Error opening url: http://127.0.0.1:8080/json.htm?type=graph&sensor=counter&range=month&idx=305 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: Error opening url: http://127.0.0.1:8080/json.htm?type=graph&sensor=counter&range=month&idx=305
Are there perhaps already again new hdd devices available that are updated? The replace function should have managed that already with the previous merge. So it is strange it stopped working now suddenly.
- Copitano
- Domoticz version: 2022.2
I rechecked the device list. And yes, new devices have been created. I activated (green to bleu arrow) them, but the new one only has a limited history. However, the old device, which is no longer being updated, still has the full history back to 2020. Should I perhaps do the merge the other way around? So, select "replace" in the new device and then point to the old device?waltervl wrote: Monday 08 September 2025 22:58 Are there perhaps already again new hdd devices available that are updated? The replace function should have managed that already with the previous merge. So it is strange it stopped working now suddenly.
Here is the correct order described https://wiki.domoticz.com/Managing_Devi ... ace_device
If it again failed it could be you ran into a bug.
- Copitano
That's exactly the instruction I followed earlier. I've done it again now. The newly created device disappears. The old one seems to remain as it was and isn't being updated in any case. However, new devices are being created in the device list again, with another green arrow. I also updated under Hardwaretab.waltervl wrote: Tuesday 09 September 2025 0:35 Here is the correct order described https://wiki.domoticz.com/Managing_Devi ... ace_device
Is it a bug then?
Seems so, perhaps create a GitHub issue with logging and screenshots describing the situation.
- Copitano
Okay, I Will. Thanks again.waltervl wrote: Tuesday 09 September 2025 8:22 Seems so, perhaps create a GitHub issue with logging and screenshots describing the situation.
- gizmocuz
This has been noticed recently before. It is the way the devices are created (poked directly into the database)
I am afraid this can not be changed easily without modifying the code.
Is it that big of a problem you loose your history of your harddisk fullness ?
- Copitano
No, not a disaster. It is a shame, though, that all the devices also get different IDX numbers. This means modifying scripts that use them, and forwarding them to Grafana becomes a bit messy. However, in my case, this only applies to the USBbackup. That's a relatively small, mounted USB drive that reaches 100% every 10 days and needs to be wiped clean except for the last day (I'm considering to replace it with a larger one when I have a little time)gizmocuz wrote: Tuesday 09 September 2025 11:28 This has been noticed recently before. It is the way the devices are created (poked directly into the database)
- gizmocuz
I know, unfortunately I am not the author of the changes and have mentioned this during his development.
The good news is that now more disks are detected
