enphase envoy node-red issue
hemant5400z
Re: enphase envoy node-red issue
Post by hemant5400z »
FireWizard wrote: Saturday 05 April 2025 14:53 Hello @
As said before in the Domoticz native Enphase application:
You can look up the counter value at Feb 18 2024 and Feb 17 2025. The difference is your production of last year.
Or select any other date.
If you don't want that.
Create your own energy counter in NR.
see: https://flows.nodered.org/node/node-red ... nergymeter
Is there a proper description for this to setup the flow?
where does power come from MQTT? domoticz not sure on how to setup.
Hemant
gizmocuz
Post by gizmocuz »
In Domoticz, go to Setup->Hardware, add the Enphase hardware and configure the paramaters and you're done.
There is no need for a node-red flow, complicates things and is a waste of resources.
I am sure you can find other interesting stuff to do with Node-Red then trying to get things done that can also be done natively.
FireWizard
Post by FireWizard »
Hello @hemant5400z,
You asked:
In Node-Red almost every node has a short description and examples. Follow the link, that I posted before.
I have no idea, what you mean? I assume you have the data available in NR, otherwise you cannot send the data to Domoticz.
But why dont you follow @Gizmocuz recommendation. Much easier.
That I still have a NR flow running has historical reasons. There was a time that the native solution did not give you the individual panel data.
hemant5400z
Thank both,
I will follow your advice and go with native.
Hemant
FireWizard
Hello
As some of you may know, I use beside the native Enphase integration, also a Node-RED flow.
Since 2 days, I noticed an issue with the login and getting the access token.
It has cost me a couple of hours, until I found that the whole login and getting an access token has changed significantly.
For details see: https://github.com/Maarten234/Enphase-E ... d/issues/3
I assume, that this might have impact on the native integration as well.
I think @gizmocuz should have a look.
hemant5400z
Hi All,
As per 27th of December my NR is not updating my virtual sensors anymore.
I get a json parse error on the URL.
Any ideas what is broken? I did not make changes to the nodered.
FireWizard
Hi @hemant5400z
I do not want to be impolite, but Domoticz forum members are not clairvoyant in general. So you have to provide more information, than you did so far.
So here are the questions:
1.
Can you give us the error?
2. Which node gives that error? Which URL?
3. When did you make the last change? Before or after may/June 2025.
4. How does your flow look like?
5. Have you read the discussion following the link, I previously posted, Sept 20, 2025?
6. In your post of May 27 2025, you said:
Thank both,
Did you do that?
hemant5400z
Hi All,
started digging ino the issue looks like it had to do with changes made by enphase on the token request.
For some reason min got updated in on December 27th while others had been facing this issue earlier in the year.
I adjusted the below flow to my needs to push it to Domoticz vurtual sensors all seems to be working untl Enphase decides to change this again :)
https://github.com/Maarten234/Enphase-E ... /tree/main
I'm using the native for the day to day, but my wattsTotal is not correct so getting it using node-red.
Regards,
Hemant
