zigbee2mqtt bind ikea remote to group
albertomarrod
Domoticz version: Latest
Re: zigbee2mqtt bind ikea remote to group
Post by albertomarrod »
heggink wrote: Saturday 10 October 2020 13:07 Next update: I have multiple of these switches (of various dates and versions) all of type E1743. With one switch, everything gets updated without any issues, with another, nothing gets updated in domoticz although the lights can be controlled fine...
Hi!
The remote is updating in domoticz once I press the button. The thing is that domoticz has created two devices only for the remote...
The first one is created when I firstly bind the remote with domoticz, and the second one when I create the group into z2m plugin...
If I press the button on the remote the device who is updated is the first one and if I do it on domoticz I have to use the second one.
Pi3, latest beta
z-wave (AEOTEC, switches, temhum, pir, contacts, roller shutter),
Pylips, WiFi ping, Mi-Light,
Xiaomi Xiaofang cams, zigbee2mqtt,
dashticz v3
heggink
Domoticz version: 12451
Post by heggink »
Doing a little more testing, it turns out that the issue is with any (type, version) remote, when switching lights through a group binding.
When using a remote to switch lights in the group, the light's status will not update in domoticz.
I tried the same with an IKEA plug. The plug DOES change state in domoticz so the issue only exists with lights. With a plug and a light in a group, only the plug changes state but not the light...
Filed an issue with the plugin developer: https://github.com/stas-demydiuk/domoti ... issues/434
P1 meter & solar panel
heggink
Post by heggink »
Found the fix: setting report: true in advanced section of z2m configuration.yaml fixes it! All devices now report perfectly!
Ericv
Domoticz version: 4.9700
Post by Ericv »
I am struggeling to unbind the Ikea remote from its default group. Has to do with my lack of experience with mqtt. I am using MQTT Explorer to look at the mqtt communication.
What must be the proper syntax to sent an unbind message?
The remote is registered in the zigbee network, i can check the status with Domoticz. But adding the remote to a group is not succesfull yet.
Help is appreciated,
Raspberry Pi3; Razberry V2; RFlink; PIco UPS HV3.0
EddyG
Post by EddyG »
heggink
Post by heggink »
Ericv wrote:Hi,
In my experience, this is best done from the web interface from zigbee2mqtt.
EddyG
Post by EddyG »
I have done it the Ikea way, because remote and bulb are from Ikea.
The resulting binding came back in zigbee2mqtt GUI.
Unbinding can be done easy in the zigbee2mqtt GUI but also easy with a mqtt message.
