I've started some work with the 2CH module
PLease make sure to be on hotfix-stable7-7.1.004 and with [2.100] at minimum
I'll do some investigation tomorrow and during the week, will keep you posted
2gang Girier dimmer switch problem in Zigbee4Domoticz Topic is solved
Re: 2gang Girier dimmer switch problem in Zigbee4Domoticz
can you kindly switch to the hotfix-stable7-7.1.004 branch ?olleman wrote: Wednesday 09 August 2023 21:34 Just a quick question. It says on Aliexpress that this device should be Zigbee 3.0 compatible but as I read from the notes of version 7 of the plugin all zigbee 3.0 devices are compatible with the plugin. Does this mean that the device really isn't Zigbee 3.0?
git pull
git checkout hotfix-stable7-7.1.004
sudo python3 -m pip install -r requirements.txt --upgrade
and let me know if the behaviour is better ?
olleman
Sorry for not getting back to you sooner l, had notifications turned off. I really appreciate your work and I'll get back to you next week since I'm backed up this weekend.pipiche wrote: Tuesday 05 September 2023 19:39can you kindly switch to the hotfix-stable7-7.1.004 branch ?olleman wrote: Wednesday 09 August 2023 21:34 Just a quick question. It says on Aliexpress that this device should be Zigbee 3.0 compatible but as I read from the notes of version 7 of the plugin all zigbee 3.0 devices are compatible with the plugin. Does this mean that the device really isn't Zigbee 3.0?
restart the pluginCode: Select all
git pull git checkout hotfix-stable7-7.1.004 sudo python3 -m pip install -r requirements.txt --upgrade
olleman
Hello!pipiche wrote: Tuesday 05 September 2023 19:39can you kindly switch to the hotfix-stable7-7.1.004 branch ?olleman wrote: Wednesday 09 August 2023 21:34 Just a quick question. It says on Aliexpress that this device should be Zigbee 3.0 compatible but as I read from the notes of version 7 of the plugin all zigbee 3.0 devices are compatible with the plugin. Does this mean that the device really isn't Zigbee 3.0?
I finally got around to testing it and it seems to work just fine now, I didn't even have to re-add the light switch in Domoticz
Thanks for the feedback
