Page 2 of 2
Re: IM200/IM210 Imaginitronix Temprature Sensor
Posted: Monday 12 January 2015 16:07
by b_weijenberg
Maybe better to select one of the supported sensors.
Cheap sensors are not always the best, see for example the WS1200 which does not have a checksum and reports sometimes incorrect values.
Other criteria: transmit range, battery life, accuracy, availability
Posted: Monday 12 January 2015 16:15
by Eloque
I know
Wasn't quite looking for the best sensor, more for the cheap ones. I am going to use the
http://www.homewizard.nl/smartwares-dra ... kraan.html parts to set the temp and was wanting to use the cheap sensors to get some averages.
Any, relatively, cheap sensor you recommend?
Posted: Monday 12 January 2015 16:20
by b_weijenberg
Posted: Monday 12 January 2015 17:32
by Eloque
Alas, sold out.
They are for home use, so small and hid able would be nice.
Posted: Monday 26 January 2015 10:06
by ThinkPad
Have you made any progress on this?
I found this:
http://domoticz.com/forum/viewtopic.php ... nix#p31474
And this:
http://sourceforge.net/p/domoticz/code/ ... paign=Code
So it seems there is some support for Imagintronix. But i don't know for which device(s).
Posted: Monday 26 January 2015 11:32
by b_weijenberg
The supported Imagintronix (Opus XT300) sensor is the soil moisture sensor.
http://www.plantcaretools.com/en/websho ... -en-detail
Posted: Wednesday 28 January 2015 15:42
by Eloque
Unfortunatly, it was not a succes. I know to little of these thing to figure out the protocol. They are gathering dust now.
Posted: Wednesday 04 February 2015 20:32
by roblom
The 433mHz transmitter has a written
http://www.hh.com SL-TX583 text on it. It seems that the
pilight does support it. The have reverse engineered the code, so maybe RFXcom has to put less effort in it to add it to the RFXtrxCOM.
Posted: Wednesday 04 February 2015 22:04
by Eloque
We can hope. But the RFX developer told me he is quite busy atm.
Posted: Wednesday 04 February 2015 22:13
by roblom
The payside of succes
Posted: Saturday 14 November 2015 17:06
by Eloque
It's been a while, and I just found the set of sensors in the bottom of a box again. Anyone have any luck with these? Since they seem to be the standard kind that I can get on the various Chinese sites, it seems that have become more common.
Didn't work out of the box with the 248 FirmWare for me though.
Posted: Friday 05 February 2016 15:10
by AxelvanH
I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
Posted: Friday 05 February 2016 21:15
by AxelvanH
AxelvanH wrote:I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
I found the right protocol. Its: TH13 - Alecto WS1700 and compatibles
Just enable Rubicon/Alecto/Banggood
Posted: Monday 24 October 2016 19:57
by simon_rb
Anyone get these to work? I have one, enabled all protocols in the end with no success.
