Page 2 of 6
Re: ShellyTeacher for Domoticz
Posted: Thursday 30 November 2023 2:33
by MikeyMan
Having issues with the plugin, so I thought I'd give this one a try. Rather user unfriendly for non programmers it seems. Too much config outside of domoticz. Hope this improves.
Also getting an error while installing:
pi@raspberrypi:~/domoticz/plugins $ sudo apt install python3-pip git
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
git is already the newest version (1:2.30.2-1+deb11u2).
python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~/domoticz/plugins $ sudo pip3 install paho-mqtt --break-system-packages
  File "/usr/local/bin/pip3", line 5, in <module>
    from pip._internal.cli.main import main
ImportError: No module named pip._internal.cli.main
Any thoughts?
Posted: Thursday 30 November 2023 19:48
by lwolf
MikeyMan wrote: Thursday 30 November 2023 2:33 Having issues with the plugin, so I thought I'd give this one a try. Rather user unfriendly for non programmers it seems. Too much config outside of domoticz. Hope this improves.
It is not a plugin. It is a helper application for simple beings who dont want to send config templates manually to integrate their Shelly devices to MQTT-AD.
There is a Windows version for non programmers. Do you see the video about usage?
MikeyMan wrote: Thursday 30 November 2023 2:33 Also getting an error while installing:
Of course, it is for Debian12 based systems:
For other systems, normal pip command will work:
Posted: Friday 01 December 2023 11:33
by MikeyMan
lwolf wrote: Thursday 30 November 2023 19:48
For this simple being, it's still a bit too much it seems.
My domoticz install is on a pi. I was happy using the plugin, since it was working rather okay. Until recently.
This results in the same error:
pi@raspberrypi:~/domoticz/plugins/shellyteacher4domo $ sudo pip3 install paho-mqtt
Could be user related for Pi.
Posted: Friday 01 December 2023 17:40
by lwolf
MikeyMan wrote: Friday 01 December 2023 11:33
lwolf wrote: Thursday 30 November 2023 19:48 There is a Windows version for non programmers. Do you see the video about usage?
There is no need to run the ShellyTeacher on the same device, where Domoticz installed. There is only one condition: the ShellyTeacher have to see the MQTT broker IP address and of course to access the broker port which is 1883 default.
So it can be run on on a Windows device once, and register all Shelly devices to the MQTT broker in retain mode. There is no need to run it again, until you buy a new Shelly device.
MikeyMan wrote: Friday 01 December 2023 11:33 This results in the same error:
Its not really ShellyTeacher related. Your pip3 is simply broken. Reinstall pip or let it go.
https://www.google.com/search?channel=f ... l.cli.main+
Posted: Friday 01 December 2023 19:45
by Jonkheer
lwolf wrote: Wednesday 29 November 2023 17:42 All right, waiting for the MQTT debugging data!
I can't see strange behavior...only the ammount of publications for the specific device.
I've done a factory reset and installed the device again. Everything in that process goes fine. After installing in Domoticz it's status is directly -1%.
