Page 2 of 4
Re: Z-Wave not working under Zwave-JS-UI
Posted: Sunday 10 March 2024 10:11
by BartSr
ok. and did you change prefix zwave > zwavejs
not sure but I thought you need to reboot after that change
and domoticz settings must allow for new devices
what devices do you own? switches will appear in short time but measuring devices must first have seen a change of measured value
Posted: Sunday 10 March 2024 10:28
by keef
Where?
Done
Switches and measuring devices
Posted: Sunday 10 March 2024 23:03
by BartSr
prefix to be changed both in zwavejs as well as domoticz hardwarepage
Posted: Tuesday 12 March 2024 9:24
by keef
Well I now get this
Posted: Tuesday 12 March 2024 10:09
by BartSr
imho zwave2mqtt is now running as expected. And what is on zwavejs-ui control panel?
Posted: Tuesday 12 March 2024 11:29
by keef
I have this
Posted: Tuesday 12 March 2024 13:34
by jvdz
Looks like your nodes aren't discovered yet, so you first need to get ZWAVEJS2MQTT working properly, before you can do anything with domoticz.
Posted: Tuesday 12 March 2024 14:14
by keef
Thanks for your help and patience.
How do I do that please
Posted: Tuesday 12 March 2024 14:54
by jvdz
Have you setup the zwave part in ZWAVEJS2MQTT correctly, like the proper network keys?:
https://zwave-js.github.io/zwave-js-ui/ ... ?id=z-wave.
.. and did you wake all devices up to ensure they tell the coordinator that they are there?
Posted: Tuesday 12 March 2024 18:10
by keef
Yes I have set up the network keys. I did a hard reset on the z-wave controller and it now only lists this in Z-Wave JS UI
But when I try to include a device it doesn't work (I'm assuming I do this in Z-Wave JS UI)
Posted: Tuesday 12 March 2024 18:28
by jvdz
keef wrote: Tuesday 12 March 2024 18:10
Not sure why you've done that... but understand you decided to start all over again and want to include all devices again.
This is indeed all ZWAVEJS2MQTT stuff. As mentioned, you will have to get all devices properly list in ZJS2M first before Domoticz will get the required config via Auto Discovery.
Posted: Tuesday 12 March 2024 18:55
by keef
jvdz wrote: Tuesday 12 March 2024 18:28
Yep wanted a clean start
I have put the devce and Zwave-JS-UI in inclusion mode (I even reset the device (to make sure it wasn't being stupid) but it just times out.
Posted: Friday 15 March 2024 9:57
by BartSr
which pi and which zwave stick are used?
Posted: Friday 15 March 2024 10:45
by keef
It's a pi4 and a zwave.me USB Stick
Posted: Friday 15 March 2024 11:10
by BartSr
did you use this stick before with OZW? Some sticks are not compatible with pi4.
Posted: Friday 15 March 2024 11:31
by keef
yes it was working before
Posted: Friday 15 March 2024 20:40
by BartSr
some sticks allow including just with stick near zwavedevice iso via zwavejs-ui. Is that possible for you?
And do you disable ozw in domoticz? Otherwise stick cannot be used in zwavejs.
Posted: Saturday 16 March 2024 9:33
by keef
I shall see if range is and issue.
No it is a fresh clean install
Posted: Saturday 16 March 2024 11:54
by keef
Nope range isn'the issue
Posted: Saturday 16 March 2024 12:57
by BartSr
did you unplug stick and include with stick near zwave device?
