How to get this in domoticz
FireWizard
Re: How to get this in domoticz
Post by FireWizard »
Good evening @edwin1234,
You said:
It
Works perfectly
I would say, it works (almost).
The svalue is in this case a fixed value of "0", which means "normal" .
See: https://piandmore.wordpress.com/2019/02 ... -domoticz/
lv is the environment level which can have the following values:
0, normal
1, comfortable
2, dry
3, wet
So regardless of the "Humidity" in percent the environmental level is always normal.
About 5 years ago I created a kind of model for all weather sensors, which I recently updated to support newer Node-RED versions:
See: viewtopic.php?p=263147&hilit=weather#p263147 My post 09 Dec 2020, 16:57.
And also: viewtopic.php?p=323593&hilit=weather#p323593 My post 12 Feb 2025, 19:13
If you want to use that function, you should change the code in the "Function" node into the following:
let hum_stat;
function comfortlevel(hum) {
switch (true) {
    case hum > 70: { hum_stat = 3 } break;
    case hum < 30: { hum_stat = 2 } break;
    case hum >= 30 && hum <= 45: { hum_stat = 0 } break;
    case hum > 45 && hum <= 70: { hum_stat = 1 } break;
    default: { hum_stat = 0 } break;
return hum_stat;
let hu = msg.payload.humidity / 10;
let lv = comfortlevel(hu).toString();
msg.payload = { "command": "udevice", "idx": 1234, "nvalue":parseInt(hu), "svalue": lv};
return msg;
Let me know, if this works for you,
Last edited by FireWizard on Tuesday 11 March 2025 14:49, edited 2 times in total.
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
Thanks for your update
Im gonna try this as soon as possible.
And let you know the results .
edwin1234
Post by edwin1234 »
Hi firewizard,
Can i copy this in to the function node or must i manualy type everything?
Cant find how to do this.
FireWizard
Hi @edwin1234,
I would do it as follows:
1. Drag and drop a new "Function" node to the canvas.
2. Then go to the code block in my previous post and "SELECT ALL".
3. Ctrl-C
4. Open the new "Function" node and
5. Ctrl-V
6. Make your changes, as you did also previously.
7. Replace your old "Function" node with the new one.
edwin1234
Post by edwin1234 »
Thanks,
Now i see i have to do it with a laptop, i did it with copy paste on the ipad with the onscreen keyboard then you cant paste it in the function node.
edwin1234
Post by edwin1234 »
Hi firewizard,
Must it be done like this?
 let hum_stat;
switch (true) {
return hum_stat;
let hu = msg.payload.data.dps["19"] / 10;
msg.payload = { "command": "udevice", "idx": 2381, "nvalue":parseInt(hu), "svalue": lv};
return msg;
FireWizard
Hi @edwin1234,
Yes, that is correct, at least as the data, that you receive in msg.payload.data.dps["19"] is equal to a 3 digit number.e.g. 468, which would result in 46% humidity.
edwin1234
Post by edwin1234 »
I did it like this
But for some reason it doesnt work?
Now i dont get the info into domoticz while it worked while it was like
This:
 msg.payload = { "command": "udevice", "idx": 2381, "svalue":"0","nvalue": parseInt (msg.payload.data.dps["19"] / 10)}
return msg;
FireWizard
Can you send me your flow?
edwin1234
Post by edwin1234 »
I have send you the flow,
Your function node is not atached for now because it didnt work.
And its a bit a mess, but just for testing.
FireWizard
Hello @edwin1234,
I compared the contents of the "Function" node with the one in my "Test" flow.
The contents is equal, so no visible difference. For the moment it works for me, and I cannot explain, why it does not work for you.
As a reference I have attached my test flow.. Try this.
        "id": "4f2495cbd6e0cfec",
        "type": "function",
        "z": "a36df463ae2177b1",
        "name": "function 6",
        "func": "let hum_stat;\n\nfunction comfortlevel(hum) {\n    \nswitch (true) {\n    case hum > 70: { hum_stat = 3 } break;\n    case hum < 30: { hum_stat = 2 } break;\n    case hum >= 30 && hum <= 45: { hum_stat = 0 } break;\n    case hum > 45 && hum <= 70: { hum_stat = 1 } break;\n    default: { hum_stat = 0 } break;\n    }\nreturn hum_stat;\n}\n\nlet hu = msg.payload.data.dps[\"19\"] / 10;\nlet lv = comfortlevel(hu).toString(); \n\nmsg.payload = { \"command\": \"udevice\", \"idx\": 2381, \"nvalue\":parseInt(hu), \"svalue\": lv};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 920,
        "y": 680,
        "wires": [
                "00dd07bac7137f6c"
        "id": "6ba36bb6ce14b5d5",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload.data.dps[\"19\"]",
                "v": "166",
                "vt": "num"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 650,
        "y": 680,
        "wires": [
                "4d1b8e518fd157b5",
                "4f2495cbd6e0cfec"
        "id": "4d1b8e518fd157b5",
        "type": "debug",
        "name": "debug 30",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 920,
        "y": 740,
        "wires": []
        "id": "00dd07bac7137f6c",
        "type": "debug",
        "name": "debug 31",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1100,
        "y": 680,
        "wires": []
edwin1234
Post by edwin1234 »
Thanks firewizard
I wil try it out en let you know
edwin1234
Post by edwin1234 »
For some strange reason its working now.
Dont know how but that doesnt matter :D
FireWizard
Hello @edwin1234,
Good to hear.
It is something strange, I had it also.
When I connected "your Function" node to the same "Inject" node, your "Function" node
did not produce any output, while my original "Function" node (with the same contents) produced the expected output.
I disconnected my "Function" node and it started to work. I reconnected my "Function" node again and
got 2 identical outputs. Strange and I could not reproduce the error afterwards.
Okay, it is working now, so we leave it.
