Earthquake info from KNMI
janpep
- Domoticz version: v2026.3
Re: Earthquake info from KNMI
HvdW pointed out to me that Weerlive also offers the data that I obtain from Buienradar. So I could reduce the number of sources I use. I am currently working on realizing that. For my own use, I continue to obtain wind and air quality index parameters (for the Dutch local 'Stookwijzer') from one common source at Open Meteo. This because others do not provide current and forecast values per hour for pm10, pm2_5, nitrogen_dioxide and ozone. These are used to calculate the air quality index.
When it's done, I shall post the weerlive end result in a separate topic.
Dz on Ubuntu VM on Proxmox behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
janpep
Update with some minor changes, including adding font color for better visibility of the hyperlinks.
BTW. The problem with interaction between scripts no longer occurred. It remains unclear to me what caused it and what solved it. So, as I always say: "Don't ask how it is done, but enjoy it." For now I consider it resolved.
-- 07-05-2024 script by Jan Peppink, https://ict.peppink.nl
-- Based on earlier script found on https://www.domoticz.com/forum/viewtopic.php?t=41380
-- Missed Dutch earthquakes. Modified script to get info from KNMI Aardbevingen RSS.
-- Parse XML result to get info from the most recent of 30 in the list.
-- URL = https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml
-- Function 'getUTCtimediffseconds' expected in global_data.
-- 09-05-2024 directly make use of dz.log instead of the 'logthis' function in global_data.
-- 10-05-2024 Again some adjustments to the log function.
-- 13-05-2024 Added font color for hyperlinks.
--- Your settings ----------------------------------------------------------------
-- First set the used device index numbers and variables you might want to change.
local alertIdx = n -- Set to the idx of the Virtual Alert sensor you have to create for this script
local mailto = '[email protected]' -- Set E-mail adres to sent notification to.
local knmiURL = 'https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml'
-- Define distance for ALERTLEVEL colors
-- From dClose to the maxRadius we get: ALERTLEVEL_GREY
local dClose = 300 -- From distance dCloser to dClose: ALERTLEVEL_YELLOW
local dCloser = 200 -- From distance dClosest to dCloser: ALERTLEVEL_ORANGE (+ eMail notification)
local dClosest = 100 -- From distance 0 to closest: ALERTLEVEL_RED (+ eMail notification)
timer = {
'every 5 minutes',
httpResponses = {
'knmi-rss' -- matches callback string below
logging = {
-- Level can be domoticz.LOG_INFO, domoicz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE
level = domoticz.LOG_INFO,
--level = domoticz.LOG_DEBUG,
marker = 'KNMI-',
execute = function(dz, triggeredItem)
-- Set Local environment=================
local _u = dz.utils -- Holds subset of handy utilities.
local _h = dz.helpers -- Holds the global functions.
local _d = dz.globalData -- Holds the global data.
-- Set your loccation coordinates from Domoticz settings =================
local yourLatitude = dz.settings.location.latitude
local yourLongitude = dz.settings.location.longitude
-- Use some color variables
local cBlue = '#0000FF;'
htmlColor = cBlue
-- Set your alert device index to store the result.
local alertLevel = dz.ALERTLEVEL_GREY -- Holds the alertLevel (color) to set
local alertText = ''
local lastalertText = dz.devices(alertIdx).text -- Holds string of the previous round.
local lTimediff = 0 -- Calculate diff in seconds between UTC and local time of this event.
local delString = "" -- Holds (sub) string to delete.
-- Local Functions go here =============
-- Calculate distance using Haversine formula
local function calculateDistance(lat1, lon1, lat2, lon2)
local R = 6371 -- Earth radius in kilometers
local dLat = math.rad(lat2 - lat1)
local dLon = math.rad(lon2 - lon1)
local a = math.sin(dLat / 2) * math.sin(dLat / 2) + math.cos(math.rad(lat1)) * math.cos(math.rad(lat2)) * math.sin(dLon / 2) * math.sin(dLon / 2)
local c = 2 * math.atan2(math.sqrt(a), math.sqrt(1 - a))
local distance = R * c
return distance
-- Now start to do something ============
if (triggeredItem.isTimer) then
dz.openURL({
url = knmiURL,
method = 'GET',
callback = 'knmi-rss'
if (triggeredItem.isHTTPResponse) then
-- Process the obtained data.
