documentation Alfen Eve charger ? Topic is solved
- athoopen
- Domoticz version: 2026.2
Re: documentation Alfen Eve charger ?
Got it. Is there a way to get more debug info out of the plugin? I already enabled info & status & problem.
Cheers,
Arjan
Rp3 Using : RFXCom, LaCrosse, KNMI, Remeha, TinyTuya, zigbee and a few others
Arjan
willemd
- Domoticz version: 2026.3
I am not aware of any possibility to get more info.athoopen wrote: Sunday 01 February 2026 12:44 Got it. Is there a way to get more debug info out of the plugin? I already enabled info & status & problem.
Did you use username "admin" and the correct password? Did you check unused devices as well?
Did you reset your Alfen to make sure there are no existing connections?
- athoopen
You are lifesaver!
I used the ace... username as I stated before. I did try admin and that only gave me lots of login errors. I have now used admiin again, and the devices get created. Must have used a wrong password previously
Really sorry to bother you all.
Thanks for helping me out !
Cheers,
Arjan
Arjan
Do you need a load balancing licence to control the max current? After updating the firmware to 6.6.2 my Alfen flashes blue and loading does not start. Maybe it is because in the new firmware a load balancing license is needed?
plenkske
I have a suggestion for an extra device from the Alfen charger: maximum number of phases. This is helpfull for solar charging. With 1 phase it can start from 1.4 kW. And if you want to charge faster you can easily switch back to 3 phase.
In the code I saw:
'312E_0': 'OD_mainMaxNrPhases1',
And I know its possible in home assistant.
Could someone add this ?
If I want to add it myself, I need to build domoticz myself aswell right ?
In the Ace installer its possible to change this. And after that the charger needs a reboot.
In the code I saw:
