Page 2 of 2
Re: CommandArray not executed
Posted: Tuesday 16 March 2021 11:28
by azonneveld
waaren wrote: Thursday 11 March 2021 8:46 Maybe you will see some interesting values when you add some prints. Something like below?
    if #commandArray == 0 then
        print ('tWakeupAssist -empty commandArray-')
        print('sValue of Profiel: '  .. tostring(otherdevices_svalues['Profiel'] ) )
        -- Any other interesting device values Here ?
        tprint(commandArray)
Today this gave the following hit:
2021-03-16 06:10:01.732 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-03-16 06:10:01.732 Status: LUA: tWakeupAssist -empty commandArray-
2021-03-16 06:10:01.732 Status: LUA: sValue of Profiel: 20
2021-03-16 06:10:01.988 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-03-16 06:10:01.988 Status: LUA: 1:
2021-03-16 06:10:01.988 Status: LUA: tWakeupAssist: Off
2021-03-16 06:10:01.988 Status: LUA: 2:
2021-03-16 06:10:01.988 Status: LUA: Variable:WakeUpAssistTriggered: 1
2021-03-16 06:10:01.989 Status: LUA: 3:
2021-03-16 06:10:01.989 Status: LUA: Variable:WakeUpAssistStarted: 370
2021-03-16 06:10:01.989 Status: LUA: 4:
2021-03-16 06:10:01.989 Status: LUA: Slaap Licht: On
2021-03-16 06:10:01.989 Status: LUA: 5:
2021-03-16 06:10:01.989 Status: LUA: Ikea Socket 02: On FOR 15
2021-03-16 06:10:01.989 Status: LUA: 6:
2021-03-16 06:10:01.989 Status: LUA: Group:Woon Lamp: On AFTER 10
2021-03-16 06:10:01.989 Status: LUA: 7:
2021-03-16 06:10:01.989 Status: LUA: Profiel: Set Level: 30
2021-03-16 06:10:01.989 Status: LUA: 8:
2021-03-16 06:10:01.989 Status: LUA: NooitUit_Auto: Off
2021-03-16 06:10:01.989 Status: LUA: 9:
2021-03-16 06:10:01.989 Status: LUA: SendNotification: Profiel geschakeld naar NooitUit_Auto....
2021-03-16 06:10:01.989 Status: LUA: =============== tWakeupAssist DEBUG ====================
Posted: Tuesday 16 March 2021 12:08
by waaren
azonneveld wrote: Tuesday 16 March 2021 11:28 Today this gave the following hit:
The only thing I can think of is that at 2021-03-16 06:10:01.732 the tWakeupAssist was not 'On' Maybe a print of the state of that device in the
line would help to identify what is going on.
Posted: Wednesday 07 April 2021 9:24
by azonneveld
waaren wrote: Tuesday 16 March 2021 12:08 the tWakeupAssist was not 'On' Maybe a print of the state of that device in the line would help to identify what is going on.
That is possible, since the script is device triggered.
tWakeupAssist could be on, but other devices are still in front in the execution cue.
When the script is executed based on other devices in the cue, the 'otherdevices' command retrieves the state of the tWakeupAssist, and it is 'On'.
I changed the script, now the 'debug' is only triggered on the tWakeupAssist device.
Posted: Tuesday 13 July 2021 8:47
by azonneveld
I have not seen the error again since upgrade to 2021.1.
Posted: Thursday 11 November 2021 11:24
by azonneveld
Today the bug happened again.
I have a kind of watchdog implemented which catches the bug, but it still remains a strange issue.
The watchdog checks every minute if the dummy switch state is 'on' and latschange is greater than 1 minute.
In that case the watchdog triggers the dummy again by setting it to 'on'.
The code that should be executed when the dummy switches on, switches the dummy off.
Suggestions are welcome
Log from dummy switch
2021-11-11 07:32:01	Off	EventSystem/AssistWakeUp2_2
2021-11-11 07:30:01	On	timer
Global log:
2021-11-11 07:30:01.370 Status: Schedule item started! Name: tWakeupAssist, Type: On Time, DevID: 50, Time: 2021-11-11 07:30:01
2021-11-11 07:32:00.485 Status: Notification: WakeUpAssistant Trigger Failed
2021-11-11 07:32:01.036 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-11-11 07:32:01.036 Status: LUA: 1:
2021-11-11 07:32:01.036 Status: LUA: Variable:WakeUpAssistTriggered: 1
2021-11-11 07:32:01.036 Status: LUA: 2:
2021-11-11 07:32:01.036 Status: LUA: Variable:WakeUpAssistStarted: 452
2021-11-11 07:32:01.036 Status: LUA: 3:
2021-11-11 07:32:01.036 Status: LUA: Group:SleepAssistantBoven: On
2021-11-11 07:32:01.036 Status: LUA: 4:
2021-11-11 07:32:01.036 Status: LUA: Ikea Socket 02: On FOR 15
2021-11-11 07:32:01.036 Status: LUA: 5:
2021-11-11 07:32:01.036 Status: LUA: Group:Woon Lamp: On AFTER 10
2021-11-11 07:32:01.036 Status: LUA: 6:
2021-11-11 07:32:01.036 Status: LUA: tWakeupAssist: Off
--============== SETTINGS =========================
local LuxLow = 800
local tNow = os.date("*t");
local tNowInMin = tNow.min + tNow.hour * 60
local ZonOp = tonumber(timeofday['SunriseInMinutes']);
local ZonOnder = tonumber(timeofday['SunsetInMinutes'])
local t =  os.date("*t");
local Taan = uservariables["VerwarmingAanTemp"]
local Tuit = uservariables["VerwarmingUitTemp"]
local mCrestaTemp,mCrestaHumidity
local doLog = false
-- functions
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = round((os.difftime (t1, t2) / 60),0)
   return difference
local function tprint (t, indent, done) -- introduced done to prevent infinite loops for tables with self-references
