- 2.jpg (110.38 KiB) Viewed 1197 times
remote control HISENSE 65U8GQ
zabinskiwojciech
- Domoticz version: 4.10776
- FireWizard
Re: remote control HISENSE 65U8GQ
Hello @zabinskiwojciech,
I see you use an older version of Node_RED. (Version 2.x.x?) Consider an update to the latest version.
In this case you have to change the "Output" from "auto-detect (string or buffer)" to "a parsed JSON object".
See:
If you update to the latest version 3.0.2, you have another option as well.
See:
Please, try again and let me know, if it functions.
Try "On/Off" button first, before we continue with the "Selector Switch".
See:
See:
zabinskiwojciech
You are irreplaceable again, great, commands work, WOL does not work ... maybe you need to install something else in Ubuntu or change something in Nodered settings.
- FireWizard
Just a quick check.
Has wake on lan been enabled in your tv settings?
See page 24 in this manual https://www.google.com/url?sa=t&source= ... d5QhXzpxYU
Chapter Wake up.
Chapter Wake up.
zabinskiwojciech
yes included
- FireWizard
Okay,
Next check:
1. Is your MAC address correct en does it match with the MAC address of the TV?
No company is registered for your MAC address: A0:62:FB:1D:B0:99 See: https://mac.lc/
[Edit] Here it is okay: https://macaddress.io/macaddress/A0:62:FB
2. Did you change the "Target Address" to the broadcast address of your LAN: 192.168.1.255?
Next check:
zabinskiwojciech
192.168.1.102 0 a0:62:fb:1d:b0:99 internal
this is what i read from the router
change Target Address
- FireWizard
Perhaps you have to install some package on your Linux(Ubuntu) machine.
You can do that, following the guide in https://www.cyberciti.biz/tips/linux-se ... ckets.html
Try to wake it up from the commandline first andthen tryagain with Node-RED/Domoticz.
zabinskiwojciech
Hello.
I fell down and I managed to start WOL, I had to change the card on the virtual machine to RLT because the virtual Intel did not support G packets. I made the settings according to the guide from the link:
https://necromuralist.github.io/posts/e ... ke-on-lan/
zabinskiwojciech
Thank you very much for help.
- FireWizard
So this means that you can switch your TV to "On". with Wake on Lan and you can also switch it Off.
Using in both cases Domoticz?
Can we conclude that this issue is closed or is there still something to be solved, e.g. Selector Switch.
If it is finished, I close this and delete that flow.
zabinskiwojciech
I'm closing, thanks for your help
