Definition stationclock in css
madpatrick
Domoticz version: 2026.1
Re: Definition stationclock in css
Post by madpatrick »
The time with Flipclock stands still in the Standby screen.
In the normal screens it flips
Lokonli
Post by Lokonli »
The tragedy of standby ...
I'll check :)
madpatrick
hahaha...
The standard 'clock' is working in the standby screen.
By the way. Now the time stottering. hangs for a few seconds and then go's for and then hangs....
Is it possible to center the station clock by default in the middle of the block?
Enz0jacco
Post by Enz0jacco »
Lokonli wrote: Friday 11 December 2020 14:25 The tragedy of standby ...
I'll check :)
now that we're talking about standby, is it possible to adjust the background in a color instead of an image?
tried a lot in css but none are working:(
Lokonli
Post by Lokonli »
Enz0jacco wrote: Friday 11 December 2020 14:39
I'll check :)
For the complete standby screen?
Add the following to custom.css:
.screenstandby {
    background-color: red !important
madpatrick
Is it possible to create white dials ?
My background is dark so the dial are now visible
Lokonli
Post by Lokonli »
madpatrick wrote: Saturday 12 December 2020 18:23 Is it possible to create white dials ?
Currently it's not supported, but it's not too difficult to add.
Currently, stationclock is constructed with the following color settings:
	// clock colors
	this.hourHandColor     = 'rgb(0,0,0)';
	this.minuteHandColor   = 'rgb(0,0,0)';
	this.secondHandColor   = 'rgb(200,0,0)';
I'll add it to the list.
Lokonli
Post by Lokonli »
madpatrick wrote: Friday 11 December 2020 14:13 The time with Flipclock stands still in the Standby screen.
I don't see issues on my system.
What kind of system do you use for Dashticz?
Do you have more content on the standby screen?
Could you test with flipclock only?
madpatrick
Not sure what happened, but now it working normally.
I'm using a Sumsung tablet with Full Remote Browser
The content i'm using are : Clock, Rain forecast and garbage
Lokonli
Post by Lokonli »
Lokonli wrote: Thursday 10 December 2020 19:42
Next addition will be - CSS Variable-Powered Clock by Emily Hayman (2 votes)
As promised, the hayman clock:
Add 'haymanclock' to a column, or define a custom block as follows:
blocks['myclock'] = {
   type: 'haymanclock'
I can still adapt the styling a bit. If needed I can add some additional configuration parameters.
Next clock requires at least 3 votes :)
Enz0jacco
Post by Enz0jacco »
That’s a pity not many people are interested I guess:p
Thnx for the effort!
Sent from my iPad using Tapatalk
Chris12
Domoticz version: 2021.1
Post by Chris12 »
Lokonli wrote: Thursday 17 December 2020 22:36
The "SVG Clock UI" had already 2 votes... is that one added as well?
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
Chris12
Post by Chris12 »
madpatrick wrote: Friday 11 December 2020 14:28 Is it possible to center the station clock by default in the middle of the block?
Did you found a sollution for this?
My standby-screen is a single column (width 12), in which I define the weather_own and a clock.
the weather_owm, is full size on the top part of the screen, but I can get the (flip)clock to be as big as the complete screen as well.
Enz0jacco
Post by Enz0jacco »
Chris12 wrote: Friday 18 December 2020 10:41
this is what I did with my stationclock
.standby .stationclock {
	display: flex !important;
	justify-content: center !important;
	align-items: center !important;
	background-color: rgb(0,0,0); !important;
	height: 800px !important; }
madpatrick
is did the same as Enz0jacco.
Put weather_own and the clock in 2 different blocks.
Chris12
Post by Chris12 »
Enz0jacco wrote: Friday 18 December 2020 15:25
Ok I give this a try as well for the normal clock.
madpatrick
   type: 'haymanclock'
Is it possible to change the font color ?
madpatrick
I've found out that this is working
.haymanclock .clock-day:before 		{font-weight: bold !important; color: rgba(168, 168, 168, .6) !important}
.haymanclock .clock-hours:before	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-minutes:before	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-seconds:before 	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-label		{color: rgba(255,255,0,.30) !important;font-weight: bold}