  local done = done or {}
  indent = indent or 0
  for key, value in pairs (t) do
    pre = (string.rep (" ", indent)) -- indent it
    if type (value) == "table" and not done[value] then
      done [value] = true
      print (pre .. tostring (key) .. ":");
      tprint (value, indent + 2, done)
    elseif type(value) == 'function' and not done[value] then
      print( pre .. (tostring (key) .. "()"))
      pre = pre .. (tostring (key) .. ": ")
      print (pre .. tostring(value))
for deviceName,deviceValue in pairs(devicechanged) do
-- WAKE ASSIST
    if otherdevices_svalues['Profiel'] ~= '40' then
            if (deviceName=='tWakeupAssist') then
                    if deviceValue == "On" and otherdevices['SkipWakeupassistant'] ~= 'On' and (otherdevices['WakeUpAssistant'] == 'On') then
                        --- UITZETTEN GAAT VIA GLOBALS, HIER WORDT TRIGGER GEZET
                        if (otherdevices_svalues['Profiel']~='30') then   -- niet uitzetten als profiel op nooituit staat
                            commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='1'}
                            commandArray[#commandArray + 1] = {['Variable:WakeUpAssistStarted']=tostring(tNowInMin)}
                        commandArray[#commandArray + 1] = {['Group:SleepAssistantBoven'] = 'On'}
                        --commandArray[#commandArray + 1] = {['Slaap Licht'] = "On"}   -- Activatie device voor group SleepAssistantBoven
                        commandArray[#commandArray + 1] = {['Ikea Socket 02'] = "On FOR 15"}  -- lamp op logeerkamer 15 minuten aan
                        if (((tNowInMin <= ZonOp) and (uservariables['LuxAlive'] == 0))  or ((tonumber(otherdevices['LuxMeter']) < LuxLow) and uservariables['LuxAlive'] == 1)) then
                            commandArray[#commandArray + 1] = {['Group:Woon Lamp'] = "On AFTER 10"}
                        if otherdevices_svalues['NotificationLevel']=='20' then -- NotificationLevel Debug
                           commandArray[#commandArray + 1] = {['SendNotification']='WakeUpAssistant Triggered'}
                        -- WakeUpAssistant uit functie onderdrukken via NooitUit_Auto
                        if otherdevices['NooitUit_Auto'] == 'On' then
                            if otherdevices_svalues['Profiel']~='30' then
                                commandArray[#commandArray + 1] = {['Profiel'] = "Set Level: 30"}
                                commandArray[#commandArray + 1] = {['NooitUit_Auto'] = "Off"}
                                if otherdevices_svalues['NotificationLevel']~='0' then -- Notification not muted
                                    commandArray[#commandArray + 1] = {['SendNotification']='Profiel geschakeld naar NooitUit_Auto, als je morgen de uitfunctie van WakeUpAssistant ook wilt onderdrukken, kies dan een profiel en zet NooitUit_Auto weer aan'}
-- KRABBEN REPORT
                        if otherdevices_svalues['NotificationLevel']~='0' then -- NotificationLevel not muted
                            local sCrestaTemp, sCrestaHumidity = otherdevices_svalues['Tuin Temp']
                            --local mCrestaTemp = otherdevices_svalues['Tuin Temp']
                            mCrestaTemp, mCrestaHumidity = otherdevices_svalues['Tuin Temp']:match("([^;]+);([^;]+)")
                            local mMin = otherdevices_svalues['Minimum Temp']
                            if tonumber(mCrestaTemp) < 3 and tonumber(mMin) < 0.5 then
                                os.execute ('(/bin/sleep 20 && /home/pi/domoticz/scripts/autokrabben.sh > /dev/null)&')
                                commandArray[#commandArray + 1] = {['SendNotification']='Krabben Report, temperatuur:' ..tostring(mCrestaTemp)}
                        if deviceValue == "On" and #commandArray >= 2 then
                            commandArray[#commandArray + 1] = {['tWakeupAssist'] = "Off"}
                    elseif deviceValue == "Off" or otherdevices['SkipWakeupassistant'] == 'On' or otherdevices['WakeUpAssistant'] == 'Off' then
                        if deviceValue ~= "Off" then
                        if otherdevices['SkipWakeupassistant'] ~= 'Off' then
                            commandArray[#commandArray + 1] = {['SkipWakeupassistant']='Off'}
            elseif (otherdevices['WakeUpAssistant'] ~= 'On') and tostring(uservariables['WakeUpAssistantTriggered']) ~= '0' then
                commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='0'}
-- Skip WakeUpAssistant
        local t = tonumber(uservariables["WakeUpAssistantNextMinutes"] - tNowInMin)
        if deviceName == 'SkipWakeupassistant' then
            if deviceValue == 'On' then
                if t < 0 or t > 90  then  -- WakeUpAssistant mag geskipt worden, maximaal 1 uur voor de wekker, en ook niet na de wekker
-- DEBUG
    if otherdevices['tWakeupAssist'] == 'On' and deviceName == 'tWakeupAssist'  then
        print("=============== tWakeupAssist DEBUG ====================")
