New software Nodoshop OTGW
BartSr
Domoticz version: V2024.7
Re: New software Nodoshop OTGW
Post by BartSr »
@PieterS
As fas as I understand it's a feature. So .5 will remain available.
I think the reason for resolution of 1 is because some thermostats (like my Honeywell Touch) don't handle resolution .5 right. OTGW don't see such a value.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
PieterS
Domoticz version: 2024.7
Post by PieterS »
Oh, happy to read its an option. It seems a bit outdated to me. Especially in modern well isolated house.
Synology with Domoticz build (V2024.7) in Docker
PieterS wrote: Friday 27 October 2023 14:36
In Domoticz Beta you can now set a thermostat so that it sets only in steps of 1 degree from 22 directly to 23 (and 24, 25 etc) so you cannot make false settings anymore....
@waltervl: not glad to read about such a resolution of one degree. :evil:
This seems to go back into the past. :roll:
Will there be a setting to choose .5 degree in the software?
And what do you mean with false settings?
It is better now!! Did you check the wiki? You can set the step of a domoticz thermostat device to whatever you like. 0.01, 0.1, 0.5, 1, 2, 5, 10 etc. You can also use it not only for temperature but for every required Unit of measure (C, F, m, cm, bar, lux, etcetera).
So it is not back in the past but up to the future!
With false setting I mean that you now can set eg 22.5 degrees but some OTGW connect thermostats cannot handle this as it can only handle integers (22 or 23)
PieterS
Post by PieterS »
No I didn't check the Wiki till you said me to do that.
But that is indeed a nice feature. Looking forward allthough the functionality will do for me now.
