Page 2 of 2
Re: Doorbell from Action (LSC Smart Connect)
Posted: Sunday 07 November 2021 15:20
by hoeby
Have you made steps with tasmota?
I got the code from the doorbell with a simple-rc-scanner
But it looks there is a pre-sample in the code. Which rswitch can not work with (by default).
The esphome code can work with it. But it goes to far for me, to get those esphome coding in a modified rcswitch code.
If you have any idea, i would be happy to hear.
Posted: Monday 08 November 2021 14:20
by CPtje
hoeby wrote:
For people who have this doorbell, they have 433mhz inside which controls a chime.
The doorbell is sold by many sellers with each having there own name, but it is the same hardware.
I used ESPHOME on a ESP8266 which reacts on this 433mhz command and send a mqtt message to domoticz.
No firmware flash on the doorbell necessary.
Made it with ESPHOME, because the 433mhz is a 64bit signal. ESPHOME can receive this
Tried it with ESPEASY, but that uses the default rcswitch library, which supports max. 32 bits
@hoeby
Could you please provide the yaml-code for this solution? I am not yet familiar with ESPHOME, but would like to give this a try.
Posted: Tuesday 16 November 2021 21:29
by fx4sky
EddyG wrote: Sunday 11 July 2021 15:37 Got the RTSP stream
rtsp://admin:[email protected]:8554/Streaming/Channels/101
rtsp://admin:[email protected]:8554/Streaming/Channels/102
First one is 1920 x 1080 and the second one is 640 x 360
The last one is suitable for display in Domoticz
Searching further....
Hello !
I try to connect my doorbell to motioneye with those settings but impossible to do this.
Even in vlc impossible to display someting.
PLease, could you explain how to do ?
Thanks in advance.
Best Regards
Jean
Posted: Tuesday 16 November 2021 21:39
by hoeby
In motioneye you have a wrong ip/port written. Don't know if that is the problem, but try it
You have: 192.169.0.14/8554
This must be: 192.168.0.14:8554
Also try in motion eye to keep the username and password empty. And place those in the url, like eddy posted.
I have a foscam doorbell. That only works with user/password in the url, not by adding them in there own fields
Posted: Wednesday 17 November 2021 22:31
by fx4sky
Thanks for your answer.
I tried with your two solution and that is the results :
I don't know if your are using the smart connect LSC smart doorbell 1080HD with Module MCU V2.10.5 ?
thanks for you help again
Best regards
Jean
Posted: Thursday 18 November 2021 9:27
by EddyG
In the first post I state which version I am using. It seems one of the latest version which is not susceptible for the hacks found on the Internet.
These are the streams that I found with this version.
Posted: Tuesday 07 December 2021 7:36
by hoeby
Last weeks i was modifying the zigbee network with sonoff zigbee coordinators.
I also saw that they have a RF bridge. Ordered one to try and see if it works that beautiful as the zigbee coordinators.
I reflashed it with tasmota and portisch firmware.
After that, the doorbell works without other modifications to the rf bridge.
This is the result it gives when pushing the button.
The "Data" is the unique code for the doorbell
RSL: RESULT = {"Time":"2021-12-06T20:19:08","RfReceived":{"Sync":12820,"Low":470,"High":1300,"Data":"303631","RfKey":"None"}}
With that result, you can make rules in de tasmota, to do things.
This rule triggers an idx device in domoticz (mqtt needs to be setup in the tasmota)
- Change 303631 to the code your doorbells gives you
- Change 64 to the idx number of your domoticz device.
You have to make something in domoticz, to set the IDX back to off. This rule, doesn't send an off command
Rule1 ON RfReceived#Data=303631 DO publish domoticz/in {"idx":64,"nvalue":1} ENDON
After adding the rule, do this command, to enable the rule
Rule1 1
When doing no rules, but getting the code in Nodered, it looks like when putting a debug behind a mqtt input
{"Time":"2021-12-06T20:35:01","RfReceived":{"Sync":12810,"Low":460,"High":1300,"Data":"303631","RfKey":"None"}}
Information how to flash:
https://tasmota.github.io/docs/devices/ ... ridge-433/
The device
Posted: Thursday 13 January 2022 8:27
by gegewawa
Did you succeed to access remotely to this doorbell using an app like TinyCam ?
I have correctly acces with this app to my doorbell by using a wifi connection, therefore when I switch to a 4G connection on my phone, it doesn't work anymore.
The port redirection on my routeur on both ONVIF and RTSP have been done. I used 8000 and 554 as redirection ports parameters.
Is it possible that the doorbell is made to allow acces only with the same wifi connection and not from the outside ?
Note that I have other Tapo cameras that work perfectly on both wifi and 4G connections.
Thanks for you help.
Posted: Thursday 24 February 2022 18:51
by fennec62
i find way to have MQTT push when button push with firmware 5.0.5
Add doorbell to Tuya APP on iOS or android
first create account on
https://iot.tuya.com
After create Cloud Project
On your project add devices Link Tuya App
Use data center from your region
You must App Account with 1 device
After note Authorization Key
Access ID/Client ID and Access Secret/Client Secret
now install
https://github.com/jasonacox/tinytuya
and start
python -m tinytuya wizard
You must write
API Key it's Access ID/Client ID
Secret it's Access Secret/Client Secret
DeviceID. you find in app Tuya
Region eu for me
With that you can have key for your device id
"name": "Visiophone Wifi",
"key": "e177111111111",
"id": "bf5ad111111111"
Now install
https://github.com/TheAgentK/tuya-mqtt
setup config.json for mqtt setting
And with tinytuya you have create devices.json rename in devices.conf and put in folder tuya-mqtt
and start
DEBUG=tuya-mqtt:* ./tuya-mqtt.js
And after each button push you can see message like that
tuya-mqtt:state MQTT DPS JSON: tuya/visiophone_wifi/dps/state -> {"244":"0"} +67ms
tuya-mqtt:state MQTT DPS244: tuya/visiophone_wifi/dps/244/state -> 0 +1ms
tuya-mqtt:tuyapi Received JSON data from device bf5ada2f1c3c05e3cfi86t -> {"244":"0"} +16s
tuya-mqtt:state MQTT DPS JSON: tuya/visiophone_wifi/dps/state -> {"244":"0"} +16s
tuya-mqtt:state MQTT DPS244: tuya/visiophone_wifi/dps/244/state -> 0 +2ms
tuya-mqtt:tuyapi Received JSON data from device bf5ada2f1c3c05e3cfi86t -> {"244":"0"} +12s
tuya-mqtt:state MQTT DPS JSON: tuya/visiophone_wifi/dps/state -> {"244":"0"} +12s
{"244":"0"} is when button push
