block>
<block type="math_arithmetic">
<field name="OP">ADD</field>
<value name="A">
<shadow type="math_number">
</shadow>
</value>
<value name="B">
</shadow>
</value>
</block>
<block type="math_single">
<field name="OP">ROOT</field>
<value name="NUM">
<field name="NUM">9</field>
</shadow>
</value>
</block>
<block type="math_trig">
<field name="OP">SIN</field>
<value name="NUM">
<field name="NUM">45</field>
</shadow>
</value>
</block>
<block type="math_constant">
<field name="CONSTANT">PI</field>
</block>
<block type="math_number_property">
<mutation divisor_input="false"></mutation>
<field name="PROPERTY">EVEN</field>
<value name="NUMBER_TO_CHECK">
</shadow>
</value>
</block>
<block type="math_round">
<field name="OP">ROUND</field>
<value name="NUM">
<field name="NUM">3.1</field>
</shadow>
</value>
</block>
<block type="math_on_list">
<mutation op="SUM"></mutation>
<field name="OP">SUM</field>
</block>
<block type="math_modulo">
<value name="DIVIDEND">
<field name="NUM">64</field>
</shadow>
</value>
<value name="DIVISOR">
</shadow>
</value>
</block>
<block type="math_constrain">
<value name="VALUE">
<field name="NUM">50</field>
</shadow>
</value>
<value name="LOW">
</shadow>
</value>
<value name="HIGH">
<field name="NUM">100</field>
</shadow>
</value>
</block>
<block type="math_random_int">
<value name="FROM">
</shadow>
</value>
<value name="TO">
</shadow>
</value>
</block>
<block type="math_random_float"></block>
</category>
<category name="Time">
<block type="logic_timeofday"></block>
<block type="logic_weekday"></block>
<block type="logic_timevalue"></block>
<block type="logic_sunrisesunset"></block>
</category>
<category name="Messages">
<block type="send_notification"></block>
<block type="send_email"></block>
<block type="send_sms"></block>
<block type="text"></block>
<block type="open_url"></block>
<block type="url_text"></block>
<block type="start_script"></block>
</category>
<category name="Security">
<block type="security_status"></block>
</category>
<category name="User variables">
<block type="uservariablesAF"></block>
<block type="uservariablesGL"></block>
<block type="uservariablesMR"></block>
<block type="uservariablesSZ"></block>
</category>
<category name="Debug/log">
<block type="writetolog"></block>
</category>
<category name="Devices">
<category name="Switches">
<block type="switchvariablesAF"></block>
<block type="switchvariablesGL"></block>
<block type="switchvariablesMR"></block>
<block type="switchvariablesSZ"></block>
</category>
<category name="Temperature">
<block type="temperaturevariables"></block>
</category>
<category name="Humidity">
<block type="humidityvariables"></block>
</category>
<category name="Dewpoint">
<block type="dewpointvariables"></block>
</category>
<category name="Barometer">
<block type="barometervariables"></block>
</category>
<category name="Weather">
<block type="weathervariables"></block>
</category>
<category name="Utility">
<block type="utilityvariables"></block>
<block type="utilityvariablesAF"></block>
<block type="utilityvariablesGL"></block>
<block type="utilityvariablesMR"></block>
<block type="utilityvariablesSZ"></block>
</category>
<category name="Scenes/groups">
<block type="scenevariables"></block>
<block type="groupvariables"></block>
</category>
<category name="Cameras">
<block type="cameravariables"></block>
</category>
<category name="SetPoints">
<block type="setpointvariables"></block>
</category>
<category name="ZWave Alarms">
<block type="zwavealarms"></block>
</category>
</category>
</xml>
<div id="maindiv" class="container-fluid">
<div class="row-fluid">
<table id="saveTable" border="0" cellpadding="0" cellspacing="0" width="100%">
<tr>
<td class=container" valign="top">
<menu type="context" id="acemenu">
<menu label="Editor Theme">
<menuitem label="Ambiance" type="radio" onclick="editor.setTheme('ace/theme/ambiance');"></menuitem>
<menuitem label="Chaos" type="radio" onclick="editor.setTheme('ace/theme/chaos');"></menuitem>
<menuitem label="Chrome" type="radio" onclick="editor.setTheme('ace/theme/chrome');"></menuitem>
<menuitem label="Cobalt" type="radio" onclick="editor.setTheme('ace/theme/cobalt');"></menuitem>
<menuitem label="Eclipse" type="radio" onclick="editor.setTheme('ace/theme/eclipse');"></menuitem>
<menuitem label="Merbivore" type="radio" onclick="editor.setTheme('ace/theme/merbivore');"></menuitem>
<menuitem label="Mono Industrial" type="radio" onclick="editor.setTheme('ace/theme/mono_industrial');"></menuitem>
<menuitem label="Monokai" type="radio" onclick="editor.setTheme('ace/theme/monokai');"></menuitem>
<menuitem label="Pastel on dark" type="radio" onclick="editor.setTheme('ace/theme/pastel_on_dark');"></menuitem>
<menuitem label="Terminal" type="radio" onclick="editor.setTheme('ace/theme/terminal');"></menuitem>
<menuitem label="Tomorrow" type="radio" onclick="editor.setTheme('ace/theme/tomorrow');"></menuitem>
<menuitem label="Vibrant_ink" type="radio" onclick="editor.setTheme('ace/theme/vibrant_ink');"></menuitem>
<menuitem label="XCode" type="radio" checked="checked" onclick="editor.setTheme('ace/theme/xcode');"></menuitem>
</menu>
<menuitem label="Auto Complete" type="checkbox" checked="true" onclick="editor.setOptions({enableLiveAutocompletion: this.getAttribute('checked')=='false'}); this.setAttribute('checked',this.getAttribute('checked')=='false');"></menuitem>
</menu>