	Line 42523: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0', ... (4 bytes))
	Line 42524: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/pos', ... (2 bytes))
	Line 42525: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/pos', ... (2 bytes))
	Line 42526: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/stop_reason', ... (6 bytes))
	Line 42527: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/stop_reason', ... (6 bytes))
	Line 42528: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/power', ... (4 bytes))
	Line 42529: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/power', ... (4 bytes))
	Line 42530: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/relay/power', ... (4 bytes))
	Line 42531: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/relay/power', ... (4 bytes))
	Line 42532: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/energy', ... (3 bytes))
	Line 42533: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/roller/0/energy', ... (3 bytes))
	Line 42534: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/relay/energy', ... (3 bytes))
	Line 42535: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/relay/energy', ... (3 bytes))
	Line 42536: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/input/1', ... (1 bytes))
	Line 42537: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/input/1', ... (1 bytes))
	Line 42538: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/input/0', ... (1 bytes))
	Line 42539: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/input/0', ... (1 bytes))
	Line 42540: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature', ... (5 bytes))
	Line 42541: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature', ... (5 bytes))
	Line 42542: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature_f', ... (6 bytes))
	Line 42543: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature_f', ... (6 bytes))
	Line 42544: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/overtemperature', ... (1 bytes))
	Line 42545: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/overtemperature', ... (1 bytes))
	Line 42546: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature_status', ... (6 bytes))
	Line 42547: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/temperature_status', ... (6 bytes))
	Line 42548: 1701454936: Received PUBLISH from shellyswitch25-C45BBE6C403E (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/voltage', ... (6 bytes))
	Line 42549: 1701454936: Sending PUBLISH to Domoticz-MQTT-AutoDiscover739c7e16-5fe2-4428-bf18-38517b6ec0b09 (d0, q0, r0, m0, 'shellies/shellyswitch25-C45BBE6C403E/voltage', ... (6 bytes))
I've found out that the Shelly device has also difficulties with the callibration proces. Although the shutters work fine with the Shellt GUI. Callibartion is not possible. I think there's a link. But I don't underdstand why it does not send a command for opening or closing via Domoticz.
Posted: Saturday 02 December 2023 8:52
by lwolf
Jonkheer wrote: Friday 01 December 2023 19:45
Please use an MQTT client like MQTT Explorer to get MQTT data.
Show me configuration object from this MQTT path:
homeassistant/cover/shellyswitch25-C45BBE6C403E-roller-0/config
If the device is not calibrated, it wont work with the default config object, as Domoticz uses position method, if it is described in the config object. I can assemble a barely open/close capable for you if you wish - without positioning.
Your device published
what is the data for that?
Posted: Sunday 03 December 2023 9:50
by Jonkheer
lwolf wrote: Saturday 02 December 2023 8:52 Please use an MQTT client like MQTT Explorer to get MQTT data.
"name": "shellyswitch25-C45BBE6C403E Roller 0",
"cmd_t": "~roller/0/command",
"stat_t": "~roller/0",
"pos_t": "~roller/0/pos",
"set_pos_t": "~roller/0/command/pos",
"avty_t": "~online",
"pl_avail": "true",
"pl_not_avail": "false",
"json_attr_t": "~info",
"pl_open": "open",
"pl_cls": "close",
"pl_stop": "stop",
"stat_opening":
"open", "stat_closing":
"close", "pos_open": 100,
"pos_clsd": 0,
"uniq_id": "shellyswitch25-C45BBE6C403E-roller-0",
"qos": 1,
"~": "shellies/shellyswitch25-C45BBE6C403E/"
I think (hope) this is wat you asked for?
lwolf wrote: Saturday 02 December 2023 8:52 If the device is not calibrated, it wont work with the default config object, as Domoticz uses position method, if it is described in the config object. I can assemble a barely open/close capable for you if you wish - without positioning.
It's strange behavior from the device and I didn't noticed before. When i installed it a had it calibrated. So if you can help we with a work around...that is much appreciated!
Posted: Sunday 03 December 2023 11:55
by lwolf
Jonkheer wrote: Sunday 03 December 2023 9:50
"pl_avail": "true",
"pl_open": "open",
"pl_cls": "close",
"pl_stop": "stop",
"stat_opening":
"pos_clsd": 0,
"qos": 1,
Yes, thank you. It seems that your config object is fine.
Jonkheer wrote: Sunday 03 December 2023 9:50 It's strange behavior from the device and I didn't noticed before. When i installed it a had it calibrated. So if you can help we with a work around...that is much appreciated!
According to Shelly docs:
/roller/0/pos reports the current position in percent, -1 if invalid
I think this is your current situation.
