Re: Zigbee for domoticz error
Posted: Friday 13 October 2023 12:21
please update to the most recent Z4D version ...
If you can provide pairing logs and export.json that would be greatjacobsentertainment wrote:Seems to be working fine, yesterday I noticed that an sonoff snzb-03 (motion/pir) was mistaken for a humidity/temperature sensor. deleted it and tried again and came back up again as an hum/temp sensor. Ill try again tonight.
I did update to most recent version.
2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04
2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration)
2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01
2023-10-27 16:55:38.662 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify)
2023-10-27 16:55:40.944 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402
2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic)
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify)
2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone)
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration)
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01
2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify)
2023-10-27 16:55:42.085 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Model Name: 66666
2023-10-27 16:55:42.091 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Manufacturer Name: eWeLink
2023-10-27 16:55:42.102 Status: zigbee: [ MainThread 19363] [None] NEW OBJECT: 87e4 Request Node Descriptor
2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0
2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informations
2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0
2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informationsCode: Select all
Allemaal
Status
Probleem
Filter: X
2023-10-27 17:01:41.443 Status: zigbee: [ZigpyForwarder_22 19574] [None] NEW OBJECT: 55a9 None
2023-10-27 17:01:42.908 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Active Endpoint Response Ep: 01 LQI: 144
2023-10-27 17:01:42.911 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Request Simple Descriptor for Ep: 01
2023-10-27 17:01:45.588 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ProfileID 0104
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ZDeviceID 0402
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Application Version 0000
2023-10-27 17:01:45.589 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster IN Count: 04
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 1: 0000 (Basic)
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 2: 0003 (Identify)
2023-10-27 17:01:45.590 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 3: 0500 (IAS Zone)
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 4: 0001 (Power Configuration)
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster OUT Count: 01
2023-10-27 17:01:45.591 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster Out 1: 0003 (Identify)
2023-10-27 17:01:47.073 Status: zigbee: [ MainThread 19363] [None] NEW OBJECT: 55a9 Request Node Descriptor
2023-10-27 17:01:47.992 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Simple Descriptor Response EP: 0x01 LQI: 144
2023-10-27 17:01:47.992 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ProfileID 0104
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 ZDeviceID 0402
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Application Version 0000
2023-10-27 17:01:47.993 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster IN Count: 04
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 1: 0000 (Basic)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 2: 0003 (Identify)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 3: 0500 (IAS Zone)
2023-10-27 17:01:47.994 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster In 4: 0001 (Power Configuration)
2023-10-27 17:01:47.995 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster OUT Count: 01
2023-10-27 17:01:47.995 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 55a9 Cluster Out 1: 0003 (Identify)
2023-10-27 17:01:52.087 Status: zigbee: [ MainThread 19363] [2] NEW OBJECT: 55a9 Model Name: MS01
2023-10-27 17:01:52.088 Status: zigbee: [ MainThread 19363] [2] NEW OBJECT: 55a9 Manufacturer Name: eWeLink It looks like the Model 66666 can be a Temp/Humi as well as a Motionjacobsentertainment wrote: Friday 27 October 2023 16:59 This is from the domoticz logCode: Select all
