Z-Wave not working under Zwave-JS-UI
BartSr
Domoticz version: V2024.7
Re: Z-Wave not working under Zwave-JS-UI
Post by BartSr »
ok. and did you change prefix zwave > zwavejs
not sure but I thought you need to reboot after that change
and domoticz settings must allow for new devices
what devices do you own? switches will appear in short time but measuring devices must first have seen a change of measured value
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
keef
Domoticz version: 2024.4
Post by keef »
Where?
Done
Switches and measuring devices
BartSr
Post by BartSr »
prefix to be changed both in zwavejs as well as domoticz hardwarepage
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
keef
Post by keef »
Well I now get this
BartSr
Post by BartSr »
imho zwave2mqtt is now running as expected. And what is on zwavejs-ui control panel?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
keef
Post by keef »
I have this
control panel.jpg (268.01 KiB) Viewed 3087 times
jvdz
Domoticz version: 4.107
Post by jvdz »
Looks like your nodes aren't discovered yet, so you first need to get ZWAVEJS2MQTT working properly, before you can do anything with domoticz.
keef
Post by keef »
Thanks for your help and patience.
How do I do that please
jvdz
Post by jvdz »
Have you setup the zwave part in ZWAVEJS2MQTT correctly, like the proper network keys?: https://zwave-js.github.io/zwave-js-ui/ ... ?id=z-wave.
.. and did you wake all devices up to ensure they tell the coordinator that they are there?
keef
Post by keef »
Yes I have set up the network keys. I did a hard reset on the z-wave controller and it now only lists this in Z-Wave JS UI
But when I try to include a device it doesn't work (I'm assuming I do this in Z-Wave JS UI)
jvdz
Post by jvdz »
keef wrote: Tuesday 12 March 2024 18:10 Yes I have set up the network keys. I did a hard reset on the z-wave controller and it now only lists this in Z-Wave JS UI
Not sure why you've done that... but understand you decided to start all over again and want to include all devices again.
keef wrote: Tuesday 12 March 2024 18:10 But when I try to include a device it doesn't work (I'm assuming I do this in Z-Wave JS UI)
This is indeed all ZWAVEJS2MQTT stuff. As mentioned, you will have to get all devices properly list in ZJS2M first before Domoticz will get the required config via Auto Discovery.
keef
Post by keef »
jvdz wrote: Tuesday 12 March 2024 18:28
Yep wanted a clean start
jvdz wrote: Tuesday 12 March 2024 18:28 This is indeed all ZWAVEJS2MQTT stuff. As mentioned, you will have to get all devices properly list in ZJS2M first before Domoticz will get the required config via Auto Discovery.
I have put the devce and Zwave-JS-UI in inclusion mode (I even reset the device (to make sure it wasn't being stupid) but it just times out.
BartSr
Post by BartSr »
which pi and which zwave stick are used?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
keef
Post by keef »
It's a pi4 and a zwave.me USB Stick
BartSr
Post by BartSr »
did you use this stick before with OZW? Some sticks are not compatible with pi4.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
keef
Post by keef »
yes it was working before
BartSr
Post by BartSr »
some sticks allow including just with stick near zwavedevice iso via zwavejs-ui. Is that possible for you?
And do you disable ozw in domoticz? Otherwise stick cannot be used in zwavejs.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
keef
Post by keef »
I shall see if range is and issue.
No it is a fresh clean install
keef
Post by keef »
Nope range isn'the issue
BartSr
Post by BartSr »
did you unplug stick and include with stick near zwave device?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
