Page 2 of 2
Re: Maximum of lua scripts?
Posted: Wednesday 31 March 2021 23:12
by JohnnySK
still same error
2021-03-31 23:08:04.971 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3650.err
2021-03-31 23:08:28.844 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3659.out
2021-03-31 23:08:28.844 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3659.err
2021-03-31 23:10:43.734 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3714.out
2021-03-31 23:10:43.734 Error: unable to remove file /home/pi/domoticz/scripts/dzVents/data/domscript3714.err
Posted: Wednesday 31 March 2021 23:21
by manjh
waaren wrote: Wednesday 31 March 2021 23:01 when using os.execute you should use the background operator
os.execute('/home/pi/domoticz/scripts/speedtest2.sh &')
Excellent. That does it! Thank you!
It comes to mind that I need to educate on dzvents. I'm quite happy using LUA, dzVents looks different in approach.
What is a good place to start? Step by step documentation?
Posted: Thursday 01 April 2021 0:04
by waaren
manjh wrote: Wednesday 31 March 2021 23:21 What is a good place to start? Step by step documentation?
os.execute is 100% Lua and the background (&) operator is Linux.
The wiki and the video @dannyBloe posted here should get you started
Posted: Thursday 01 April 2021 0:58
by waaren
JohnnySK wrote: Wednesday 31 March 2021 23:12 still same error
can you share the os script and the content of these files in home/pi/domoticz/scripts/dzVents/data/ ?
Also please the output of
sudo ps -ef | grep  '[d]omoticz' | cut -d' ' -f1
sudo find /home/pi/domoticz/scripts/dzVents -type d -exec stat -c '%A - %U:%G  %n' {} +
sudo find /home/pi/domoticz/domoticz -type f -exec stat -c '%A - %U:%G  %n' {} +
sudo find /home/pi/domoticz/scripts/dzVents/data/*err -type f -exec stat -c '%A - %U:%G  %n' {} +
Posted: Thursday 01 April 2021 1:08
by JohnnySK
pi@raspberrypi:~/domoticz/scripts $ sudo ps -ef | grep  '[d]omoticz' | cut -d' ' -f1
root
root
root
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/scripts/dzVents -type d -exec stat -c '%A - %U:%G  %n' {} +
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents/scripts
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents/examples
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents/examples/templates
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents/generated_scripts
drwxr-xr-x - pi:pi  /home/pi/domoticz/scripts/dzVents/dumps
drwxrwxrwx - pi:pi  /home/pi/domoticz/scripts/dzVents/data
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/domoticz -type f -exec stat -c '%A - %U:%G  %n' {} +
-rwxr-xr-x - pi:pi  /home/pi/domoticz/domoticz
pi@raspberrypi:~/domoticz/scripts $ sudo find /home/pi/domoticz/scripts/dzVents/data/*err -type f -exec stat -c '%A - %U:%G  %n' {} +
-rw------- - root:root  /home/pi/domoticz/scripts/dzVents/data/domscript4307.err
-rw------- - root:root  /home/pi/domoticz/scripts/dzVents/data/domscript4308.err
content of file in home/pi/domoticz/scripts/dzVents/data/
empty, 0 bytes, just filenames
script, connect to webserver, get values, calculate and push it to domoticz
#!/bin/bash
content=`curl -s http://admin:[email protected]/rect.cgi?A=4&B=Select`
current=`html2text <<< "$content"  | grep "Current_(A)_____" | column -ts'|' | column -ts'Current_(A)_____  '`
voltage=`html2text <<< "$content"  | grep "Voltage_(V)_____" | column -ts'|' | column -ts'Voltage_(V)_____  '`
power=`awk '{print $1*$2}' <<<"$current $voltage"`
url="http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=240&nvalue=0&svalue=$power"
report=`curl -s $url`
Posted: Thursday 01 April 2021 2:21
by waaren
JohnnySK wrote: Thursday 01 April 2021 1:08 content of file in home/pi/domoticz/scripts/dzVents/data/
Can you try again after changing the dzVents and bash to the below ones. It might not directly solve the issue but will show more information on what happens.
The power value will be returned to dzVents for further processing.
btw. It should also be possible to directly call the http://admin:[email protected]/rect.cgi?A=4&B=Select with a openURL call and bypass the OS script completely.
