🌙 Nightglass Theme (WIP)
imautohuttraeger
Domoticz version: latest
Re: 🌙 Nightglass Theme (WIP)
Post by imautohuttraeger »
Link is 404
Stop, look and listen.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
galadril wrote: Friday 17 April 2026 20:51 Added a theme setting page!
https://github.com/user-attachments/ass ... ba0e5065f8
Nice !!!
galadril
Post by galadril »
Added theme presets to the theme settings. what do you think of them?
HansieNL
Post by HansieNL »
Great theme with nice presets.
I stick with the default dark theme and use a carbon-fibre background.
Added 1 line to the custom.css file for the background:
body {
    background: var(--dz-bg) !important;
    background-image: none !important;
    background: #1b1d25 url('images/carbon-fibre.png') repeat !important;
Blah blah blah
galadril
Post by galadril »
Thanks all for leaving feedback and bugs on the github page, appreciated!
Ive pushed some more fixes/features on the new version.
all settings pages are now themes/restyled
imautohuttraeger
galadril wrote: Sunday 19 April 2026 14:38 Ive pushed some more fixes/features on the new version.
I really like it! Every user should give it a trial - it is worth it.
Rik60
Post by Rik60 »
Yes, i like it too, but i see some small issues. Can i put them here or do i have to create issues on Github?
HansieNL
Post by HansieNL »
Rik60 wrote: Monday 20 April 2026 9:38 Yes, i like it too, but i see some small issues. Can i put them here or do i have to create issues on Github?
galadril wrote: Wednesday 15 April 2026 21:05 It would be verify helpful if we create the issues/feature requests here btw:
https://github.com/galadril/Domoticz-Ni ... eme/issues
Blah blah blah
jannl
Domoticz version: 2026.1.x
Post by jannl »
I am propably missing something, but how does this work with docker? www/styles dis not exist at first and after creating it en putting nightglass in it, it does not show up as template.
pfloryann
Post by pfloryann »
Theme is cool and thanks for that.
I'm already using it as my base theme :)
I'll add a few things that I think could be nice to implement:
1. The option to select the icon + its color for the widget
2. It might be useful to have the logs and timer buttons in the dashboard widget like in the theme demo.
3. The possibility of grouping multiple devices in a single widget and grouping them per room or preferentially in the dashboard. (I think this is more difficult)
4. Adding the live surveillance camera in a widget in the dashboard
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
madpatrick
pfloryann wrote: Monday 20 April 2026 13:43 Hi,
Hi pfloryann
see : viewtopic.php?p=333009#p333009
galadril
Post by galadril »
Pushed quite a big new update, with
- various fixes
- reworked notifications
- reworked modal dialogs (all, rgb,rgbw,ww,motor,fans,thermostat,setpoint,etc)
Hope you like it
Demo dialog modals -> https://galadril.github.io/Domoticz-Nig ... opups.html
Demo notifications -> https://galadril.github.io/Domoticz-Nig ... tions.html
galadril
Post by galadril »
and new notification config where you can change stuff (and blacklist live notifications for specific devices)
I have trouble to understand the search function that is being used by the theme.
When it shows the list if found devices and it is a sensor I see the current value but not a possibility to go to the log page. Only to the tab where the sensor is used (temperature, weather, other, switches etc).
Going to the page seems strange, I would expect going to the log page. When going to the page I have to find the device again between my 10s of devices.
It looks like I prefer the search function as implemented in the default theme as it just filters the devices in the current tab. And then you can do whatever to normally do with a device (switch it, Edit it, show the log etc).
Am I missing a configuration option here in the nightglass theme?
imautohuttraeger
waltervl wrote: Sunday 03 May 2026 23:37 I have trouble to understand the search function that is being used by the theme.
I am missing the old filter, too. Although I do like this new global search function with integrated switch function or showing the sensor data: Maybe "Go to page" could be substituted by "Show on page", so the link goes to the filtered page.
Information: This refers to gitHub issue No 121:
https://github.com/galadril/Domoticz-Ni ... issues/121
pfloryann
Post by pfloryann »
One option would be for the new search engine to display the device widget in a popup with a design similar to the fan and ventilation or motor and actuator in the nightglass banner(see bottom right of banner) depending on the type of device.. From here you can access the functionalities and even editing.
galadril
Post by galadril »
The Nightglass theme has two search options, each with a different purpose:
/ → Device Search
Quick filter for devices on your current page.
Type, press Enter, and it jumps to the device and hightlight/flashes the device.
Ctrl + K → Command Palette
Global search across all devices with fuzzy matching.
Lets you control devices directly (toggle, dim, navigate), similar to the command palette in Visual Studio Code or Mac Spotlight for example.
👉 In short:
/ = find something
Ctrl + K = find + control something
Does that makes a bit sense?
Also which is maybe a bit unknown currently, keyboard shortcuts:
Press 1-9 to instantly jump to sections:
Key Section
1 Dashboard
2 Switches
3 Scenes
4 Temperature
5 Weather
6 Utility
7 Cameras
8 Log
9 Setup
imautohuttraeger
Latest update also lets you differentiate between search and filter also on mobile devices --> excellent! Thank you!
galadril
Post by galadril »
imautohuttraeger wrote: Tuesday 05 May 2026 20:03 Latest update also lets you differentiate between search and filter also on mobile devices --> excellent! Thank you!
I do try to take your feedback haha, and see if we can rework this to its betters :lol:
domcars0
Domoticz version: 2026.2
Post by domcars0 »
Just a question. I've personnal icons for the 'child lock' switch devices and would like to replace the On/Off png images by awesome fonts.
I've added :
 'images/ChildLock48_On.png':   'fa-solid fa-lock',
	 'images/ChildLock48_Off.png':   'fa-solid fa-lock-open',
In the src/js/icons.js file.
It works when I load the page, but font does not change when I switch the device (I must reload the page) . What do I do to make it works ?
Thank you very much