You can add the following two line into mqtt_templates.txt under "[SHSW-21-roller][SHSW-25-roller]"
topic=%discovery_prefix%/cover/%shelly_id%-roller-0-basic/config
payload={"name": "%shelly_id% Roller 0 Basic", "cmd_t": "~roller/0/command", "stat_t": "~roller/0", "avty_t": "~online", "pl_avail": "true", "pl_not_avail": "false", "pl_open": "open", "pl_cls": "close", "pl_stop": "stop", "state_opening": "open", "state_closing": "close", "state_stopped": "stop", "uniq_id": "%shelly_id%-roller-0-basic", "qos": 1, "~": "shellies/%shelly_id%/"}
I hope it will work, i removed every position-aware property from it. You need to teach again the non-working Shelly device, after adding this line, of course.
Posted: Sunday 03 December 2023 14:00
by Jonkheer
Thanks Iwolf!,
I will add the lines to the config. But I do think there's an issue with the devive. There is still waranty on it, so I also made a ticket at Shelly.com.
I'll inform if the extra lines makes any difference.
8-)
Posted: Monday 04 December 2023 19:10
by lwolf
Jonkheer wrote: Sunday 03 December 2023 14:00 Thanks Iwolf!,
8-)
I am testing the template, but i think it will not work, as Shelly roller do not reply if it is in fully opened or fully closed state, it can only be gathered from position topic. And if position -1 nothing will work.
Although i can add a Selector Switch (disabled by default) which can be used to control stop/close/open state and it will get the actual state from Shelly 2.5.
topic=%discovery_prefix%/select/%shelly_id%/cover-control/config
payload={"name": "%shelly_id% Cover Control", "~": "shellies/%shelly_id%/", "uniq_id": "%shelly_id%-0-covercontrol", "enabled_by_default": false, "cmd_t": "~roller/0/command", "stat_t": "~roller/0", "avty_t": "~online", "pl_avail": "true", "pl_not_avail": "false","stat_cla": "selector" , "ops":["stop","close","open"] }
Cover Control selector added at today commit.
Posted: Tuesday 05 December 2023 14:34
by MikeyMan
So, please forgive my multitude of stupid questions... But i'm trying to ease into this, to see if it fixes some issues i have with the python plugin.
Here goes:
- What does the teacher actually do? Does it send data through to Domoticz? Or just alters the MQTT messages in the broker?
- What is the difference between AutoMQTT and using this feature?
- Can i run the old stuff and the new stuff in parallel? If so; do i need to point the MQTT devices to a new prefix?
- If i want to switch over a device from python to teacher, what are the steps?
Posted: Tuesday 05 December 2023 16:02
by Xavier82
Posted: Tuesday 05 December 2023 16:58
by MikeyMan
Xavier82 wrote: Tuesday 05 December 2023 16:02 @MikeyMan: Check this topic:
viewtopic.php?t=25656&hilit=shellyteacher&start=500
Maybe I'm missing something. But I don't see an answer tot any of my earlier questions there.
Posted: Tuesday 05 December 2023 18:50
by waltervl
MikeyMan wrote: Tuesday 05 December 2023 14:34 So, please forgive my multitude of stupid questions... But i'm trying to ease into this, to see if it fixes some issues i have with the python plugin.
Here goes:
See https://github.com/enesbcs/shellyteacher4domo
What it does is making MQTT Auto discover config topics for your Shelly devices so that Domoticz can understand what the devices are sending over MQTT. Those MQTT config topics are retained by the MQTT broker so after a reboot of Domoticz it will reuse them.
No you cannot use plugin and teacher. It is stated in the readme.
Steps are the same as with any other switch from one environment to another. See for example Zwave-JS-UI and Zigbee2MQTT Domoticz wiki pages
Posted: Tuesday 05 December 2023 19:01
by lwolf
It will fix python plugin issues, as its not a python plugin. Domoticz MQTT Autodiscovery hardware is written in C and is part of the Domoticz default build. This is behind the whole idea. Python plugins has a tendency to use all memory and cause Domoticz to crash.
MikeyMan wrote: Tuesday 05 December 2023 14:34 Here goes:
Shelly devices speak MQTT but has NO autodiscovery function by factory.
