Page 2 of 2
Re: P1 meter suddenly stopped working
Posted: Thursday 18 April 2024 0:41
by waltervl
As mentioned before check with
ls /dev/serial/by-id
Also in the P1 hardware configuration you should see the by-id entries in the pulldown list in the serial port field.
Posted: Friday 19 April 2024 19:40
by balosa
i finally got the
by-id working, but it still won't receive any data, I will contact the Electric Company to let them check the meter is working 100%, I have my doubts it is sending telegrams through the P1, next thing is to buy another P1 cable too see if that changes anything, probably will buy a P1 ethernet thingy so i can access it through LAN
- P1meter_5.jpg (81.03 KiB) Viewed 2272 times
- P1meter_4.jpg (198.38 KiB) Viewed 2272 times
Posted: Friday 19 April 2024 21:02
by FireWizard
Are you sure that the Baudrate is only 9600 Bd.
This is only the case if your P1 Smartmeter uses DSMR protocol 2.2,
which is rather old. What is your meter brand/type?
Posted: Friday 19 April 2024 23:32
by balosa
yes i am sure, it was always on 9600
it's a Kamstrup 162JxC, it's over 10yrs old for sure
Posted: Monday 22 April 2024 13:50
by FireWizard
Hi @balosa
Did you check the USB port to which the P1 Smart meter cable has been connected?
If you found the correct USB port, did you check the RAW protocol?
Stop Domoticz and execute the following command in case the port is USB0. If otherwise replace the number.
cu -l /dev/ttyUSB0 -s 9600 --parity=none
What do you see?
Let us know.
Posted: Sunday 05 May 2024 22:35
by balosa
Sorry for the late response, it just says it is connected.
After that it hangs, I have to restart Putty to enter commands again
- P1meter_7.jpg (14.55 KiB) Viewed 2190 times
Posted: Tuesday 11 June 2024 10:25
by balosa
Well there is a breakthrough, the problem was the electricity meter from the power company, it didn't send anymore data through the P1 and to the company itself, the meter has been replaced and now I'm getting data again.
Thanks to all who did try to help and for the advice given !
