Need help for understand dzVents
albebert
Re: Need help for understand dzVents
Post by albebert »
waaren wrote: Tuesday 23 February 2021 0:26
albebert wrote: Monday 22 February 2021 19:02 many thanks and send me your paypal adres in PM wan't to offer you a beer :)
Very kind of you but not needed.
i know but it's a pleasure for me, so as you want :)
Many thanks for your help !
after some test, seems that all is working. just a smal issue, i don't know why but when amp is Off, the script send a volume=0 to the amp, not a real problem because when the amp is off it ignore the command.
So i share m'y 2 scripts that are running (i've 2 zone to control)
zone Main (Called zone 1 for me) :
local scriptVar = 'Yamaha'
        timer =
            'every minute' -- just an example to trigger the request
        devices =
            'Ampli - Zone 1',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        local maxVolume = 161
        local volume = dz.devices('Ampli - Zone 1') -- switch (dimmer)
        local input = dz.devices('Ampli Input') -- selector switch with all possible input strings as levels
        if item.isTimer then
            dz.openURL({
                url = 'http://192.168.200.67/YamahaExtendedControl/v1/main/getStatus',
                callback = scriptVar,
        elseif item.isDevice then
            dz.openURL('http://192.168.200.67/YamahaExtendedControl/v1/main/setVolume?volume=' .. (math.floor( item.level * maxVolume / 100) ))
        elseif item.isHTTPResponse and item.json and item.json.power == 'on' then
            dz.log('or another here ?', dz.LOG_DEBUG)
            volume.dimTo(math.floor(item.json.volume / maxVolume * 100)).silent()
            input.switchSelector(item.json.input).silent()
        if item.isHTTPResponse and item.json and item.json.power == 'standby' then
           volume.quietOff()
Zone 2 :
local scriptVar = 'Yamaha2'
        timer =
        devices =
            'Ampli - Zone 2',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
        local volume2 = dz.devices('Ampli - Zone 2') -- switch (dimmer)
            dz.openURL({
                url = 'http://192.168.200.67/YamahaExtendedControl/v1/zone2/getStatus',
            dz.openURL('http://192.168.200.67/YamahaExtendedControl/v1/zone2/setVolume?volume=' .. (math.floor( item.level * maxVolume / 100) ))
            volume2.dimTo(math.floor(item.json.volume / maxVolume * 100)).silent()
           volume2.quietOff()
albebert
Post by albebert »
so now i undestand a bit more dzvent, i'm trying to make a net radio selector.
local scriptVar = 'Yamaha3'
        timer =
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
        local input3 = dz.devices('Net Radio Selector') -- selector switch with all possible input strings as levels
            dz.openURL({
                url = 'http://192.168.200.67/YamahaExtendedControl/v1/netusb/getPlayInfo',
            return
        if item.isHTTPResponse and item.json and item.json.input == 'net_radio' then
            dz.utils.dumpTable(item.json) -- just for test / debug
			input3.switchSelector(item.json.artist).silent()
but i've 1 problem and 1 question :
question : it's possible to add a wildcard to input3.switchselector ?
Api send "La Grosse Radio Rock (France/French)" but wan't only" La Grosse Radio Rock" in selector, it's possible ?
problem : when the script run, it's seems to change the input causing amp to reopen radio (1s audio cut due tu buffering), ".silent" does not act as "quietoff" ?
(not shure that i'am clear, i'm french and not good in english, if you don't understant i will try to reformulate)
albebert wrote: Tuesday 23 February 2021 10:56 question : it's possible to add a wildcard to input3.switchselector ?
No the switchSelector() must match the exact level name or level number (0,10,20 etc)
Yes you could use standard Lua string manipulation or a translation table
-- string manipulation
sourceStr = "La Grosse Radio Rock (France/French)"
targetStr = sourceStr:match("(.+)%(") -- Anything up to the first (
targetStr = targetStr:gsub("^%s*(.-)%s*$", "%1") -- remove leading and trailing spaces
print("Only part up to first ( will be printed of '" .. sourceStr .. "'. Result: '" .. targetStr .. "'")
-- translationTable
translationTable =
	["La Grosse Radio Rock (France/French)"] = "La Grosse Radio Rock",
	["something else"] = "something new",
print('"' .. sourceStr .. '" will be translated into "' .. translationTable[sourceStr] .. '"')
print('"something else"' .. ' will be translated into "' .. translationTable["something else"] ..'"')
problem : ".silent" does not act as "quietoff" ?
No silent() only prevents the device update to lead to another event trigger. It will perform the requested action on the device
albebert
Post by albebert »
ok all is working now :)
local scriptVar = 'Yamaha_net_radio'
        timer =
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            dz.openURL({
            return
--dz.log(input3.switchSelector(state, dz.LOG_DEBUG)
            sourceStr = item.json.artist
			input3.switchSelector(targetStr).silent().checkFirst()
i've added .checkFirst() to switchSelector so now i've a cut only if i change radio from outside domoticz.
another many thanks !