if (triggeredItem.ok and triggeredItem.isXML) then
-- We have something, which looks like this:
--<rss xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#" xmlns:georss="http://www.georss.org/georss" version="2.0">
-- <channel>
-- <copyright>Copyright KNMI</copyright>
-- <description>KNMI - de laatste 30 registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</description>
-- <title>KNMI - de meest recente registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</title>
-- <item>
-- <title>2024-05-05, 't Zandt, M=0.3</title>
-- <description>2024-05-05, 19:14:45, Lat = 53.357, Lon = 6.783, Diepte = 3.0 km, M = 0.3, Plaats = 't Zandt, Author = KNMI, Type = Geinduceerd, Analyse = Reviewed</description>
-- <geo:lat>53.357</geo:lat>
-- <geo:lon>6.783</geo:lon>
-- <georss:point>53.357 6.783</georss:point>
-- <link>http://www.knmi.nl/nederland-nu/seismologie/aardbevingen/knmi2024ivvz</link>
-- <guid>knmi2024ivvz</guid>
-- </item>
local result_table = triggeredItem.xml
if type( result_table ) == "table" then
dz.log( 'result_table: type = ' .. type(result_table), dz.LOG_DEBUG )
-- Get only the info from the first item.
-- Get link to page with details.
dz.log( result_table.rss.channel.item[1].link, dz.LOG_DEBUG )
local qUrl = tostring( triggeredItem.xml.rss.channel.item[1].link )
-- The complete description to split up. Put it in a table.
dz.log( result_table.rss.channel.item[1].description, dz.LOG_DEBUG )
local description_table = _u.stringSplit( result_table.rss.channel.item[1].description, ',' )
-- Get time (= UTC time) from the description_table.
-- Record 1 = 2024-05-05; Record 2 = 19:14:45 (strip the seconds)
local atUTCtime = description_table[1] .. ' ' .. string.sub( description_table[2], 2, 6 )
atUTCtime = dz.time.dateToDate( atUTCtime, 'yyyy-mm-dd hh:MM', 'dd-mm-yyyy hh:MM', 0 )
dz.log( 'atUTCtime = ' .. atUTCtime, dz.LOG_DEBUG )
-- Calculate the Local time.
local qUnixtime = dz.time.dateToTimestamp( atUTCtime, 'dd-mm-yyyy hh:MM' )
lTimediff = _h.getUTCtimediffseconds( qUnixtime )
local atLocalTime = dz.time.timestampToDate( qUnixtime, 'dd-mm-yyyy hh:MM', lTimediff )
dz.log( 'atLocalTime = ' .. atLocalTime, dz.LOG_DEBUG )
-- Record 3 = Lat = 53.357
delString = "Lat = "
local qLat = tostring(description_table[3]):gsub( delString, "" )
dz.log( 'qLat = ' .. qLat, dz.LOG_DEBUG )
-- Record 4 = Lon = 6.783
delString = "Lon = "
local qLon = tostring(description_table[4]):gsub( delString, "" )
dz.log( 'qLon = ' .. qLon, dz.LOG_DEBUG )
-- Record 5 = Diepte = 3.0 km
delString = "Diepte = "
local qDepth = tostring(description_table[5]):gsub( delString, "" )
dz.log( 'qDepth = ' .. qDepth, dz.LOG_DEBUG )
-- Record 6 = M = 0.3
delString = "M = "
local qMag = tostring( description_table[6]):gsub( delString, "" )
dz.log( 'qMag = ' .. qMag, dz.LOG_DEBUG )
-- Record 7 = Plaats = 't Zandt
delString = "Plaats = "
local qPlace = tostring(description_table[7]):gsub( delString, "" )
dz.log( 'qPlace = ' .. qPlace, dz.LOG_DEBUG )
-- Record 8 = Author = KNMI
local qAuthor = description_table[8]
-- Record 9 = Type = Geinduceerd
local qType = description_table[9]
-- Record 10 = Analyse = Reviewed
-- Calculate distance from home location.
local distance = calculateDistance( yourLatitude, yourLongitude, qLat, qLon )
-- Round the distance to the nearest kilometer
local roundedDistance = _u.round( distance, 0 )
--Set Alertlevel color based on distance.
if roundedDistance < dClosest then
alertLevel = dz.ALERTLEVEL_RED
elseif roundedDistance >= dClosest and roundedDistance < dCloser then
alertLevel = dz.ALERTLEVEL_ORANGE
elseif roundedDistance >= dCloser and roundedDistance < dClose then
alertLevel = dz.ALERTLEVEL_YELLOW
--Set and format the new alertText
local alertText = tostring( atLocalTime .. ' uur in ' .. qPlace .. '\n' .. 'Magnitude: ' .. qMag .. '. Diepte: ' .. qDepth .. '. Afstand: ' .. roundedDistance ..' km.\n' .. '<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '" target="_blank"><span style="color: ' .. htmlColor .. '">Toon locatie</span></a>' .. ' - ' .. '<a href="' .. qUrl .. '" target="_blank"><span style="color: ' .. htmlColor .. '">Toon bron</span></a>' )
-- Only update and send mail when info has changed. and
if alertText ~= lastalertText then
-- We have new information, so update the device.
dz.devices(alertIdx).updateAlertSensor(alertLevel, alertText)
-- Only send email when it comes closer then dCloser
if roundedDistance <= dCloser then
--Set and format the new mail message
local message = tostring('Plaats: ' .. qPlace .. '<br>' ..
