Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
JeeWee2 wrote: ↑Sunday 28 January 2024 10:37
Success finally!! Thanks willemd. It took at least 6 attempts (of which 3 complete fresh installs), but only the last one did not run into fatal errors during the very last 'make' command. This is what I have done:
A. installing the bullseye version without monitor (using the Raspberry Pi imager)
B. creating 2 GB swap space
C. installing Screen to avoid the abortion of commands by sudden dropdowns in SSH connection (but actually not used)
D. using the default options of the description
E. step by step execution of the commands
F. using 'gmake' instead of 'make'.
Don't know what did the trick, but point A. (i.e. without monitor) and F. were new.
I used a 4GB swap space because the wiki says "If your system has limited memory (Less then 4GB of memory), you (might) need to create a swap file for compilation."
Maybe that is why in my case the first attempt was succesfull. Don't know.
Anyway, good that it worked for you as well.
Just for the records:
Raspberry Pi Zero W was launched in February 2017 so it is not a 12 year old hardware. And still the best hardware to run a Domoticz server.
This was the first time I had tried using a PiZero after about 8 years of using Domoticz and I was so disappointed to see that it didn't work. I'd just got the zero out of a drawer thinking it would be perfect for monitoring my UPS and a couple of temperature sensors where the main Domoticz Pi is the other side of a solid wall so the sensors will not work and I can't justify spending £50+ for a Pi4/5 when I already have a pi zero sitting unused.
Running Domoticz and Dashticz beta on Raspberry Pi OS 32 bit - has anyone had success with 64 bit?
tarmacalastair wrote: ↑Wednesday 31 January 2024 17:48
I'm also using an RPI Zero W for my home server, as it consumes 5V 0.12A, and more than perfect to serve my ~20 sensor.
willemd wrote: ↑Monday 15 January 2024 19:49
Yes, don't close Putty and don't put your PC to sleep.
I have no clue about the error, not much info, but indeed, it is worth trying to remove previous left-overs and try again...
If really needed do it fully from scratch, but I would try moving backwards in steps.
What I did to not have to keep Putty open is put all the commands in a shell script e.g. step2.sh (chmod a+x to make it executable):
I tried to compile the 2023.3 version using the commands willemd posted on the 10th of January 2024, but after I run the command 'cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt' I constantly get the message that certain modules are missing. After I install them I get the message: could NOT find Boost. Now after running the installation of all the boost libs I get the error: 'Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u2) ...
Error: Timeout was reached'
I don't know how to solve a time-out error. Can anyone help me with this?
mvanrijnbach wrote: ↑Tuesday 26 March 2024 22:58
Best regards, Michiel.
Don't know how to solve these specifics, but wondering why your installation did not work: did you install a large enough swapspace and did you ensure your ssh session was not closed due to inactivity during the installation? Seems modules are missing maybe because of interrupted installation?
thanks for your reply. I did not create a swap space, I guess I might have to. I only have a few hundred MB space left after installing everything (total disk space 4.7 GB). I'm connecting through a VNC session and the ssh session is not closed during the make process. So I might have to create some swap space and I think I have to follow the procedure more closely as well.
how much disk space is needed for the boost-libraries? I had like 800 MB space, but during the tar command I run out of disk space. My disk is only 4.7 GB and most of the space is taken up by libraries. I have no idea how to free up more space.
By the way, I have a RPi Model B+ V1. Does anyone have a compiled version of Domoticz for this model. If I want to compile it from scratch I don't have enough disk space for the installation of the boost libraries.
That's not the best raspberry pi out there.
This one is known for causing corruptions with the sd card.
Best to get yourself a V3 or better (or an oDroid)
Hi Gizmocuz,
yeah, it's an older RPi, but I never had any problems with it. Domoticz has been running without issues for years. However, I think the memory/disk space is too small to compile Domoticz.
