Ecowitt WS90 and RFX868, missing sensors
PatrickH67
Domoticz version: 2024.4
Re: Ecowitt WS90 and RFX868, missing sensors
Post by PatrickH67 »
gizmocuz wrote: Thursday 12 September 2024 11:06
Could you please confirm that version 2024.4 of Domoticz should work or should I upgrade to a newer version
No, this is not working as a recent patch has been made.
You have to use the beta version.
Bdw, the stable release is 2024.7 (but you need to use the current beta!)
In the settings you can specify to use the beta version.
Just make a complete backup before just in case
I would like to thank everyone who took the time to answer my various questions and especially gizmocuz and b_weijenberg
After having updated my Domoticz to the last beta version I have now access to all of my Ecowitt sensors from WS90 and WH57
Thank you very much for your help
Patrick
PatrickH67
Some feedback after several days of using the beta version with the Ecowitt WS90
All sensors works fine in domoticz except the "rain" one which always return a zero value where the Ecowitt application returns some values
Patrick
gizmocuz
Post by gizmocuz »
Found the issue with the rain sensor. Please upgrade to beta 16268
PatrickH67
gizmocuz wrote: Tuesday 01 October 2024 15:58 Found the issue with the rain sensor. Please upgrade to beta 16268
Thanks a lot for your support
I have upgraded to version beta 16268 and now I have some values for the Rain sensor in Domoticz.
But some values are not correct compared to the ones from Ecowitt application
The big value of 253,9 correspond to the date at which I have updated the Domoticz version, so it corresponds to the total value seen by the rain sensor at this date.But the value 60,9 for Saturday (today) on the weekly graph is not correct at all and also not in line with first graph (5 day graph)
12-10-2024 12-48-05.png (214.38 KiB) Viewed 1107 times
I have also noticed some "strange" values (very big values) for the wind sensor (see screenshot), those values are not present in the Ecowitt application and may come from erroneous decoding of the data stream may be from RFX868 !?
12-10-2024 12-57-05.png (95.45 KiB) Viewed 1107 times
Patrick
