Today the bug happened again.
I have a kind of watchdog implemented which catches the bug, but it still remains a strange issue.
The watchdog checks every minute if the dummy switch state is 'on' and latschange is greater than 1 minute.
In that case the watchdog triggers the dummy again by setting it to 'on'.
The code that should be executed when the dummy switches on, switches the dummy off.
Suggestions are welcome
Log from dummy switch
2021-11-11 07:32:01 Off EventSystem/AssistWakeUp2_2
2021-11-11 07:30:01 On timer
Global log:
2021-11-11 07:30:01.370 Status: Schedule item started! Name: tWakeupAssist, Type: On Time, DevID: 50, Time: 2021-11-11 07:30:01
2021-11-11 07:32:00.485 Status: Notification: WakeUpAssistant Trigger Failed
2021-11-11 07:32:01.036 Status: LUA: =============== tWakeupAssist DEBUG ====================
2021-11-11 07:32:01.036 Status: LUA: 1:
2021-11-11 07:32:01.036 Status: LUA: Variable:WakeUpAssistTriggered: 1
2021-11-11 07:32:01.036 Status: LUA: 2:
2021-11-11 07:32:01.036 Status: LUA: Variable:WakeUpAssistStarted: 452
2021-11-11 07:32:01.036 Status: LUA: 3:
2021-11-11 07:32:01.036 Status: LUA: Group:SleepAssistantBoven: On
2021-11-11 07:32:01.036 Status: LUA: 4:
2021-11-11 07:32:01.036 Status: LUA: Ikea Socket 02: On FOR 15
2021-11-11 07:32:01.036 Status: LUA: 5:
2021-11-11 07:32:01.036 Status: LUA: Group:Woon Lamp: On AFTER 10
2021-11-11 07:32:01.036 Status: LUA: 6:
2021-11-11 07:32:01.036 Status: LUA: tWakeupAssist: Off
--============== SETTINGS =========================
local LuxLow = 800
local tNow = os.date("*t");
local tNowInMin = tNow.min + tNow.hour * 60
local ZonOp = tonumber(timeofday['SunriseInMinutes']);
local ZonOnder = tonumber(timeofday['SunsetInMinutes'])
local t = os.date("*t");
local Taan = uservariables["VerwarmingAanTemp"]
local Tuit = uservariables["VerwarmingUitTemp"]
local mCrestaTemp,mCrestaHumidity
local doLog = false
-- functions
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = round((os.difftime (t1, t2) / 60),0)
return difference
local function tprint (t, indent, done) -- introduced done to prevent infinite loops for tables with self-references
local done = done or {}
indent = indent or 0
for key, value in pairs (t) do
pre = (string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done[value] then
done [value] = true
print (pre .. tostring (key) .. ":");
tprint (value, indent + 2, done)
elseif type(value) == 'function' and not done[value] then
print( pre .. (tostring (key) .. "()"))
pre = pre .. (tostring (key) .. ": ")
print (pre .. tostring(value))
for deviceName,deviceValue in pairs(devicechanged) do
-- WAKE ASSIST
if otherdevices_svalues['Profiel'] ~= '40' then
if (deviceName=='tWakeupAssist') then
if deviceValue == "On" and otherdevices['SkipWakeupassistant'] ~= 'On' and (otherdevices['WakeUpAssistant'] == 'On') then
--- UITZETTEN GAAT VIA GLOBALS, HIER WORDT TRIGGER GEZET
if (otherdevices_svalues['Profiel']~='30') then -- niet uitzetten als profiel op nooituit staat
commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='1'}
commandArray[#commandArray + 1] = {['Variable:WakeUpAssistStarted']=tostring(tNowInMin)}
commandArray[#commandArray + 1] = {['Group:SleepAssistantBoven'] = 'On'}
--commandArray[#commandArray + 1] = {['Slaap Licht'] = "On"} -- Activatie device voor group SleepAssistantBoven
commandArray[#commandArray + 1] = {['Ikea Socket 02'] = "On FOR 15"} -- lamp op logeerkamer 15 minuten aan
if (((tNowInMin <= ZonOp) and (uservariables['LuxAlive'] == 0)) or ((tonumber(otherdevices['LuxMeter']) < LuxLow) and uservariables['LuxAlive'] == 1)) then
commandArray[#commandArray + 1] = {['Group:Woon Lamp'] = "On AFTER 10"}
if otherdevices_svalues['NotificationLevel']=='20' then -- NotificationLevel Debug
commandArray[#commandArray + 1] = {['SendNotification']='WakeUpAssistant Triggered'}
-- WakeUpAssistant uit functie onderdrukken via NooitUit_Auto
if otherdevices['NooitUit_Auto'] == 'On' then
if otherdevices_svalues['Profiel']~='30' then
commandArray[#commandArray + 1] = {['Profiel'] = "Set Level: 30"}
commandArray[#commandArray + 1] = {['NooitUit_Auto'] = "Off"}
if otherdevices_svalues['NotificationLevel']~='0' then -- Notification not muted
commandArray[#commandArray + 1] = {['SendNotification']='Profiel geschakeld naar NooitUit_Auto, als je morgen de uitfunctie van WakeUpAssistant ook wilt onderdrukken, kies dan een profiel en zet NooitUit_Auto weer aan'}
-- KRABBEN REPORT
if otherdevices_svalues['NotificationLevel']~='0' then -- NotificationLevel not muted
local sCrestaTemp, sCrestaHumidity = otherdevices_svalues['Tuin Temp']
--local mCrestaTemp = otherdevices_svalues['Tuin Temp']
mCrestaTemp, mCrestaHumidity = otherdevices_svalues['Tuin Temp']:match("([^;]+);([^;]+)")
local mMin = otherdevices_svalues['Minimum Temp']
if tonumber(mCrestaTemp) < 3 and tonumber(mMin) < 0.5 then
os.execute ('(/bin/sleep 20 && /home/pi/domoticz/scripts/autokrabben.sh > /dev/null)&')
commandArray[#commandArray + 1] = {['SendNotification']='Krabben Report, temperatuur:' ..tostring(mCrestaTemp)}
if deviceValue == "On" and #commandArray >= 2 then
commandArray[#commandArray + 1] = {['tWakeupAssist'] = "Off"}
elseif deviceValue == "Off" or otherdevices['SkipWakeupassistant'] == 'On' or otherdevices['WakeUpAssistant'] == 'Off' then
if deviceValue ~= "Off" then
if otherdevices['SkipWakeupassistant'] ~= 'Off' then
commandArray[#commandArray + 1] = {['SkipWakeupassistant']='Off'}
elseif (otherdevices['WakeUpAssistant'] ~= 'On') and tostring(uservariables['WakeUpAssistantTriggered']) ~= '0' then
commandArray[#commandArray + 1] = {['Variable:WakeUpAssistTriggered']='0'}
-- Skip WakeUpAssistant
local t = tonumber(uservariables["WakeUpAssistantNextMinutes"] - tNowInMin)
if deviceName == 'SkipWakeupassistant' then
if deviceValue == 'On' then
if t < 0 or t > 90 then -- WakeUpAssistant mag geskipt worden, maximaal 1 uur voor de wekker, en ook niet na de wekker
-- DEBUG
if otherdevices['tWakeupAssist'] == 'On' and deviceName == 'tWakeupAssist' then
print("=============== tWakeupAssist DEBUG ====================")
if #commandArray == 0 then
print ('tWakeupAssist -empty commandArray-')
print('sValue of Profiel: ' .. tostring(otherdevices_svalues['Profiel'] ) )
tprint(commandArray)
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
