Page 2 of 2
Re: How can I best debug dzVents?
Posted: Friday 13 August 2021 22:19
by EddyG
So I installed the zigbee plugin on an almost virgin domoticz test system.
Got the same error
2021-08-13 21:55:23.790 Error: EventSystem: in /opt/domoticz/dzVents/runtime/dzVents.lua: ...oticz/dzVents/runtime/device-adapters/generic_device.lua:67: attempt to index a nil value (field '_')
My problem is I cannot find which device is causing the error.
Have set full debugging on and hope for the best.....
Posted: Saturday 14 August 2021 8:01
by EddyG
It get even funnier. I have 1 script running on that official docker Domoticz test system ( version 2021.1 build 13360).
A copied that script from the examples, nothing special in the script.
- Spoiler: show
active = true,
devices = {
'Internal Temperature'
execute = function(domoticz, mySensor)
if (mySensor.temperature > 45) then
domoticz.notify('Hey!', 'The house might be on fire!!',
domoticz.PRIORITY_EMERGENCY,
domoticz.SOUND_SIREN)
domoticz.log('Temperatuur boven 45 graden', domoticz.LOG_ERROR)
This is part of the logfile around the error. So the question is why is the Domoticz event system triggered?
2021-08-14 07:25:40.771 Status: dzVents: Info: Handling events for: "Internal Temperature", value: "42.4"
2021-08-14 07:25:40.771 Status: dzVents: Info: ------ Start external script: get sensor values.lua: Device: "Internal Temperature (Motherboard)", Index: 1
2021-08-14 07:25:40.771 Status: dzVents: Info: ------ Finished get sensor values.lua
2021-08-14 07:25:41.174 zigbee2mqtt: (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/logging {'level': 'info', 'message': 'MQTT publish: topic \'zigbee2mqtt/AchterdeurSW\', payload \'{"battery":100,"contact":true,"last_seen":"2021-08-14T07:25:40+02:00","linkquality":54,"temperature":25,"voltage":3055}\''}
2021-08-14 07:25:41.174 zigbee2mqtt: (zigbee2mqtt) MQTT message: zigbee2mqtt/AchterdeurSW {'battery': 100, 'contact': True, 'last_seen': '2021-08-14T07:25:40+02:00', 'linkquality': 54, 'temperature': 25, 'voltage': 3055}
2021-08-14 07:25:41.780 zigbee2mqtt: (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/logging {'level': 'info', 'message': 'MQTT publish: topic \'zigbee2mqtt/ZolderTHB\', payload \'{"battery":100,"humidity":48.8,"last_seen":"2021-08-14T07:25:40+02:00","linkquality":147,"pressure":1017.9,"temperature":25.9,"voltage":3025}\''}
2021-08-14 07:25:41.781 zigbee2mqtt: (zigbee2mqtt) MQTT message: zigbee2mqtt/ZolderTHB {'battery': 100, 'humidity': 48.8, 'last_seen': '2021-08-14T07:25:40+02:00', 'linkquality': 147, 'pressure': 1017.9, 'temperature': 25.9, 'voltage': 3025}
2021-08-14 07:25:41.913 Error: EventSystem: in /opt/domoticz/dzVents/runtime/dzVents.lua: ...oticz/dzVents/runtime/device-adapters/generic_device.lua:67: attempt to index a nil value (field '_')
2021-08-14 07:25:48.364 zigbee2mqtt: (zigbee2mqtt) MQTT message: zigbee2mqtt/bridge/logging {'level': 'info', 'message': 'MQTT publish: topic \'zigbee2mqtt/Garage\', payload \'{"battery":100,"humidity":71.1,"last_seen":"2021-08-14T07:25:48+02:00","linkquality":39,"temperature":15.7,"voltage":2100}\''}
Posted: Saturday 14 August 2021 9:47
by EddyG
And just for reference, I have several Domoticz systems running, even 1 system, which is up for more then a year, of which the Linux system never went down for the last 1070 days. And that Domoticz system has NO error at all.
