API script /http polling Powerfox Energy tracker
All kinds of 'OS' scripts
Mirkoser
Domoticz version: 2021/1
Re: API script /http polling Powerfox Energy tracker
Post by Mirkoser »
Thank you, related to this topic I have another question.
I tried to create another http request for my Wallbox.
Im struggling with the item.json…. Because the answer of my Wallbox is full of numbers and I cannot write e.g item.json.8062d in the code.
Answer of the http request
{"8000d":3473211392,"8002":1,"8003":258,"8004":263,"8005":1084,"8006":256,"8007":0,"8008s":"W00-00EA","8016s":"cFos Power Brain","8040":3,"8041":2,"8042d":1000,"8044":0,"8045":230,"8046":230,"8047":230,"8050q":121890,"8054d":22608230,"8056":1,"8057":0,"8058q":121890,"8062d":0,"8064d":0,"8066d":0,"8068d":0,"8070":0,"8071":0,"8120d":24}
should be something like
Somevalue = item.json['8026d']
or perhaps
Somevalue = item.json.['8026d']
Mirkoser
Post by Mirkoser »
That was the solution. But now I get the response „Nil“ in the log for the JSON 8026d value 🙃
Because there is no "8026d"? :)
Mirkoser
Post by Mirkoser »
oh damn...too much computer in the last days...now its working
Thanks a lot for all. I will post the running scripts as well
Mirkoser
Post by Mirkoser »
here my running powerfox plugin . Values are loaded into a virtual dummy P1 Meter
		timer = {
			'every minute' -- just an example to trigger the request
		httpResponses = { 'Powerfoxtrigger' } -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'Powerfox',
		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://XXXXXXXXXX:[email protected]/api/2.0/my/main/current', -- X =Login Powerfox Y= PW
				method = 'GET',
				callback = 'Powerfoxtrigger', -- see httpResponses above.
	if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
				    local USAGE1 = item.json.A_Plus
					local RETURN1 = item.json.A_Minus
				  GetWatt = item.json.Watt
                    if  item.json.Watt < 0 then
                      CONS = 0
                      PROD = math.abs(GetWatt)
                      	domoticz.devices('Stromverbrauch').updateP1(item.json.A_Plus, '0', item.json.A_Minus, '0', '0', item.json.Watt)
                      	 domoticz.log('negative watts', domoticz.LOG_INFO)
                      	  domoticz.log(item.json.Watt, domoticz.LOG_INFO)
                      	   domoticz.log(item.json.A_Plus , domoticz.LOG_INFO)
					         domoticz.log(item.json.A_Minus, domoticz.LOG_INFO)
                      CONS = GetWatt
                      PROD = 0
                      domoticz.devices('Stromverbrauch').updateP1(item.json.A_Plus, '0', item.json.A_Minus, '0', item.json.Watt, '0')
                        domoticz.log('posetive watts', domoticz.LOG_INFO)
Great, thanks for sharing the end result!
Mirkoser
Post by Mirkoser »
Hi I need again some assistance…I try to import some data with http get from my wallbox
The answer of the request is( see below)Now my question is how to import one specific value of this answer. I mean for example line with „ power" : 612, . But there are more lines with the name „power“
"params" : {
"title" : "cFos Power Brain",
"desc" : "Standard-Konfiguration",
"max_total_power" : 11000,
"power_reserve" : 0,
"overdraft" : 0,
"max_total_evse_power" : 0,
"consumed_evse_power" : 0,
"remaining_evse_power" : 10388,
"lb_enabled" : true,
"disable_policy" : 1,
"ocpp_srv_tls_mode" : "off",
"ocpp_srv_port" : 19520,
"ocpp_srv_use_ext_cert" : false,
"ocpp_srv_cert_fn" : "",
"ocpp_srv_private_key_fn" : "",
"ocpp_srv_cacert_fn" :
"price_model" : 0,
"fixed_price" : 0.000000,
"tibber_home_id" : "",
"cycle_time" : 3000,
"max_evses" : 3,
"shareware_mode" : false,
"version" : "1.9.1101",
"time" : 1651093245,
"vsn" :
"vendorid" : 52997,
"version" : 17368141,
"productid" : 1,
"serialno" : "W00-00EA"
"cpu" : 58,
"mem" : 62,
"ocpp_gateway_license_cnt" : 0,
"ocpp_gateway_licenses_used" : 0
"devices" : [
"dev_type" : "meter_powerfox_http_json",
"device_enabled" : 1,
"name" : "Stromverbrauch Gesamt",
"address" : "https://backend.Powerfox.Energy/API/2.0/my/main/current",
"id" : 1,
"dev_id" : "M3",
"number" : 2,
"desc" : "powerfox http",
"com_err" : false,
"com_err_secs" : 26851,
"com_errors" : 25,
"last_error" : "HTTP CLT:  failed to open TLS connection to backend.Powerfox.Energy:443",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 2744864,
"export" : 4406790,
"power" : 612,
"current_l1" : 887,
"current_l2" : 887,
"current_l3" : 887,
"voltage_l1" : 0,
"voltage_l2" : 0,
"voltage_l3" : 0,
"role" : 3,
"model" : "Powerfox,Powerfox,1.0,1.0,0"
