Failing to understand
solarboy
- Domoticz version: 2024.6
Re: Failing to understand
Isn't that what you require or is there something more complex I have misunderstood ?
FredZ
Sorry, I may not have been entirely clear.
I was assuming that for want of a better term, the script would run every 4 hours (or timer setting)
In my lay persons speak, check the overflow sensor. If active don't turn on the pump, else turn on the pump.
once pump turns off as a result of any of the sensors becoming active the script will stop and wait for the next timer cycle.
The assumption here is that the pump gets turned off and stays off until the next timer cycle.
Fred
Fred
solarboy
This version should only turn the pump on every 4 hours if conditions are met. It will turn off as soon as condition are not met.
devices = {
'Switch1',
'Switch2',
'Switch3',
'Switch4',
timer = {
'every 4 hours',
local dz = domoticz
local dzd = dz.devices
local pump = dzd('Switch1')
local overflow = dzd('Switch2')
local headerFull = dzd('Switch3')
local tankLow = dzd('Switch4')
local chatter = item.isDevice and item.name or item.trigger
dz.log('Header Tank Script triggered by '..chatter, dz.LOG_INFO)
if overflow.state == 'Off' and headerFull.state == 'Off' and tankLow.state == 'Off' -- this ensures pump will only turn on if conditions are right
and chatter == 'every 4 hours' -- this ensure the pump only turns ON if the script was activated by the timer
then
pump.switchOn()
domoticz.log('Pump turning On triggered by '..chatter,dz.LOG_FORCE)
elseif chatter ~= 'every 4 hours'
then
pump.switchOff()
domoticz.log('Pump turning Off triggered by '..chatter,dz.LOG_FORCE)
if tankLow.state == 'On'
then
--put your notification method here
domoticz.log('Tank Low',dz.LOG_FORCE)
- habahabahaba
- Domoticz version: 2024.4
Let me try
devices = {
'Switch2',
'Switch3',
'Switch4',
timer = {
'every 4 hours',
--'every 1 minutes' -- for testing
logging = {
level = domoticz.LOG_INFO,
marker = 'Filling the tank',
local pump = domoticz.devices('Switch1') -- as it was said the Pump had to not trigger the script
local overflow = domoticz.devices('Switch2')
local headerFull = domoticz.devices('Switch3')
local tankLow = domoticz.devices('Switch4')
if item.isTimer then -- here are conditions for time
domoticz.log('Script is triggered by timer', domoticz.LOG_INFO)
if overflow.state == 'On' then -- or Off ? set what you need
pump.switchOn().checkFirst()
domoticz.log('Pump is turned on by timer and overflow', domoticz.LOG_INFO)
domoticz.log('Pump was NOT turned on by timer because of overflow', domoticz.LOG_INFO)
else -- here are conditions for devices
domoticz.log('Script is triggered by device '.. item.name, domoticz.LOG_INFO)
pump.switchOff().checkFirst()
domoticz.log('The pump was turned off the trigger device - '.. item.name, domoticz.LOG_INFO)
if item.name == 'Switch4' then -- put here the name of device
domoticz.log('The Tank level is LOW. You can put here any notification or turn the pump ON', domoticz.LOG_INFO)
FredZ
Well done. this script seems to do what I wanted.
So what I have discovered is that there seem to be many ways to accomplish the same outcome. Also as a lay person I need to be more specific about the application and the outcome I am seeking.
There are many things I wish to do within Dom, and I am going to study what has been posted here in the vein attempt to get an understanding of how this sort of programming works. And maybe write something that functions for me. Reading the docs didn't improve my ability to understand. I felt as thought the docs were pointed toward someone with some understanding of programming.
Thank you to solarboy for the fine effort he put in and for being so tolerant of my programming ineptitude. It is pleasing to see that there are people out there that are genuinely prepared to help even if what is being asked seems simple to them.
Fred
Fred
habahabahaba wrote: Saturday 25 January 2025 14:31 Let me try
return { on = { devices = { 'Switch2', 'Switch3', 'Switch4', }, timer = { 'every 4 hours', --'every 1 minutes' -- for testing }, }, logging = { level = domoticz.LOG_INFO, marker = 'Filling the tank', }, execute = function(domoticz, item) local pump = domoticz.devices('Switch1') -- as it was said the Pump had to not trigger the script local overflow = domoticz.devices('Switch2') local headerFull = domoticz.devices('Switch3') local tankLow = domoticz.devices('Switch4') if item.isTimer then -- here are conditions for time domoticz.log('Script is triggered by timer', domoticz.LOG_INFO) if overflow.state == 'On' then -- or Off ? set what you need pump.switchOn().checkFirst() domoticz.log('Pump is turned on by timer and overflow', domoticz.LOG_INFO) else domoticz.log('Pump was NOT turned on by timer because of overflow', domoticz.LOG_INFO) end else -- here are conditions for devices domoticz.log('Script is triggered by device '.. item.name, domoticz.LOG_INFO) pump.switchOff().checkFirst() domoticz.log('The pump was turned off the trigger device - '.. item.name, domoticz.LOG_INFO) if item.name == 'Switch4' then -- put here the name of device domoticz.log('The Tank level is LOW. You can put here any notification or turn the pump ON', domoticz.LOG_INFO) end end end }
solarboy
Glad you got it sorted and thanks for tolerating MY ineptitude also.
