Dashticz v3.14.1-beta
Lokonli
Re: Dashticz v3.14.1-beta
Post by Lokonli »
Renber wrote: Saturday 26 April 2025 12:11
I cannot reproduce the problem.
Can you send me:
1. your block definition from CONFIG.js
2. the json output of the Domoticz device:
http://domoticz-ip:port/json.htm?type=command&param=getdevices&rid=123
with 123 your device id.
is ok: blocks['VLC_Bureau'] = {idx:1386,width:12,title:'VLC'};
is not ok: blocks['VLC Bureau'] = {idx:1386,width:12,title:'VLC'};
"SubType" : "X10",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "Media",
Fixed in latest version.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Lokonli wrote: Saturday 26 April 2025 12:47
madpatrick wrote: Saturday 26 April 2025 11:34 Thanks for the quick fix.
How can i adjust the stop button ?
.btn-number.stop 				{width: 88px !important;height: 50px !important; border: 1px solid rgba(255,255,255,0.7);background: red; border-radius: 5px;font-size:20px !important;}
When i change the size it doesn't work
I will make styling a bit easier.
Can you add the following to custom.css for testing:
.mh {
    --col1width: 30px;
    --col2width: 30px;
.right2col {
    padding-right: calc(var(--col1width) + var(--col2width) + 8px);
.col-button2 {
    width: calc(var(--col1width) + var(--col2width));
.col-button2 .btn-number {
    width: var(--col1width);
.btn.stop {
    width: var(--col2width);
    font-size:20px;
    display: flex;
    justify-content: center;
    align-items: center;
/*Only change below this line*/
.mh {
    --col1width: 60px;
    --col2width: 60px;
.mh .btn {
    background-color: #00aaff;
    border-radius: 5px;
.mh .btn.stop {
    background-color: red;
You can change the width of the up/down and stop button via the two parameters: now they are 60px.
The styling can be done via ".mh .btn", or via ".mh .btn.stop" for the stop button only.
If this is working for you let me know, and I'll include in the next version.
Thanks again.
Now it is working and even llok better.
The stop button is perfect now
DOesn't look easier, but maybe becasue the setup is different i need to get used to it
jake
Post by jake »
I updated to today's latest beta and my energy blocks now have all additional title text. For instance, this block:
blocks['240_1'] = {
width: 4,
title: 'Opbrengst',
icon: 'fas fa-sun',
unit: 'W',
switch: true
Now shows in Dashticz as:
0W
Opbrengst: nu
other blocks have now extended titles like:
Opbrengst: Vandaag
Verbruik: Energie vandaag
Verbruik: Energieverbruik
How do I get rid of these descriptive texts behind my titles?
Lokonli
Post by Lokonli »
jake wrote: Saturday 07 June 2025 21:55 I updated to today's latest beta and my energy blocks now have all additional title text. For instance, this block:
blocks['240_1'] = {
width: 4,
title: 'Opbrengst',
icon: 'fas fa-sun',
unit: 'W',
switch: true
0W
Opbrengst: nu
Opbrengst: Vandaag
Add the following:
showsubtitles: false,
jake
Post by jake »
Lokonli wrote: Sunday 08 June 2025 17:06 How do I get rid of these descriptive texts behind my titles?
Add the following:
Thank you, that did the trick!
