Page 2 of 2
Re: eurotronics SPZB0001 ZIGBEE
Posted: Thursday 02 December 2021 13:40
by FWES70
yes I did, but then it does not connect to the Zigate anymore. after I flashed the FW from anther of my TRV's it connected again, but (obviously) had the same behaviour: one-way communicatin only.
From what I read, there are 2 versions of the 20191014 FW, one of which is not OK. As a fix, Eurotronic has provided the last working FW (20190408).
Posted: Thursday 02 December 2021 14:21
by pipiche
But how did you flash ? This is an OTA format and you should use the Firmware update from the plugin to push , is that what you did ?
Posted: Thursday 02 December 2021 14:55
by FWES70
No,I used the wired method described by Solvisit in this topic:
https://github.com/EUROTRONIC-Technolog ... -830773393
I will try to push it through the plugin
Posted: Thursday 02 December 2021 15:57
by pipiche
This could be the issue, as if you use the flash technics, you need to have the firmware in the proper format. And OTA format is for Zigbee Over-The_Air upgrade (which is then what the plugin does), and which requires to be online on Zigbee
so I'm afraid that either you get a binary firmware to re flash your Eurotronic device, otherwise this one is dead.
Eventually extract the firmware from one working device with Solvisit method and flash it back to the not-working device
Posted: Thursday 02 December 2021 15:59
by FWES70
Yes,I did that before and it is OK.
I cannot enable firmware upgrade in the Web UI (option is not there). any idea?
Posted: Thursday 02 December 2021 16:25
by pipiche
That is correct, I'll work on that this evening (it will be available on the beta branch)
Posted: Thursday 02 December 2021 16:54
by FWES70
in the meantime I found it in the PluginConf.py and chaged "hidden" : "True" to "False". now I see it and it is enabled.
But the FW update does not work so far. (I added a folder "EUROTRONIC" in the OTAFirmware folder, saved the .ota file there and updated the OTA plugin). Am I doing anything wrong here?
Posted: Thursday 02 December 2021 16:59
by FWES70
I added the log for the OTA update, maybe it helps. if there is anything I can do let me know
Posted: Thursday 02 December 2021 17:32
by pipiche
As I said, they are changed to be made.
I did it, the OTA is working the file is sent to the device, but it looks like the image is rejected.
Posted: Thursday 02 December 2021 17:40
by pipiche
Please switch to the latest beta branch ( beta-5.2.314 ).
You have to download the OTA firmware under OTAFirmware/EUROTRONICS/ folder
then restart the plugin
Then you will be able to launch the firmware update from the WebUI > Admin > Firmware
You might need to wait 1 or 2 ' until the plugin is fully running.
For me , unfortunatly the upgrade is not going through.
Posted: Thursday 02 December 2021 18:39
by FWES70
thank you so far. I have the same issue. let's wait if the new TRV has OK firmware.
Posted: Tuesday 07 December 2021 13:26
by FWES70
Update: the new TRV worked, so I used the method form Solvisit to dump the FW from it and flash it to my other TRV's sucesfully. took me about 20 minutes, and they all work fine now!
The only thing I did extra was delete the flash first on the old TRVs with this command:
JN51xxProgrammer.exe -s COM3 eraseflash=full
then deleted the old TRV's from Domoticz and re-paired them as normal.
Note: the "thermostat Mode" is gone now, but I did not use that anyway.
Posted: Tuesday 07 December 2021 13:31
by pipiche
Can you tell me what is the SWBUILD value now ?
If you want to retreive the Themostat mode, there is a way with teh latest beta version.
Go to the WebUI > Admin > Provisionning > Recreate widget(s) of existing device
This will re-create ALL widgets, so then after you can remove what is duplicate
Posted: Tuesday 07 December 2021 14:14
by FWES70
now it shows:
SWBUILD_1 : "20191014"
SWBUILD_3 : "00000000"
I looked when I had paired the new TRV, and there was absolutely no difference between the old and new (see below)
Ep :
01 :
0000 :
4000 : "00000000" -- this used to be 22190930
0005 : "SPZB0001"
0000 : "2"
0001 : "22"
0002 : "5"
0004 : "Eurotronic"
0006 : "20191014" --no change
000a : "31393931" --no change
For me it is fine now, I do not need the mode, I steer on temperature
If OK, I will send you a PM with the export raw of the devices, maybe you can find something?
by pipiche
Sound good
Posted: Tuesday 07 December 2021 15:19
by FWES70
did you get my PM? I do not see it in my sent items
