Rik60 wrote: Friday 14 August 2026 19:39
Finally succeded to switch to stable9 9.1.002 from stable8 8.1.008. This is what i did:
- From the ui (user interface) updated the plugin
Then from the comman line:
switch to the plugin directory: cd domoticz/plugins/Domoticz-Zigbee
- set owner to pi: sudo chown -R pi:pi .
- go to the tools directory: cd Tools
- from command line executed: bash plugin-switch-stable9.sh --i-understand
This fails now, had to stash: git stash
again: - from command line executed: bash plugin-switch-stable9.sh --i-understand
Ok, switched the stable9 without errors
switched to the ui and updated the plugin -> updated stable9 without errors
Restarted the plugin in the ui
In the domoticz log errors: something to do with domoticz and domoticzex framework, both running on the same time
Rebooted the Rpi
No errors in the log
No Zigbee tab in the main domoticz screen -> Settings -> settings -> save settings
Ah, Zigbee tab in main screen
Can control Zigbee powerplug -> plugin works and actual version is 9.1.002
So, finally succes to switch to Stable9.
I hope that this can help other users.