Your domoticz user is root but the directories are owned by pi:pi
that might be the reason the temp files (*err / *out) cannot be deleted
local scriptVar = 'getPower'
return
    on =
        devices =
            'Batt Napatie',
        shellCommandResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        local function osScript(script, delay)
            dz.executeShellCommand(
                command = '/home/pi/domoticz/scripts/' .. script,
                callback = scriptVar,
                timeout = 30,                          -- max execution time in seconds
            }).afterSec(delay or 0)
        if item.isDevice or item.isTimer then
           osScript('pv_fpv1.sh')
           osScript('pv_fpv2.sh', 10)
        elseif item.ok then
            dz.log('data from script: ' .. item.data, dz.LOG_DEBUG) -- need more processing
            dz.log('There was an error', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
bash script
#!/bin/bash
echo $power
Posted: Thursday 01 April 2021 9:47
by azonneveld
JohnnySK wrote: Tuesday 30 March 2021 9:43 Yes,
maybe this is problem.. I have os.execute in one script.. I will move this one to the dzVents.
You could try, in lua:
os.execute ('(/home/.../script.sh > /dev/null)&')
This makes the script continue without waiting for the externally script to finish.
Posted: Thursday 01 April 2021 9:55
by waaren
azonneveld wrote: Thursday 01 April 2021 9:47 This makes the script continue without waiting for the externally script to finish.
True but in dzVents > 3.1 the executeShellCommand() is available and that command will not only execute any shell command truly async and in a separate thread but does also offers the option to capture the result and returncode by means of the callback.
So if you are on a recent domoticz build the preferred way of executing any os command from within a dzVents script is to use the executeShellCommand()
Posted: Thursday 01 April 2021 10:20
by JohnnySK
I have some work now but I will try it. And it's possible get from bash more than one value?
Because I already started work on get voltage from BASH too.. see this
#!/bin/bash
#echo "$current"A
#echo "$voltage"V
#echo "$power"W
#echo "$content"
replace=""
firstStep=`echo "${content//<\/TR>/$replace}"`
secondStep=`echo "${firstStep//<TR>/$replace}"`
lastStep=`echo "${firstStep//BORDER CELLPADDING="3"/$replace}"`
#whole=`html2text <<< "$lastStep"`
#echo "$whole"
values=`html2text <<< "$lastStep"  | grep "Input_Voltage_(V)" | column -ts'| °()_-' | column -ts'abcdefghijklmnoprstuvqxyzTIVSNC'`
#echo $values
IFS=' ' read -ra params <<< "$values"
#Print the split string
#for i in "${params[@]}"
#do
#    echo $i
#done
sekundy=`date +%S`
#echo $sekundy
remainder=$(( sekundy % 15 ))
if [ "$remainder" -eq 0 ]; then
        #echo $sekundy
        pvVoltage=${params[1]}
        #echo "$pvVoltage"V
        url="http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=331&nvalue=0&svalue=$pvVoltage"
        #echo $url
fi
Posted: Thursday 01 April 2021 11:14
by waaren
JohnnySK wrote: Thursday 01 April 2021 10:20 I have some work now but I will try it. And it's possible get from bash more than one value?
Yes. The amount of data to return to dzvents is not unlimited but I tested up to 64K without issues.
can you share the result of the first curl command
It might help in creating a dzVents performing the same task but without the need of curl and/or OS script.
Posted: Thursday 01 April 2021 12:10
by JohnnySK
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN">
<HTML>
<HEAD>
<META http-equiv="refresh" content="30;URL=rect.cgi">
</HEAD>
<BODY>
<H2>Rectifier</H2>
<FORM METHOD=GET action=rect.cgi>
<P>Rectifier Address
<SELECT NAME=A><OPTION >1<OPTION SELECTED>4<OPTION >5</SELECT>
<INPUT TYPE=SUBMIT NAME=B VALUE="Select">
</P>
</FORM>
Enabled <INPUT TYPE=CHECKBOX NAME=C CHECKED>
<INPUT TYPE=SUBMIT NAME=D VALUE="Submit"  >
</FORM>
<H2>Rectifier Status</H2>
<TABLE BORDER CELLPADDING="3">
<TR>
<TH>Voltage (V)</TH>
<TD>52.1</TD>
</TR>
<TR>
<TH>Current (A)</TH>
<TD>14.9</TD>
</TR>
<TR>
<TH>Mean Current (A)</TH>
<TD>98.5</TD>
</TR>
<TR>
<TH>Temperature (&deg;C)</TH>
<TD>20</TD>
</TR>
<TH>Input Voltage (V)</TH>
<TD>201</TD>
</TR>
<TH>Version</TH>
<TD>50.56</TD>
</TR>
<TH>Serial Number</TH>
<TD>541</TD>
</TR>
</TABLE>
<H2>Alarm Status</H2>
