Add HomeWizard WiFi watermeter in Domoticz
- mvveelen
Re: Add HomeWizard WiFi watermeter in Domoticz
Whoops !
In Setup >> Settings >> Meters/Counters I had 1000000 for Water. Probably because I have been experimenting in the past with a Wemos D1 Mini board and a sensor.... The divider was 0, now I have this and I think it's right:
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- FireWizard
Hello @mvveelen,
In this case, I also understand your 1,000.000
I think these values look much more realistic.
- mvveelen
Thanks, I’ll monitor the values the next few days.
Edit: it's OK like this. The values are not very exact though.
I've edited my post to include the code brackets,
My - updated and now working - script is listed below.
Manual JSON request from a browser:
{"wifi_ssid":"XXX","wifi_strength":32,"total_liter_m3":0.087,"active_liter_lpm":0,"total_liter_offset_m3":0}
Domoticz versie: 2023.1
HTTP Poller: GET
Content type: application/json
URL: http://192.168.X.Y/api/v1/data
Command: water.lua
Directory: /home/pi/domoticz/scripts/lua_parsers
4 -rw-r--r-- 1 root root 843 May 14 15:30 water.lua
HTTP Poller: GET
Command: water.lua
-- Read API values
s = request['content'];
PRINT_MODE = true --true false -- when true print all used values
print('Water script')
local info = debug.getinfo(1,'S');
if PRINT_MODE == true then
print (' ')
print('*** Start van ' .. info.source .. ' script')
print ('Json response: ' .. s)
-- Watermeter
local idWater = 46
local a = domoticz_applyJsonPath(s,'.active_liter_lpm')
domoticz_updateDevice(idWater,'',a)
print('Waterverbruik: ' .. a)
local idWaterTotaal = 45
local b = domoticz_applyJsonPath(s,'.total_liter_m3')
domoticz_updateDevice(idWaterTotaal,'',b)
print('Totaal water verbruikt: ' .. b)
print('*** Einde van ' .. info.source .. ' script')
print (' ')
- mvveelen
Hi, please use the 'code' brackets when you post code and also try to use English here.
Do you use other LUA scripts that work? In other words, is LUA activated in Domoticz?
Do you receive errors or no messages at all?
My code:
My devices:
Haven't changed the rights of the file water.lua by the way, so what you have should be OK.
My code:
-- Read API values
-- Watermeter
local idWater = 2099
domoticz_updateDevice(idWater,'',a*1)
local idWaterTotaal = 2100
domoticz_updateDevice(idWaterTotaal,'',b*1000)
local idWaterVerbruik = 2101
local c = domoticz_applyJsonPath(s,'.total_liter_m3')
domoticz_updateDevice(idWaterVerbruik,'',c*1000)
Apologies for not using the right brackets !
The solution: the following line was a comment, I guess that prevented the main part of the code from running.
Correct line below.
Thank you for responding.
Correct line below.
- Domoticz version: 3.8153
I have written a Python plugin for the watermeter. Check the HomeWizard Wi-Fi Watermeter on Github.
- heggink
- Domoticz version: 12451
Just got the device and installed the plugin. World really nicely! Thx!!
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- sincze
- Domoticz version: 2024.4
Yes the mentioned P1 & Watermeter plugin are working excellent
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Is it possible to use this HomeWizard watermeter if I do not have anything else from HomeWizard I do not have a subscription with them. I am interested to set up this watermeter in combination with domoticz
- sincze
Yes, I have only their (P1 and Watermeter) devices.
You only need their APP to set it up but that is basically it.
Then you can cut Internet connection for the device and use it locally.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Thanks for the answer. So you don't need to have the P1 meter with it? Only you need the app during the initial setup, afterwards you don't need it anymore... That is great..
I don't get It.. I don't see the Meter offset in my widget? Any Idea? I have added a Custom sensor with m3 as label. It is a General / Custom Sensor. The device updates OK; but I cannot set the offset on the device because the value is not the same as in the Homewizard app..?FireWizard wrote: ↑Friday 30 December 2022 15:06 Hello @Hesmink
Go to your Watermeter widget and click "Edit".
The "Configuration" screen will open and insert the desired value.
Insert the desired "Meter Offset" and click "Update".
- Domoticz version: 2024.7
The offset value is available on the counter device.
- FireWizard
Goodevening @CronoS,
If you had read the thread from the beginning, you would have found the following line in a post of @Hesmink (30 december 2022).
Use a counter and configure it as water.
So the "Custom"sensor is the wrong choice.Got it. As per OP, I used the custom sensor, and you cannot add the offset there. I now updated it to a counter of type water. Issue solved, thanks.
Sorry; my mistake. I only have red the first page hahaha.. I even didn't saw that there was already a plugin now. Installed it and seems to work OK.. Thanks!FireWizard wrote: ↑Tuesday 03 October 2023 18:24 Goodevening @CronoS,
Hi Eraser,Eraser wrote: ↑Saturday 03 June 2023 15:15 I have written a Python plugin for the watermeter. Check the HomeWizard Wi-Fi Watermeter on Github.
This is great, my usage is only shown rounded to 10's
So 100 liters, of 320 etc. Never 44 liter or 182.
Could this be due to settings?
- FireWizard
Change the setting for "Water" to 1000 instead of 100.
YesCould this be due to settings?
Thanks FireWizard,
Would that mean my data so far should be deleted.
As it's now showing 50 liters today where the original was 500~
Family of 4 all showered today and the washer machine ran several times today.
So 500 is about right.
- FireWizard
Hi @bvdf0251,
Technically it is not necessary to delete existing data, as long as you realise that the data so far is incorrect. This data should not be used for any comparison..
To avoid mistakes, I would recommend to delete the data and start from scratch.
Do not forget to insert a correct off-set.