So if ShellyTeacher app founds a supported Shelly device online, it sends the correct configuration object to the MQTT broker, which is necessary for the Discovery process, without this information the MQTT-AD hardware unable to do anything.
After teaching the devices to Domoticz MQTT-AD controller do the rest, the Teacher is not necessary to operate the devices, as configuration object sent in 'retain' mode, and if the MQTT broker operates well, its saved into its database.
MikeyMan wrote: Tuesday 05 December 2023 14:34 - What is the difference between AutoMQTT and using this feature?
I do not understand your question. What is the difference between the butter and bread?
Butter needs to be spread onto bread, and ShellyTeacher sends configuration object to Domoticz MQTT Autodiscovery hardware.
MikeyMan wrote: Tuesday 05 December 2023 14:34 - Can i run the old stuff and the new stuff in parallel? If so; do i need to point the MQTT devices to a new prefix?
In fact you can run them paralell. If you disable Gen1 checkbox before ShellyTeacher teaching process, it will only find Gen2 devices, and there wont be duplications.
Otherwise, Gen1 devices will appear under the new hardware and will exists under the old hardware also, which is not a good idea.
(If you change the prefix, old ShellyMQTT plugin will not work, as it is not prepared for this - its almost the same if you just delete the ShellyMQTT plugin)
MikeyMan wrote: Tuesday 05 December 2023 14:34 - If i want to switch over a device from python to teacher, what are the steps?
I just renamed new devices to their old names. Maybe others have better ideas, somewhere i saw a topic for zigbee2mqtt which also supports Autodiscovery and that is the proposed hardware also.
Posted: Tuesday 05 December 2023 19:03
by waltervl
For replacing old Domoticz device by new to keep the history of old device you can use the device replace function under the edit button.
Posted: Tuesday 05 December 2023 19:45
by MikeyMan
lwolf wrote: Tuesday 05 December 2023 19:01
Point is; that with the plugin i suddenly have an issue with a PlusHT. Was trying to check if this issue remained with the autodiscovery function
Thanks, very enlightening.
with the above explanation this makes sense :)
for testing purposes, i would be okay with the double devices for now. :)
I have been testing with a PlusHT. This was already in use in my MQTT server.
Restarting etc doesnt seem to make it discoverable. Tried to delete all retained topics as well, but no luck yet.
Posted: Tuesday 05 December 2023 19:59
by MikeyMan
Settings seem to be okay
Schermafbeelding 2023-12-05 195823.png (66.59 KiB) Viewed 13552 times
Schermafbeelding 2023-12-05 195910.png (40.72 KiB) Viewed 13552 times
Posted: Wednesday 06 December 2023 18:33
by lwolf
MikeyMan wrote: Tuesday 05 December 2023 19:59 Settings seem to be okay
The default Gen2 prefix has no "shellies/" in it. ShellyTeacher subscribes to "+/online" topic where it awaits basic announcements. + is a wildcard meaning exactly one level deep with any name.
Updated ShellyTeacher 0.6 is available on github.
https://github.com/enesbcs/shellyteache ... s/tag/0.06
Posted: Thursday 21 December 2023 0:08
by azeph
Hi, I have a Shelly Plus Plus S to measure power and energy. I use the ShellyTeacher results for Domoticz for some days now for this device. I really like ithis. I have a question: With the ShellyTeacher for Domoticz the graph of the energy shows up as an incremental line graph (see the attachment). I also have the Wi-Fi Energy Socket of HomeWizard (which is also a power meter) and for that I use the eraser3/HomeWizard-Wifi-Energy-Socket plugin to show the graphs in Domoticz. This plugin shows the power and energy as a non-incremental line graph and a column graph respectively. This I find more informative and easy to interpret (see the other attachment). Would it be possible to show the graphs from ShellyTeacher for Domoticz in the way that it is displayed with the Eraser3/HomeWizard-Wifi-Energy-Socket plugin? If that would be possible, it would be great!
