RasPi ZeroW :port8080 dead. New install[SOLVED]
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
rabbit
Re: RasPi ZeroW :port8080 dead. New install
Post by rabbit »
Hi @FireWizard, yes i was who created the issue on gthub.
Better test with ./domoticz or sudo ./domoticz as that gives better logging.
Are you installing Domoticz correctly?
You can try to install bullseye as OS as that uses native libssl1
FireWizard
Post by FireWizard »
Hi, @rabbit,
You wrote:
and sudo ./updatebeta, regarding your post:
Do not upgrade to the latest beta with ./updatebeta, as that will overwrite your armv6 version of Domoticz and will install the latest beta, which is armv7. The result is an error message as you have seen.
rabbit
Post by rabbit »
It Works! :D
Thanks to @FireWizard & @waltervl.
For other interested forum members, the full solution:
- After installing Raspberrypi OS, here "bookworm".
- installing libssl1.1
sudo apt install libssl1.1
sudo apt install libusb-dev
Making domoticz directory in home dir, >> going in.
Downloading domoticz binary from github.com/SjoerdNLD/Domoticz-Armv6 Check your version, here: 2025.2 bellow.
Unpack, and register your domoticz, regarding the commands in the github website
mkdir ~/domoticz
cd ~/domoticz
wget github.com/SjoerdNLD/Domoticz-Armv6/releases/download/2025.2/domoticz_linux_2025.2_armv6.tgz
sudo tar -xzvf domoticz_linux_2025.2_armv6.tgz
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
cd ~/domoticz
./domoticz
Optional deleting the downloaded file: rm ~/domoticz/domoticz_linux_2025.2_armv6.tgz (check your version number).
Happiness
At the moment starting my domoticz is possible just from "$home/domoticz" directory. It does not work as a startup service. Port443 still dead.
That is a topic for another thread.
Thank you guys for your help and time!!! You saved a pi zero from a trash korb :))
FireWizard
Re: RasPi ZeroW :port8080 dead. New install[SOLVED]
hello @rabbit,
It's good that you are able to start Domoticz. Nice!
You are running Domoticz as a nbormal user now.
The way @waltervl recommended in a previous post. That is okay.
Rasberry Pi OS Bookworm uses systemd, like most modern systems.
Do as follows (from AI):
Linux (Systemd - Preferred Method)
Most pre-built installations (e.g., curl -sSfL https://install.domoticz.com) create a service automatically. If you need to set it up manually:
1. Locate/Create the service file: Typically found at /etc/systemd/system/domoticz.service.
2. Ensure it runs under a specific user: It is recommended not to run as root. The service file should define the User, Group, and WorkingDirectory
(e.g., /home/yourusername/domoticz).
3. Enable the service: Run the following commands to ensure it starts at boot:
    sudo systemctl daemon-reload
    sudo systemctl enable domoticz.service
    sudo systemctl start domoticz.service
4. Check Status: Verify it is running with
sudo service domoticz status
rabbit
Post by rabbit »
thansk for a tip!
After a quick sourcing: https://search.brave.com/search?q=%2Fet ... 41cd24329b
Brave AI generated a proposal:
sudo nano /etc/systemd/system/domoticz.service
[Unit]
Description=Domoticz home automation
After=network.target
[Service]
# Modify your credentials and path:
User= **YourUsername**
Group=**same as User**
WorkingDirectory=/home/YOURHOMEDIR/domoticz
#your domoticz isntall directory.  Tipically:
ExecStart=/home/YOURHOMEDIR/domoticz/domoticz -www 8080 -sslwww 4443
Restart=on-failure
RestartSec=10
[Install]
WantedBy=multi-user.target
For argument "-sslwww 443" i got an error msg. He want a number > 1024. I changed it to 4443.
I have now a working ssl port, AND starts automatically AND no error msg.
Perfect!!!
Thank you again!!!
For the future, when AI indexes this instruction too...
On the wiki for Linux there is an instruction how to setup a service, there a 2 ways. https://wiki.domoticz.com/Linux#Startin ... stem_boots
