How to set a device on for 5 minutes and then off for 5 minutes
Dave21w
- Domoticz version: Stable
Re: How to set a device on for 5 minutes and then off for 5 minutes
look at the topic I posted above, thats done in blockly and as soon as the virtual switch is off the toggled device switches off as well
willemd
- Domoticz version: 2024.1
yes, the "else" part will be executed whenever item is not a timer (never happens in this script) or when the virtual device is inactive, or both.hemant5400z wrote: Thursday 08 December 2022 14:54returnwaltervl wrote: Thursday 08 December 2022 14:23 Please post your working script else it will be difficult to advise.
on ={ timer = {'every 1 minutes',}
execute = function(dz,item)
if item.isTimer and dz.devices('Virtual').active then
dz.devices('Sonoff').toggleSwitch()
Above is working and toggles on/off, what I want is a failsafe so if Virtual is Off, while the Sonoff is still on (triggered), it should go Off, currently it stays on infinite.
So indeed need an Else statement with: if item.isTimer and dz.devices('Virtual').active-not-active then
Hemant
By the way: I always find it much easier on the mind to use switchOn() and switchOff() instead of toggleSwitch().
- Domoticz version: 2025.1
This will switch Sonoff on/off until switch Virtual is switched off. Then Sonoff will be switched off. The checkFirst is to prevent a switch log entry and other triggers every minute.
if dz.devices('Virtual').active then
dz.devices('Sonoff').switchOff().checkFirst()
hemant5400z
Users browsing this forum: kimot and 1 guest
