Re: zwavejs-ui - FAIL - how many of you did try & succeed?
Posted: Sunday 09 June 2024 22:11
I recognized the reponse of Tuinfluiter with a big smile.renerene wrote: Wednesday 14 February 2024 18:25 OpenZwave -> zwavejs-ui
Please tell me about your attempts. Just to get an idea of succes rate.
I think I had feeling this even more than twice.When I first read about the migration to Zwavejs-UI and read the instruction, I thought: I'm not going to do this.
The second time when I read it, I thought the same.
It did mean that I postponed it a few times and had to work up the courage to get started.
I recognize that several people had to overcome something. Especially because everything just worked.
My next thought was that this is definitely something that will turn off the novice hobbyist. In addition, you have to gather the information from different sources and the trick is to extract what applies to your situation and what not. I understand that it is all volunteer work, but the method to be followed is not crystal clear. You must be aware that not everyone has the same platform and therefore the working methods may differ.
For example, I wanted to install everything in my Ubuntu (virtual machine) without using Docker again under that.
All that makes it seem like something for advanced users.
At the end I just tried. I installed Domoticz with a copy of my database, MQTT and Zwave-js-ui one by one in a test environment and connected my Zwave stick to it.
Meanwhile the whole thing was further complicated by the fact that with the new version 7.2 of DSM on my Synology, the USB stick was only recognized by connecting it with an USB hub in between. (Has something to do with a solder point on old Gen 5 stick).
All this fiddling kept me busy for a few days. I can completely understand that many people would have already given up hope!
BUT through this experimenting and just doing, I got a better understanding how things work together.
At the end I have to say that it was easier than it seemed beforehand. Also I see that it is working very stable. At the moment only a few small things remaining, like batterylevel of Remotec scene master BW8510 that is visible in Devices, but not with dzVents.