'Magnitude: ' .. qMag .. '<br>' ..
'Diepte: ' .. qDepth .. '.<br>' ..
'Lokale Tijd: ' .. atLocalTime .. ' uur.<br>' ..
'UTC Tijd: ' .. atUTCtime .. ' uur.<br>' ..
'Afstand: ' .. roundedDistance .. 'km.<br>'..
'Coördinaten: ' .. qLat .. ','.. qLon .. '<br>' ..
qAuthor .. '<br>' ..
qType .. '<br>' ..
'<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '">Toon locatie</a>' .. '<br>' ..
'<a href="' .. qUrl .. '">Toon bron</a>' .. '<br>' )
-- Send the mail
dz.email( 'Aardbeving ' .. qPlace, message, mailto )
dz.log( 'No result_table found', dz.LOG_ERROR )
dz.log( 'Item or XML - NOT OK', dz.LOG_ERROR )
-- That's All --------------------------------------------------Dz on Ubuntu VM on Proxmox behind FRITZ!Box.
janpep
Oops!
I discovered that the comparison with the last saved value does not work when using hex color. Clear example of not being tested long enough. This is now causing the mail to be sent every 5 minutes. Excuse me. I am working on it.
janpep
The issue is solved by using plain text 'Blue' instead of the hexadecimal color code '#0000FF;'.
It turned out this caused the problem when comparing last and new alert string, because of the semicolon, which is not escaped and ended the string.
Update of the device and sending of mail notification will again only take place when the content has changed.
Sorry for the inconvenience. This shoud be beter:
timer = {
'every 5 minutes',
httpResponses = {
logging = {
marker = 'KNMI-',
-- Use color variable for hyperlink font color
htmlColor = 'Blue'
return distance
dz.openURL({
url = knmiURL,
method = 'GET',
-- <channel>
-- <item>
-- </item>
delString = "M = "
dz.log( 'LastalertText = ' .. lastalertText, dz.LOG_DEBUG )
dz.log( 'NewalertText = ' .. alertText, dz.LOG_DEBUG )
dz.devices(alertIdx).updateAlertSensor( alertLevel, alertText )
'Afstand: ' .. roundedDistance .. 'km.<br>' ..
qType .. '<br>' ..
-- Send the mail
- psubiaco
post cancelled
Paolo
janpep
Please note that I have specially started this separate earthquake topic with the name "Eurthquake info from KNMI" !!
I did this to prevent confusion by mixing things up.
That is precisely why I have not posted my script information in the topic that already concerns the other source: seismicportal.eu
Please keep it there!
- psubiaco
post cancelled
Paolo
- Domoticz version: 2026.3
In latest Beta dVents logging has been simplified and more on line of normal logging. See for more info the already mentioned link and the new logging dzvents template.waltervl wrote: Wednesday 08 May 2024 16:01 You can set log level per logging line. eg
From documentation:Code: Select all
dz.log('extra debug: Device 123 is ' .. myName, dz.LOG_DEBUG)See following topic for examples https://www.domoticz.com/forum/viewtopi ... 85#p279685domoticz.log(message, [level]): Function. Creates a logging entry in the Domoticz log but respects the log level settings. You can provide the loglevel: domoticz.LOG_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE. In Domoticz settings you can set the log level for dzVents.
janpep
To be honest, I do not understand.waltervl wrote: Friday 05 July 2024 22:45 In latest Beta dVents logging has been simplified and more on line of normal logging. See for more info the already mentioned link and the new logging dzvents template.
- You quote your own contributiion of more than two month ago, while for me the "problem" was solved. So it's a bit like an answer to a question that was not asked.
- You are referring to the latest beta version, which most people probably won't have. It seems correct to me to assume that people are running the latest stable version.
- In the link you gave, there is also a post that refers to 'latest Beta 2024.4'. I run the stable 2024.4, so I expect that a latest beta should be beyond that number?
- Then It is not clear to me WHAT has changed.
- You refer to a template, which I do not see anywhere.
- And finally: I already reported that the logging "problem" for me was solved after your first explanation ,for which I thank you.
At the moment I have two "standard" lines in my scripts.
--level = domoticz.LOG_INFO
--level = domoticz.LOG_DEBUG- Sometimes only the INFO line commented out, to get some basic logging of start and end times.