2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144 2023-10-27 16:55:38.659 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104 2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402 2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000 2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04 2023-10-27 16:55:38.660 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic) 2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify) 2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone) 2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration) 2023-10-27 16:55:38.661 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01 2023-10-27 16:55:38.662 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify) 2023-10-27 16:55:40.944 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Simple Descriptor Response EP: 0x01 LQI: 144 2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ProfileID 0104 2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 ZDeviceID 0402 2023-10-27 16:55:40.945 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Application Version 0000 2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster IN Count: 04 2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 1: 0000 (Basic) 2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 2: 0003 (Identify) 2023-10-27 16:55:40.946 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 3: 0500 (IAS Zone) 2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster In 4: 0001 (Power Configuration) 2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster OUT Count: 01 2023-10-27 16:55:40.947 Status: zigbee: [ZigpyForwarder_22 19574] [-] NEW OBJECT: 87e4 Cluster Out 1: 0003 (Identify) 2023-10-27 16:55:42.085 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Model Name: 66666 2023-10-27 16:55:42.091 Status: zigbee: [ MainThread 19363] [1] NEW OBJECT: 87e4 Manufacturer Name: eWeLink 2023-10-27 16:55:42.102 Status: zigbee: [ MainThread 19363] [None] NEW OBJECT: 87e4 Request Node Descriptor 2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0 2023-10-27 16:55:46.530 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informations 2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) sent a Leave indication and will be outside of the network. LQI: 0 2023-10-27 16:55:46.540 Status: zigbee: [ZigpyForwarder_22 19574] (87e4/00124b002247e662) cleanup key plugin data informations
git pull
git checkout fix-sonoff-firmware-model
sudo python3 -m pip install -r requirements.txt --upgrade
How do I get this datapipiche wrote: Tuesday 31 October 2023 8:13 I would need an export.json plugin raw devices information. so I can understand what is wrong with battery
Version: "3"
ZDeviceName: "Pir terras"
Status: "inDB"
SQN: "6d"
Ep:
01:
1000: Object {}
0000: Object {"4000":"2.0.022","0004":"IKEA of Sweden","0005":"TRADFRI motion sensor","0000":3,"0001":32,"0002":98,"0003":1,"0007":3,"000a":"E1745"}
0001: Object {"0021":11}
0003: Object {}
0009: Object {}
0b05: Object {}
0004: Object {}
0006: Object {"0000":"Cmd: 42, 02"}
0019: Object {}
Type: "Motion"
ClusterType: Object {"616":"Motion"}
Heartbeat: "1568"
RIA: "1"
LQI: 100
Battery: 11
Model: "TRADFRI motion sensor"
ForceAckCommands: Array[0] []
MacCapa: "80"
IEEE: "5c0272fffe8a987d"
Type: "Motion"
ProfileID: "0104"
ZDeviceID: "0850"
App Version: 32
Attributes List: Object {}
DeviceType: "RFD"
HW Version: 1
Last Cmds: Array[0] []
LogicalType: "End Device"
Manufacturer: "117c"
Manufacturer Name: "IKEA of Sweden"
NbEp: "1"
PowerSource: "Battery"
ReadAttributes:
Ep:
01:
0001:
TimeStamp: "28/10/2023 00:11:08"
iSQN: Object {"0021":"32"}
Attributes: Object {}
ZigateRequest: Object {}
0006:
iSQN: Object {"4000":"33","4001":"33","4002":"34","4003":"34","0000":"33","fffd":"34","fffe":"35"}
0000:
iSQN: Object {"4000":"38","0000":"36","0001":"36","0002":"36","0003":"37","0004":"37","0005":"37","0007":"38","000a":"38"}
ReceiveOnIdle: ""
Stack Version: 98
Stamp: Object {"time":1698774674.1152956,"Time":"2023-10-31 18:51:14","MsgType":"8011","LastSeen":"31/10/2023 18:51:14"}
ZCL Version: 3
Health: "Live"
CertifiedDevice: true
Max Tx: "0052"
bitfield: "4002"
Epv2: Object {"01":{"ProfileID":"0104","ZDeviceID":"0850","ClusterIn":{"1000":{},"0000":{},"0001":{},"0003":{},"0009":{},"0020":{},"fc7c":{}},"ClusterOut":{"1000":{},"0003":{},"0004":{},"0006":{},"0008":{},"0019":{}}}}
_rawNodeDescriptor: "117c005200522c000080524002"
Max Rx: "0052"
server_mask: "2c00"
BindingTable: Array[4] [{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:03:11","Time":"27/10/2023 19:03:11"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:28:11","Time":"27/10/2023 19:28:11"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"27/10/2023 19:38:12","Time":"27/10/2023 19:38:12"},{"Devices":[],"SQN":0,"Status":"","TimeStamp":"28/10/2023 00:11:08","Time":"28/10/2023 00:11:08"}]
OTAClient: Object {"ManufacturerCode":"117c","ImageType":"11c8","CurrentImageVersion":"20022623"}
Max Buffer Size: "52"
descriptor_capability: "00"
Param: Object {}
ConfigSource: "DeviceConf"
macapa: "80"
Capability: Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
BatteryUpdateTime: "27/10/2023 18:55:16"
WriteAttributes:
Ep: Object {"01":{"1000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0009":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0b05":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}