- Spoiler: show
- Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.4.2 (default, Sep 16 2019, 20:33:47) [GCC 4.9.2]
Uptime: 453 Days, 20 Hours, 10 Minutes, 40 Seconds
I have a few other Raspberry Domoticz running which don't show any errors, or only induced by me.
These errors come from zigbee2mqtt service, the zigbee2mqtt plugin, dzVents system, or the Plugin handler by Domoticz (see
https://github.com/domoticz/domoticz/issues/4881 )
I am searching for a way to narrow down the cause.
Posted: Saturday 14 August 2021 10:10
by heggink
Happy to try to help find the issue. I have had my share of issues with domoticz in the past (many different crashes from signal 6 to signal 11, scripts misbehaving for no apparent reason, the system getting blocked for 10 seconds not responding to triggers) so I know how frustrating it can be to find the cause.
Couple of things that would help me understand where you are coming from:
What debugging do you have switched on:
- domoticz (-loglevel normal,status,debug,error)?
- script level (logging = { level = domoticz.LOG_DEBUG, marker = "IETS" } and subsequent LOG_DEBUG logs)
What zigbee types of devices do you have? Since I don't experience your issues, maybe you have a device that I don;t have which causes dzvents to bork.
At some point, I had max debuggin on, leading to massive syslogs. Digging through those ultimately enabled me to find multiple culprits. I have helped a couple of other people find their issues so let's see.
Let me know. Feel free to PM me.
H
Posted: Saturday 14 August 2021 11:37
by EddyG
Currently the logging is set to:
Domoticz -> logging is default in a docker container on a RPi 4 test system.
Zigbee2mqtt plugin -> logging is set to Verbose
dzVents -> logging is set to debug.
52 Zigbee devices of all kind of types.
The most problematic part is that errors (and crashes) occur random in time, with no relation to any device YET!
I cleared everything, now I have to wait to the first error to occur.
Posted: Saturday 14 August 2021 12:28
by EddyG
Up until now I found 1 strange thing in the logging, but that does not lead to an error.
This device
https://www.zigbee2mqtt.io/devices/TS00 ... uya-ts0002 sends this zigbee message from zigbee2mqtt logging
info 2021-08-14 12:20:26: MQTT publish: topic 'zigbee2mqtt/Slaapkamer', payload '{"brightness":203,"color":{"x":0.4599,"y":0.4106},"color_temp":300,"last_seen":"2021-08-14T12:20:26+02:00","linkquality":45,"state":"ON","state_l1":"OFF","state_l2":"ON"}'
But that device does not have brightness and color, very strange!!!
In the GUI of the zigbee2mqtt service it is a normal 2 pol. switch and the switch works normal.
Posted: Sunday 15 August 2021 14:13
by EddyG
I got a little bit further.
I only get things working if I shutdown Domoticz and Zigbee2mqtt and disable Zigbee plugin hardware in Domoticz by phpLiteAdmin.
Then I start zigbee2mqtt and Domoticz, if everything is up then I enable Zigbee plugin in Domoticz.
Then things get running without a Domoticz crash, but a lot of device (not all) are not recognized any more by dzVents scripts, which give errors like the device is unknown.
When I actuate such a device in the GUI of Zigbee2mqtt then that device starts working again in Domoticz as it should.
So any ideas of where problem can be solved are welkom....
Posted: Friday 20 August 2021 9:51
by EddyG
After almost 5 days without any zigbee errors and crashes, it looks like the system is stable now.
What did I do to make it stable again?
A LOT!!! So it is difficult to point out what did the trick.
Most important is that I found out that not very device has all settings filled with the right value.
So I excluded and included a lot of those devices again.
After that all settings/properties were 'normalized' as that they have normal values instead of NULL or even empty.
Most problems were on battery powered devices.
What ever it caused it, I don't know, but it seems stabel now.
P.S. Still don't know where the dzVents error came from......
Posted: Saturday 21 August 2021 17:23
by EddyG
Found 2 of the reasons:
1. Delete the file state.json in zigbee2mqtt/data dir and let it build fresh again.
2.
https://github.com/stas-demydiuk/domoti ... issues/679
I hope the issue will be corrected soon!