- Sometimes only the DEBUG line commented out, to debug and see the lines in the script are as...
dz.log('I want this to be logged when I am debugging', dz.LOG_DEBUG) More of this in other (logging) topics please.
I just wanted you to inform you of the change in dzvents logging in latest Beta (and upcoming stable)..... Sorry for the misunderstanding. I thought you would appreciate it.
janpep
That is appreciated, but I can not do anything with it right now.
I think very soon you can as I feel a new stable is close by.
Fredom
Great script and very useful.
Unfortunately I get an error message that I cannot resolve.
Error
local alertIdx = 133 -- Set to the idx of the Virtual Alert sensor you have to create for this script
local mailto = 'XXXXXX.com' -- Set E-mail adres to sent notification to.
timer = {
'every 5 minutes',
httpResponses = {
logging = {
marker = 'KNMI-',
htmlColor = 'Blue'
return distance
dz.openURL({
url = knmiURL,
method = 'GET',
-- <channel>
-- <item>
-- </item>
delString = "M = "
qType .. '<br>' ..
-- Send the mail
Error
2024-07-06 13:20:01.217 Error: dzVents: Error: (3.1.8) KNMI-: An error occurred when calling event handler Aardbevingen
2024-07-06 13:20:01.217 Error: dzVents: Error: (3.1.8) KNMI-: ...oticz/scripts/dzVents/generated_scripts/Aardbevingen.lua:119: attempt to index a nil value (local '_h')
2024-07-06 13:25:01.435 Error: dzVents: Error: (3.1.8) KNMI-: An error occurred when calling event handler Aardbevingen
2024-07-06 13:25:01.435 Error: dzVents: Error: (3.1.8) KNMI-: ...oticz/scripts/dzVents/generated_scripts/Aardbevingen.lua:119: attempt to index a nil value (local '_h')
-- That's All --------------------------------------------------Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Fred
janpep
As explained earlier, the script expects some items in the global_data script.
That is the the global-place used for functions and persistent variables so that they can be used from several scripts. So it functions as a 'central place'.
So 'local _h' points to: dz.helpers which holds the global functions.
For explanation see: DzVents Wiki page
Place the next functions that are used in the helper section of the global_data script. Create one if it does not exist yet.
Hope this helps.
-- Global helper functions
helpers = {
-- Used in t-Alarmeringen, t-Earthquake-KNMI,
getUTCtimediffseconds = function(qUnixtime)
local timezone = os.date('%z', qUnixtime) -- "+0200"
local signum, hours, minutes = timezone:match '([+-])(%d%d)(%d%d)'
local lTimediff = (tonumber(signum..hours)*3600 + tonumber(signum..minutes)*60)
return lTimediff
end,
-- Used in t-Earthquake-KNMI, t-Airplanes,
calculateDistance = function( lat1, lon1, lat2, lon2)
return distance
end,
Kedi
- Domoticz version: latest
Instead of using;
you can use
math.sin(dLat / 2) * math.sin(dLat / 2)Code: Select all
math.sin(dLat / 2)^2Logic will get you from A to B. Imagination will take you everywhere.
janpep
I am not a mathematician and have just taken the calculation from the mentioned topic https://www.domoticz.com/forum/viewtopic.php?t=41380. And it works.
What is the difference in outcome? To me it looks like it will be the same
Or do you think it will save a lot of time?
Kedi
It is more readable/shorter. The opposite of sqrt.
Ofcourse there is no difference in outcome.
But it is your party.... and I wrote 'can'
janpep
Here I prefer 'easier for everyone to understand' than 'shorter'.
Fredom
I did as you suggested,
I added the function. Unfortunately still the same error message. I am not a programmer, so this is beyond my knowledge.
local mailto = 'XXXXXXXX.com' -- Set E-mail adres to sent notification to.
timer = {
'every 5 minutes',
httpResponses = {
logging = {
marker = 'KNMI-',
htmlColor = 'Blue'
-- local function calculateDistance(lat1, lon1, lat2, lon2)
-- local R = 6371 -- Earth radius in kilometers
-- local dLat = math.rad(lat2 - lat1)
-- local dLon = math.rad(lon2 - lon1)
-- local a = math.sin(dLat / 2) * math.sin(dLat / 2) + math.cos(math.rad(lat1)) * math.cos(math.rad(lat2)) * math.sin(dLon / 2) * math.sin(dLon / 2)
-- local c = 2 * math.atan2(math.sqrt(a), math.sqrt(1 - a))-
-- local distance = R * c
-- return distance
-- end
helpers = {
return lTimediff
end,
return distance
end,
dz.openURL({
url = knmiURL,
method = 'GET',
-- <channel>
-- <item>
-- </item>
delString = "M = "
qType .. '<br>' ..
-- Send the mail
Yours sincerely,
Fred
Fred