"dev_type" : "meter_powerbrain",
"name" : "S0 Zähler 2",
"address" : "meter2",
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"desc" : "cFos Power Brain, S0 Zähler 2",
"com_err" : false,
"com_err_secs" : 297427,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 401107,
"export" : 0,
"power" : 0,
"current_l1" : 0,
"current_l2" : 0,
"current_l3" : 0,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 4,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA"
"name" : "Stromverbrauch Garage",
"address" : "meter1",
"id" : 2,
"dev_id" : "M1",
"number" : 1,
"desc" : "cFos Power Brain, S0 Zähler 1",
"com_err" : false,
"com_err_secs" : 300716,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 778749,
"export" : 0,
"power" : 46,
"current_l1" : 67,
"current_l2" : 67,
"current_l3" : 67,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 0,
"dev_type" : "evse_powerbrain",
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"desc" : "cFos Power Brain 11kW",
"com_err" : false,
"com_errors" : 0,
"last_error" : "",
"is_evse" : true,
"used_phases" : 7,
"is_mock" : false,
"label" : "",
"min_charging_cur" : 6000,
"max_power" : 11040,
"prio" : 3,
"charging_enabled" : false,
"cur_charging_power" : 0,
"last_set_charging_cur" : 6000,
"total_energy" : 8625219,
"phases" : 0,
"state" : 1,
"model" : "cFos Power Brain,1.0,1.9.1101,W00-00EA",
"paused" : false,
"pause_time" : 300,
"pause_min_time" : 300,
"ucnt" : 1,
"evse" :
"dc_sensor_faults" : 0,
"dc_last_test_time" : "2022-04-26T15:55:30.946Z",
"dc_sensor_fault" : false,
"dc_sensor_glitches" : 3,
"cp_state" : "Standby",
"cp_fault" : false,
"pp_state" : "no cable",
"charging" : false,
"current" : 0,
"enabled" : false
"loadmgr_disabled" : false
Not completely sure but "power" : 612 is part of device with "dev_id" : "M3".
So if this M3 device is always in the same location in the json (first device in the list) you could try something like item.json.devices[0].power
or could also be item.json.devices[1].power.
If this not works you have to loop through the results
		local result_table = item.json.devices
		local tc = #result_table
		for i = 1, tc do
			if result_table[i].dev_id == "M3" then
                            PowerRead = result_table[i].power
Mirkoser
Post by Mirkoser »
Perfect, thanks I will try. Yes m3 device will be always at the same position.. I will report:)
Mirkoser
Post by Mirkoser »
Seems not working,
tried to receive the title just for testing: domoticz.log(item.JSON.params.title , domoticz.LOG_INFO)
thats the error in the log file
2022-05-01 19:27:11.936 Error: EventSystem: in TEST: [string "return {..."]:10: attempt to index a nil value (global 'domoticz')
here the response in raw data from by wallbox
"params" : {
"overdraft" : 0,
"remaining_evse_power" : 14140,
"price_model" : 0,
"cycle_time" : 3009,
"max_evses" : 3,
"time" : 1651298858,
"vsn" :
"vendorid" : 52997,
"productid" : 1,
"cpu" : 24,
"mem" : 57,
"devices" : [
"id" : 1,
"dev_id" : "M3",
"number" : 2,
"com_err" : false,
"com_err_secs" : 17714,
"com_errors" : 31,
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 2770970,
"export" : 4593968,
"power" : -3140,
"current_l1" : -4551,
"current_l2" : -4551,
"current_l3" : -4551,
"voltage_l1" : 0,
"voltage_l2" : 0,
"voltage_l3" : 0,
"role" : 3,
"id" : 3,
"dev_id" : "M2",
"number" : 3,
"com_err" : false,
"com_err_secs" : 503040,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 425261,
"export" : 0,
"power" : 0,
"current_l1" : 0,
"current_l2" : 0,
"current_l3" : 0,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 4,
"id" : 2,
"dev_id" : "M1",
"number" : 1,
"com_err" : false,
"com_err_secs" : 506329,
"com_errors" : 0,
"last_error" : "",
"is_evse" : false,
"used_phases" : 0,
"is_mock" : false,
"is_va" : false,
"invert" : false,
"import" : 810522,
"export" : 0,
"power" : 37,
"current_l1" : 54,
"current_l2" : 54,
"current_l3" : 54,
"voltage_l1" : 230,
"voltage_l2" : 230,
"voltage_l3" : 230,
"role" : 0,
"name" : "Wallbox",
"address" : "evse",
"id" : 1,
"dev_id" : "E1",
"number" : 1,
"com_err" : false,
"com_errors" : 0,
"last_error" : "",
"is_evse" : true,
"used_phases" : 7,
"is_mock" : false,
"label" : "",
"prio" : 3,
"total_energy" : 8703602,
"phases" : 0,
"state" : 1,
"paused" : false,
"pause_time" : 300,
"ucnt" : 1,
"evse" :
"dc_last_test_time" : "2022-04-28T07:25:18.416Z",
"cp_fault" : false,
"charging" : false,
"current" : 0,
"enabled" : false
It should work
but you are using capital letters for JSON. DZvents is case sensitive!
"item.JSON.params.title" should be "item.json.params.title"
