Re: [HOW TO] Install Domoticz on Odroid C4 (testcase)
Posted: Thursday 12 January 2023 0:21
Thanks for documenting this Odroid install, it has been some work I seeDidi wrote: Wednesday 11 January 2023 22:47Lots of things where not working at all or Domoticz did not responded to json calls, http(s) calls, Log rotate did not worked, plugin installations where not going as explained in the Domoticz Wiki and so on.waltervl wrote: Wednesday 11 January 2023 21:39 And what went wrong when running Domoticz on Ubuntu on Odroid C4?
Because i had a few days of time over, i tried as much possibility's as possible to find a way, most users, would like. Also i tried to keep it documented as much as possible as you can see in my response. I did not noted all, due to the solution was more important.![]()
It is still strange that on Ubuntu you had so many issues as I run Ubuntu on a X86 and do not experience it. There could be some missing modules and pre installed applications like python but basically the wiki instructions should work on any Ubuntu. But as I do not have an Odroid I cannot check
