Domoticz 16083 freezing (including 16086 version)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
PA3FAT
Re: Domoticz 16083 freezing (including 16086 version)
Post by PA3FAT »
if from the ssh promp do
"sudo ./domoticz"
it keeps running from my direct ip (so not via my url which is not more than portforwarding)
PA3FAT
Post by PA3FAT »
Removed in the domoticz.sh following loglevel.
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,events
ystem,python,thread_id"
It seems to keep running......via the regular daemon
Update: runs as before now. Via domain and local ip.
Logging levels less as a result of the ARGS defined.
Domoticz version: 2024.7
There is nor recent crash.log file in the Domoticz folder? Check the troubleshooting wiki for info.
If you run it with
sudo ./domoticz -nowwwpwd
Did you check the menu setup - users for multiple admins? There should be 1.
Check the password for that admin.
Check the security settings.
Last resort is to go back to your latest running environment before updating to beta as instructe on the wiki. But there are only 5 backups saved so if you updated more then 5 times already that first vbackup is already gone...
gizmocuz
Post by gizmocuz »
PA3FAT wrote: Thursday 20 June 2024 19:12 Removed in the domoticz.sh following loglevel.
Good, you don't want to run with debuglevels anyway, but there seems to be something going wrong here
First of all, I have to assume that line above is on a single line and not two lines, so it should look like this:
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
It must be one of these log levels that is causing issues
Could you try them one by one to see which one is causing the issue?
You do not have to check 'thread_id'
There have been some recent changes to the python implementation, but best to check them all
I will also recheck all debug logging, but that are 'a lot' of lines
Edit: Can't find any changes to logging lately. Are you using the binary version or are you compiling yourself? If you are compiling yourself, are you running in debug or release build mode?
PA3FAT
Post by PA3FAT »
Will see if i can do a one by one on the debug levels.
My issues started after 16083 upgrade. Tried to many times so no option to revert.
I am not compiling the Domoticz myself. Did the initiall setup already years ago and update via regular update process in the GUI or sometimes ./updatebeta
rick8245
Post by rick8245 »
I still have this problem.
I do NOT have this line in my domoticz.sh
ystem,python,thread_id" so i cannot remove it
When i start it interactively with :
sudo ./domoticz -nowwwpwd it freezes after 15 - 20 minutes and does no work anymore.
Can I go back to the version of march/April this year .
Than I had not yet this issue.
Oh, i run this on a raspberry for 3 years now without any issues but since june/july it is not reliable
Thanks in advance
Rick8245
jonsludde
Post by jonsludde »
I have the same problem and been struggling with this for many hour.
My setup is a new RP4, latest OS, latest domotics, docker and installed as per instructions.
A MyZwave gpio-card, moved from my old RP3, database backup from RP3 installed on the new RP4.
MQTT seems to work, JSUI seems to work.
I have enabled log and debug, all except sql, alot coming in and it seems to work OK. (root@jonshome:/opt/mosquitto# /home/pi/domoticz/domoticz -nowwwpwd -daemon -www 8088 -log /var/log/domoticz.log -loglevel all -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id,auth
When I start a browser and f.i. go to http://jonshome:8088/ domotics die and the last lines in the log contains:
The latest thing I tested was to remove the Zwave card, but that didn't help.
Before that I uninstalled docker and the 2 containers.
I have tested Edge and Chrome in windows and chrome on android, all of them crashes domoticz. Well crashes, the crashlog is empty, domoticz just dies..
I'm out of ideas now, hopefully some of you guys can help out.
jonsludde
Post by jonsludde »
Today it works, I have no clue as to why, nothing has been done with the Raspberry or OS or other SW.
Well, guess I just should be happy that it works.
Cheers
