tried to receive the title just for testing: domoticz.log(item.JSON.params.title , domoticz.LOG_INFO)
2022-05-01 19:27:11.936 Error: EventSystem: in TEST: [string "return {..."]:10: attempt to index a nil value (global 'domoticz')
"params" : {
"title" : "cFos Power Brain",
"desc" : "Standard-Konfiguration",
"max_total_power" : 11000,
"power_reserve" : 0,
"overdraft" : 0,
"max_total_evse_power" : 0,
"consumed_evse_power" : 0,
"remaining_evse_power" : 14140,
"lb_enabled" : true,
"disable_policy" : 1,
"ocpp_srv_tls_mode" : "off",
"ocpp_srv_port" : 19520,
"ocpp_srv_use_ext_cert" : false,
"ocpp_srv_cert_fn" : "",
"ocpp_srv_private_key_fn" : "",
"ocpp_srv_cacert_fn" :
"price_model" : 0,
"fixed_price" : 0.000000,
"tibber_home_id" : "",
"cycle_time" : 3009,
"max_evses" : 3,
"shareware_mode" : false,
"version" : "1.9.1101",
"time" : 1651298858,
"vsn" :
"vendorid" : 52997,
"version" : 17368141,
"productid" : 1,
"serialno" : "W00-00EA"
"cpu" : 24,
"mem" : 57,
"ocpp_gateway_license_cnt" : 0,
"ocpp_gateway_licenses_used" : 0
"devices" : [
"dev_type" : "meter_powerfox_http_json",
"device_enabled" : 1,
"name" : "Stromverbrauch Gesamt",
"address" : "https://backend.Powerfox.Energy/API/2.0/my/main/current",
"id" : 1,
"dev_id" : "M3",
"number" : 2,
"desc" : "powerfox http",
"com_err" : false,
"com_err_secs" : 17714,
"com_errors" : 31,
"last_error" : "HTTP CLT: failed to open TLS connection to backend.Powerfox.Energy:443",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 2770970,
"export" : 4593968,
"power" : -3140,
"current_l1" : -4551,
"current_l2" : -4551,
"current_l3" : -4551,
"voltage_l1" : 0,
"voltage_l2" : 0,
"voltage_l3" : 0,
"role" : 3,
"model" : "Powerfox,Powerfox,1.0,1.0,0"
"dev_type" : "meter_powerbrain",
"name" : "S0 Zähler 2",
"address" : "meter2",
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"desc" : "cFos Power Brain, S0 Zähler 2",
"com_err" : false,
"com_err_secs" : 503040,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 425261,
"export" : 0,
"power" : 0,
"current_l1" : 0,
"current_l2" : 0,
"current_l3" : 0,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 4,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA"
"name" : "Stromverbrauch Garage",
"address" : "meter1",
"id" : 2,
"dev_id" : "M1",
"number" : 1,
"desc" : "cFos Power Brain, S0 Zähler 1",
"com_err" : false,
"com_err_secs" : 506329,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 810522,
"export" : 0,
"power" : 37,
"current_l1" : 54,
"current_l2" : 54,
"current_l3" : 54,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 0,
"dev_type" : "evse_powerbrain",
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"desc" : "cFos Power Brain 11kW",
"com_err" : false,
"com_errors" : 0,
"last_error" : "",
"is_evse" : true,
"used_phases" : 7,
"is_mock" : false,
"label" : "",
"min_charging_cur" : 6000,
"max_power" : 11040,
"prio" : 3,
"charging_enabled" : false,
"cur_charging_power" : 0,
"last_set_charging_cur" : 6000,
"total_energy" : 8703602,
"phases" : 0,
"state" : 1,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA",
"paused" : false,
"pause_time" : 300,
"pause_min_time" : 300,
"ucnt" : 1,
"evse" :
"dc_sensor_faults" : 0,
"dc_last_test_time" : "2022-04-28T07:25:18.416Z",
"dc_sensor_fault" : false,
"dc_sensor_glitches" : 3,
"cp_state" : "Standby",
"cp_fault" : false,
"pp_state" : "no cable",
"charging" : false,
"current" : 0,
"enabled" : false
"loadmgr_disabled" : false