ConsistencyCheck: "ok"
ZCL-IN-SQN:
0019: "6d"
0006: "6b"
RollingLQI: Array[11] [104,104,104,100,100,100,100,100,100,100,100]
ZCLSQN: "08"
MapLQI:
d966: 129
NwkID: "b519"Code: Select all
3:
Version: "3"
ZDeviceName: "rookmelder overloop"
Status: "inDB"
SQN: "00"
Ep: Object {"01":{"0000":{"0004":"Heiman","0005":"SMOK_YDLV10","0003":1,"0006":"20150330","0007":3,"0010":"","0011":0,"0012":"01","0013":0},"0001":{"0000":0,"0001":0,"0010":0,"0011":0,"0012":65535,"0013":0,"0020":30,"0021":200,"0030":"","0031":255,"0032":0,"0033":0,"0034":30,"0035":1,"0036":25,"0037":0,"0038":0,"0039":0,"003a":40,"003b":0,"003c":0,"003d":0,"003e":"00000000"},"0003":{},"0009":{},"0019":{},"0500":{"0010":"e0798dfffec7b5a1","0000":"01","0001":"0028","0002":"alarm1: 1, alarm2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 1, trouble: 0, acmain: 0, test: 0, battdef: 0"},"0502":{"0000":"240"},"Type":"Smoke","ClusterType":{"605":"Smoke"}}}
Heartbeat: "33950"
RIA: "3"
LQI: 120
Battery: 200
Model: "SMOK_YDLV10"
MacCapa: "84"
IEEE: "005043c903356c2f"
Type: "Smoke"
ProfileID: "0104"
ZDeviceID: "0402"
App Version: ""
DeviceType: "RFD"
HW Version: 1
Manufacturer: "120b"
Manufacturer Name: "Heiman"
NbEp: "1"
PowerSource: "Main"
ReadAttributes: Object {"Ep":{"01":{"0000":{"TimeStamp":"08/10/2023 20:25:18","iSQN":{"4000":"1f","8000":"1f","0000":"00","0001":"18","0002":"18","0003":"19","0004":"19","0005":"19","0006":"1a","0007":"1a","0008":"1a","0009":"1b","000a":"1b","000b":"1b","000c":"1c","000d":"1c","000e":"1c","0010":"1d","0011":"1d","0012":"1d","0013":"1e","0014":"1e","0015":"1e","fffd":"1f","fffe":"20","ffdf":"20","ffe0":"20","ffe1":"21","ffe2":"21","ffe4":"21"},"Attributes":{"8000":"86","0009":"86","000c":"86","0014":"86","fffe":"86","ffe1":"86"},"ZigateRequest":{}},"0500":{"TimeStamp":"08/10/2023 20:24:37","iSQN":{},"Attributes":{"0010":"00","0000":"00","0001":"00","0002":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"09","0001":"09","0010":"09","0011":"0a","0012":"0a","0013":"0a","0020":"0b","0021":"0b","0030":"0b","0031":"0c","0032":"0c","0033":"0c","0034":"0d","0035":"0d","0036":"0d","0037":"0e","0038":"0e","0039":"0e","003a":"0f","003b":"0f","003c":"0f","003d":"10","003e":"10","fffd":"10","fffe":"11"},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"12","0001":"12","0002":"12","0003":"13","0004":"13","0005":"13","0006":"14","0007":"14","0008":"14","0009":"15","000a":"15","fffd":"15","fffe":"16"},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":"08/10/2023 20:25:04","iSQN":{"0000":"17"},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle: ""
Stack Version: ""
Stamp: Object {"time":1696789861.5398967,"Time":"2023-10-08 20:31:01","MsgType":"8401","LastSeen":"08/10/2023 20:31:01","LastPing":1698684654}
ZCL Version: ""
Health: "Not Reachable"
ReadConfigureReporting: Object {}
IAS: Object {"Auto-Enrollment":{"Status":"Enrolled","Ep":{"01":{"Status":"Enrolled","ZoneId":"00"}}},"01":{"EnrolledStatus":1,"ZoneType":40,"ZoneTypeName":"fire","ZoneStatus":{"alarm1":0,"alarm2":0,"tamper":0,"battery":0,"Support Reporting":0,"Restore Reporting":1,"trouble":0,"acmain":0,"test":0,"battdef":0,"doorbell":0,"GlobalInfos":"0;0;0;0;0;1;0;0;0;0;0","TimeStamp":"08/10/2023 20:24:29"}}}
Max Tx: "0000"
IASBattery: 100
SWBUILD_1: "20150330"
bitfield: "4002"
Epv2: Object {"01":{"ProfileID":"0104","ZDeviceID":"0402","ClusterIn":{"0000":{},"0003":{},"0500":{},"0001":{},"0009":{},"0502":{}},"ClusterOut":{"0019":{}}}}
_rawNodeDescriptor: "bbaa0000000000000384404002"
Bind: Object {"01":{"0500":{"Target":"0000","Stamp":"08/10/2023 20:24:32","Phase":"binded","Status":"00","i_sqn":"03"}}}
Max Rx: "0000"
ConfigureReporting: Object {"Ep":{"01":{"0500":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"06","0001":"06","0002":"06"},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"07"},"Attributes":{"0000":"8c"},"ZigateRequest":{}},"0001":{"TimeStamp":"08/10/2023 20:24:35","iSQN":{"0000":"08","0020":"08","0021":"08"},"Attributes":{"0000":"8c","0020":"8c","0021":"8d"},"ZigateRequest":{}}}}}
server_mask: "0000"
BindingTable: Object {"SQN":0,"Status":"Success","TimeStamp":"08/10/2023 20:24:40","BindingTableSize":1,"Devices":[{"005043c903356c2f":{"sourceEp":"01","Cluster":"0500","targetIEEE":"e0798dfffec7b5a1","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]}
Max Buffer Size: "40"
descriptor_capability: "03"
Param: Object {}
macapa: "84"
Capability: Array[4] ["Reduced-Function Device","Main Powered","Standard security","NwkAddr should be allocated"]
BatteryUpdateTime: "08/10/2023 20:24:47"
WriteAttributes: Object {"Ep":{"01":{"0500":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0009":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0502":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
ZCLSQN: "00"
pingDeviceRetry: Object {"Retry":0,"TimeStamp":"30/10/2023 17:50:59"}
NwkID: "e3ff"
