Page 2 of 2
Re: Latest update crashes domoticz
Posted: Wednesday 25 May 2022 13:48
by gerard1
I have done a restore, got Domoticz running again. (back to 14338)
However, many errors in the log file. Had to repair the Database.
Now everything is running as it should.
Posted: Thursday 26 May 2022 11:40
by Dnpwwo
This seems to have been a Linux only issue, I've pushed a fix that should fix at least some of the issues (maybe all).
Thanks @heggink, given I already had a copy of your test plugin I was able to reproduce the crash.
Posted: Thursday 26 May 2022 13:59
by gerard1
I have tried to update to Versie #14343
Did not work, same issue as before.
Had to rollback to Version # 14338 again.
Posted: Thursday 26 May 2022 14:37
by ferrosk
gerard1 wrote: Thursday 26 May 2022 13:59
The
fix is included in build #14344, you have to test with this version.
Posted: Thursday 26 May 2022 14:50
by Huntback
Same here, did update to b14343 but crashed also.
Removed plugin again.
btw b14344 is not available, b14343 is latest to pull.
Posted: Thursday 26 May 2022 14:53
by ferrosk
If you do not update by compiling from sources but use updatebeta script method, you have to wait next day for new beta build #14344 (or newer)
(see
https://domoticz.com/forum/viewtopic.php?t=36966)
Posted: Thursday 26 May 2022 23:18
by heggink
Dnpwwo wrote:Hi,
Fix working for me after compiling from source. Thanks!!
Sent from my SM-G980F using Tapatalk
Posted: Tuesday 31 May 2022 19:05
by gerard1
Eveything is working again. Have done a source update.
Takes some time, but it worked. ( version: 14344)
Posted: Thursday 02 June 2022 9:11
by DoMoAD
With the build from today 14348 the problem is gone. deConz plugin is working again and no crash on startup.
Thank you very much
Posted: Thursday 02 June 2022 14:06
by Huntback
Domoticz (Latest) on Docker/Synology:
After auto-update (Portainer) from 2022.1-build:14341 to 2022.1-build:14348 Domoticz is (with the Python plugin) not crashing and stable again
Thanks for resolving the issue.