<div id="aceDiv" class="ui-corner-all" style="display:none;" contextmenu="acemenu"></div>
<div id="blocklyDiv"></div>
</td>
<td style="width:250px" valign="top">
<label for="eventName">Event name:</label><br>
<input type="input" id="eventName" name="eventName" oninput="SetSaveButton();" onchange="SetSaveButton();" style="width: 12em; padding: .2em;" class="text ui-widget-content ui-corner-all" /><br>
<p>
<select name="interpreter" id="interpreter" class="ui-widget-content ui-corner-all" onchange="new_block();" style="width: 12em; padding: .2em; margin-top: 0.4em;">
<option selected="selected">Blockly</option>
<option>Lua</option>
<option>dzVents</option>
<option>Python</option>
</select>
<p>
<select name="eventType" id="eventType" class="ui-widget-content ui-corner-all" style="width: 12em; padding: .2em;">
<option selected="selected">All</option>
<option>Device</option>
<option>Security</option>
<option>Time</option>
<option>UserVariable</option>
</select>
<p>
<label for="eventActive">Event active:</label>
<input type="checkbox" id="eventActive" name="eventActive"/>
</p>
<p>
<a class="btnstyle3-dis" id="btnSave" href="javascript:save_block()">Save</a>
<a class="btnstyle3" href="javascript:new_block()">New</a>
</p>
<p>
<label for="savedEvents">Saved events:</label><br>
<select size="20" width="100%" style="width: 100%" id="savedEvents" name="savedEvents" onchange="loadSelectedEvent(this.value);"></select>
</p>
<p>
<a class="btnstyle3-dis" id="btnDelete" style="width: 80%" href="javascript:delete_block()">Delete selected</a></br>
<a class="btnstyle3" style="width: 80%; margin-top: 0.4em;" href="javascript:show_states()">Show current states</a>
</p>
<div id="blockId" style="display:none;"/>
</td>
</tr>
</table>
</div>
</div>
</body>
</html>
eventsframe.html
pvm
- Domoticz version: 4.10538
Are these fuctional?
Can upgrading the complete blockly code also fix the 'else' issue (not really functioning as and else statement)
Tried the Math function. Made simple test to add a "1 + 1" value to variable, but it is not updating the variable. So no, it is not functional.
wuschels
- Domoticz version: stable
ebretteville you are my sunshine !
That is exactly what i am looking for a long time.
i've tried to implement the original google code, but i was not succesful.
in January i will try it with your file.
is there somthing else to do....?
1x Pi1 (PiHole)
4x Pi3 ( Nextcloud, Domoticz, Kodi, MagicMirror)
1x AMD Quad-core, 32Gbyte RAM (SuSE-Linux, Vmware....)
ebretteville
Don't know, blockly is from my point of view no really well documented. I can't find a complete list of available blocks. Also tried to do an avarage with some sensors values but it says average of list so it's ok for what i want to do but I can't find the list block. Also for @Mesomorf maybe you have to use the write to log block and write to the idx the result of the operation.
wuschels
Blockly ist documented at: https://developers.google.com/blockly/
There is a Online-Guide where you can test your blockly-scripts.
It is also possible to make your own blocks, but it is not so easy....
I managed to implement "Loops", "Math" and "Variables" into domoticz.
It seems to work, but i do have problems with "variables". It seem that blockly-variables are not compatible with domitcz-user-variables..
1x Pi1 (PiHole)
Xztraz
In the long run a full blockly->lua editor would be awesome. Start with blockly and if more advanced stuff is needed. Just switch the code to lua and continue there. Great way to learn coding.
JoergZ
- Domoticz version: V3.8153
I downloaded toolbox.xml and eventsframe.html to /home/pi/domoticz/www/ and restartet domoticz. But nothing changed. There is no Math library or something else new block at the blockly editor. What have I to do, to use math?
ebretteville
viewtopic.php?p=175156&sid=826759ff4357 ... 8a#p160576
Attached file has been updatedWith loops, to be placed at /home/pi/domoticz/www/ in a file named eventsframe.html
JoergZ
Please, no repetitions, use some other descriptive words. I don't understand. A loop is a programming element. But what is the context to the path of the files toolbox.xml and eventsframe.html.
ebretteville
Forget toolbox.xml and place eventsframe in the location described in my last message. That will do the trick
Sent from my MI MAX using Tapatalk
salopette
- Domoticz version: BETA
Hello, where does the file have to be changed that I get the math?
The file is also no longer found?
Thank you
Thank you
ebretteville
Read my previous message and get the file in my first post that I updated
Does ebrettvilles toolbox.eml and eventsframe.htm. work for everybody?
I have tried it but with no effect. The linked html file has gone from the location. Please update it.
Is there another location for math in blockly for domoticz?
Possibly one with better documentation about installation and usage?
Thank you all.
Thank you all.
Can someone post the lastest eventsframe.html?
Thank you soo much!
Andy
Thank you soo much!
Andy
ebretteville
Will do it later, I'm in the train
salopette
Hello ebretteville, is there an update ???
ebretteville
I found this on my hard drive, don't know if it's the last version. Sorry. I also noticed that the events module has been updated recently. At least in the latest beta version. So use it at your own risk and backup the previous file before.
Rename it with an html ext
