DZvents and security
remko2000
Re: DZvents and security
Post by remko2000 »
thanks for your explanation. Bright. I adjusted it and now I no longer have an error.
What strikes me is that this script is now triggered every second. This gives a lot of messages in my log. Is there any way to limit this traffic?
2024-02-25 11:46:18.098 Status: dzVents: Info: ------ Start internal script: testbeveil5: Security: "Disarmed", trigger: "Disarmed"
2024-02-25 11:46:18.117 Status: dzVents: Info: Security was triggered by Disarmed
2024-02-25 11:46:18.117 Status: dzVents: Info: ------ Finished testbeveil5
2024-02-25 11:46:18.118 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2024-02-25 11:46:18.440 Status: dzVents: Info: ------ Start internal script: testbeveil5: Security: "Disarmed", trigger: "Disarmed"
2024-02-25 11:46:18.460 Status: dzVents: Info: Security was triggered by Disarmed
2024-02-25 11:46:18.460 Status: dzVents: Info: ------ Finished testbeveil5
Kedi
Domoticz version: latest
Post by Kedi »
So there is still an error in your script. Just post your last working script.
remko2000
Post by remko2000 »
I'm sorry, this is:
        security = { domoticz.SECURITY_DISARMED, domoticz.SECURITY_ARMEDAWAY }
        if item.state == domoticz.SECURITY_ARMEDAWAY then
            domoticz.devices('Beveiliging buttonplus schakelen').switchOn()
            domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1r/ledrgb -m 8323072')
            domoticz.log('Security was triggered by ' .. item.trigger, domoticz.LOG_INFO)
        elseif item.state == domoticz.SECURITY_DISARMED then
            domoticz.devices('Beveiliging buttonplus schakelen').switchOff()
            domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1r/ledrgb -m 0')
Tukker
Domoticz version: 2023.2
Post by Tukker »
What if you change your elseif into an if?
The elseif is dependent from the prior if, a second if if's on it's own.
Bugs bug me.
The script seems OK now.
So there must be something else sending disarm signal to the Domoticz security panel. Do you have the Domoticz security panel open all the time somewhere? Some other test script still running?
Kedi
Post by Kedi »
I tested the script and it works fine.
This behavior is only possible if the button "Beveiliging buttonplus schakelen" triggers the security panel again.
You wrote that that button is a dummy. Is there a script that triggers on that dummy that switches the security panel?
Or is there a 'link' between the domoticz/out/buttonplus/wk1/button/1r/ledrgb topic and the security panel?
remko2000
Post by remko2000 »
After some research I understand. With the dummy I had 'on' and 'off' commands for my security panel (e.g. http://10.0.1.122:8080/json.htm?type=co ... ode=xxxxxx). I had set this up this way because I want to switch my security on or off from my button plus panel with 1 button (with the toggle of my dummy). In principle I could also overcome this in the script, but I suspect that with the current script my dummy only switches along, but I also want my security panel to switch along when I switch my dummy (via my plus button). So both ways. So I want to be able to switch my security with both my dummy and the security panel.
How could I supplement my script with this or should it be a separate script?
For simplicity's sake, I have removed switching the LED from the script
Kedi
Post by Kedi »
It should be something like this. I could not test it, I hope I did not make typos.
    	devices = { 'Beveiliging buttonplus schakelen' },
        if item.isSecurity then
        	    domoticz.devices('Beveiliging buttonplus schakelen').switchOn().silent()
	            domoticz.devices('Beveiliging buttonplus schakelen').switchOff().silent()
	 	if item.state == 'On' then
	 		domoticz.devices(<Security Panel Name>).armAway().silent()
	 		domoticz.devices(<Security Panel Name>).disarm().silent()
remko2000
Post by remko2000 »
Many thx, this works great. A little adjustment in the name 'security panel' and it works! This is my endscript:
	 		domoticz.devices('Security Panel').armAway().silent()
	 		domoticz.devices('Security Panel').disarm().silent()