<P><IMG SRC=ok.gif ALT="O"> Input Voltage OK<BR><IMG SRC=ok.gif ALT="O"> Low Voltage<BR><IMG SRC=ok.gif ALT="O"> Module Alarm<BR><IMG SRC=ok.gif ALT="O"> OV Shutdown<BR><IMG SRC=ok.gif ALT="O"> Current Limiting<BR><IMG SRC=ok.gif ALT="O"> Power On<BR><IMG SRC=ok.gif ALT="O"> OVP Enabled<BR><IMG SRC=ok.gif ALT="O"> Current Limit Reduced<BR><IMG SRC=ok.gif ALT="O"> Fan Fail<BR><IMG SRC=ok.gif ALT="O"> Current Share<BR><IMG SRC=ok.gif ALT="O"> Temp. Alarm<BR><IMG SRC=ok.gif ALT="O"> Phase Failure<BR><IMG SRC=ok.gif ALT="O"> Temp. SD<BR><IMG SRC=ok.gif ALT="O"> Internal Failure<BR></P>
</BODY>
</HTML>
Posted: Thursday 01 April 2021 17:22
by waaren
JohnnySK wrote: Thursday 01 April 2021 12:10
<HTML>
It's worth a try to see the result of below dzVents script that would get the values without using curl or OS scripts.
Please feel free to ask for clarification if and when needed.
local scriptVar = 'getRectData'
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_INFO,
        marker = scriptVar,
        local function extractData(myData)
            -- get Values
            values = {}
            for value in string.gmatch(myData, "<TD>([%d%.]*)</TD>") do
                table.insert(values, value)
            -- get Labels and make table
            local counter = 1
            local data = {}
            for label in string.gmatch(myData, "<TH>([%s%w%(%)%&%;]*)</TH>") do
                data[label] = values[counter]
                counter = counter + 1
            return data
        if item.isTimer then
            dz.openURL(
                url = 'http://admin:[email protected]/rect.cgi?A=4&B=Select',
        elseif item.isHTTPResponse and item.ok then
            local data = extractData(item.data)
            dz.utils.dumpTable (data) -- This will show the content of the datatable. From here it will be relatively easy to populate the various virtual sensors (volt, ampere, etc)
            dz.log('There was a problem handling the request', dz.LOG_ERROR)
            dz.log(item, dz.LOG_ERROR)
Posted: Friday 02 April 2021 0:24
by JohnnySK
but timer offer minutes timer only.. and my script must run maximal each 10seconds..
aaand, I must to turn off dzVents.. I have few devices updated by web api (json svalue update by web get) but each 6-8seconds... and devices get higher and higher delay. After 12hours values in domoticz and reality was so far ... only restart of domoticz service helps. It looks like dzVents create some big load on web server.
Posted: Friday 02 April 2021 7:22
by waaren
JohnnySK wrote: Friday 02 April 2021 0:24 but timer offer minutes timer only.. and my script must run maximal each 10seconds..
For that restriction an easy workaround exists that was used before for similar cases.
See below
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
        local frequency = 6 -- every 60 / frequency seconds (frequency 6 ==>> every 10 seconds)
            -- get Values
            values = {}
            local counter = 1
            local data = {}
            return data
        local function sendURL(delay)
            dz.openURL(
            local interval = math.floor(60/frequency)
            for delay = interval, (60 - interval), interval do
                sendURL(delay)
So to summarize you have similar response problems as you reported before in January 2019 when you use a couple of classic Lua scripts and also after converting scripts to dzVents when updating a number of devices every 5 seconds.
Then the conclusion might well be that given your current hardware, scripting is not the solution for you if the current update frequency and number of devices are a requirement.
Posted: Friday 02 April 2021 9:00
by JohnnySK
Maybe..
But, on latest release was this delay with same scripts under minute. (not realtime, but not so bad)
Today, I have turned off dzVents, I migrated two big measurement scripts to MQTT and LUA but on beta, it looks like web interface gets big delay after few minutes of run. (delay more than 5minutes, really bad)
Yes I had simmilar problem before. I migrated lot off devices to MQTT and upgraded to latest release with new RPi and data was almost in realtime..
Posted: Friday 02 April 2021 11:29
by JohnnySK
How LUA scripts update values.. Maybe will be better use red-node for prepare data and push ti domoticz only final values. V 2020.2 support consuption calculation by itself.. (send Watt only) I have this scripts because in earlier version was it on device update.
