problem installing SolarEdge ModbusTCP plugin
jannl
Domoticz version: 2026.1.x
Re: problem installing SolarEdge ModbusTCP plugin
Post by jannl »
With docker exec you can enter the container and install inside the container. To make this persistent you can use customstart.sh. This is explained in the wiki.
See https://wiki.domoticz.com/Docker
BartSr
Domoticz version: V2024.7
Post by BartSr »
I know Janni, one day this will happen but 1st I need to get the plugin work.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Read the general instructions in the wiki. On recent OS python uses virtual environments (venv). Domoticz Docker is Setup as a virtual environment so there you do not need to do something special.
For Domoticz not running in docker you need to setup a python virtual environment and install the modules inside that.
A python author made a nice instruction for that, it is linked in the wiki https://wiki.domoticz.com/Using_Python_ ... ules_fails
jannl
Post by jannl »
BartSr wrote: Wednesday 24 December 2025 19:39 I know Janni, one day this will happen but 1st I need to get the plugin work.
But that is way easier with docker. The python environment in de container is already prepared.
