Python plugin: WiZ Connected
JessicasDad
Re: Python plugin: WiZ Connected
Post by JessicasDad »
Is anyone successfully using this Wiz-Connected plugin to control Phillips Wiz bulbs in the uk?
I've got the plugin installed ok and the heartbeat etc appears in the logs, but it just doesn't detect any of the bulbs :(
I don't think it's an issue with my network as I've got the Wiz plugin added to Homebridge on another Pi on the same network and it finds the bulbs ok as long as I specify the static IP addresses for them, but that doesn't seem to be an option with Domoticz.
The wiz bulbs are also connected to Alexa ok.
Can anyone help?
Ross
JessicasDad
Just to update this.
I've given up on getting the plugin working and am using virtual switches with UDP commands sent via scripts instead.
packetloss
Domoticz version: 4.11590
Post by packetloss »
sydspost wrote: Wednesday 28 July 2021 11:02 Bought recently a WiZ connected WiFI-lightbulb in the Supermarket without checking if there was support for this brand in Domoticz. I found out the hardway that there was no support ;-)
So, i made my own plugin which operates the lightbulb within your local network, no access to the WiZ connected cloud is needed. Except for the initial pairing of the device with your WiFi. After the pairing is done, you can delete the device from the WiZ connected cloud and/or close your account.
Key features:
  • Auto-detects devices in your network
    Tested with WiZ whites lights (but should control other devices on/off)
    Allows controlling Dimmer/Cold-Warm for lights
    When device operated by app, Domoticz is synchronized every 10 seconds
You can download the plugin from https://github.com/sydspost/Domoticz-Wi ... ted-plugin
Enjoy !
Not having Wiz devices yet, I am planning to buy one like this: https://www.wizconnected.com/nl-nl/p/li ... 0169077669
My question is: the Git says 'should control other devices on/off' , but can I also use the script (that I upfront already installed in Domoticz) to change colors? Or is it only on and off?
