Re: Decided to use plugin Zigbee for domoticz plugin
Posted: Tuesday 11 February 2025 0:34
When using Zigbee4Domoticz (I still am not sure you are using this or Zigbee2MQTT) you have to put the controller in pairing mode from the Z4D user interface. In the domoticz log you should see statements appear about the controller being in pairing mode.
When the controller is in pairing mode you have to press on the connect button on the plug. But you have to use the instruction of the plug as every zigbee device is a little bit different. When there is a button you normally have to press it a long time to put the plug in pairing mode. Normally you should see a led blink in a blue color. But this also depends on the device. So check the device instruction manual. Also connection messages about the pairing should be visible in the Domoticz log (menu Setup - Log).
If the device led does not blink something is wrong with the plug.
