Dashticz v3.6 master
Lokonli
Re: Dashticz v3.6 master
Do you see issues with all your graphs?
Can you post the code from CONFIG.js for a graph with problems?
Remelco
- Domoticz version: 2020.1
Yes , I have 2 graphs and both have the same problem.
Also the icons are disappeared from nu.nl and nos.nl
my config.js of the graphs:
// Definition 'Elektriciteit' graph
blocks[p1_grafiek_elektra] = {
title: 'Energie',
graph: ['line','bar','bar'],
custom : {
"vandaag": {
range: 'day',
filter: '12 hours',
data: {
netto: 'd.v+d.v2-d.r1-d.r2',
gebruikt: 'd.v+d.v2',
geleverd: '-d.r1-d.r2'
"maand": {
range: 'month',
filter: '1 months',
data: {
"jaar": {
range: 'year',
filter: '12 months',
data: {
legend: true,
datasetColors:['blue','red','yellow']
// Definition 'Gas' graph
blocks[p1_grafiek_gas] = {
title: 'Gas',
width: 12,
height: '425px',
custom : {
"dag": {
graph: 'bar',
range: 'day',
filter: '24 hours',
data: {
Gas: 'd.v'
"maand": {
graph: 'bar',
range: 'month',
data: {
Gas: 'd.v'
"jaar": {
graph: 'line',
range: 'year',
data: {
Gas: 'd.v'
legend: false,
datasetColors: ['yellow'],
displayFormats : {
minute: 'h:mm',
hour: 'h:mm',
day: 'DD MMM',
week: 'DD MMM',
month: 'MMM',
title: 'Energie',
custom : {
"vandaag": {
range: 'day',
filter: '12 hours',
data: {
"maand": {
range: 'month',
filter: '1 months',
data: {
"jaar": {
range: 'year',
data: {
legend: true,
title: 'Gas',
width: 12,
height: '425px',
custom : {
"dag": {
graph: 'bar',
range: 'day',
filter: '24 hours',
data: {
Gas: 'd.v'
"maand": {
graph: 'bar',
range: 'month',
data: {
Gas: 'd.v'
"jaar": {
graph: 'line',
range: 'year',
data: {
Gas: 'd.v'
legend: false,
displayFormats : {
minute: 'h:mm',
hour: 'h:mm',
day: 'DD MMM',
week: 'DD MMM',
month: 'MMM',
Remelco
Is this what you meant?
var p1_elektra_nu = '56_1';
var p1_elektra_vandaag = '56_2';
var p1_elektra_totaal = '56_3';
var p1_grafiek_gas = 'graph_57';
var p1_grafiek_elektra = 'graph_56';
Jimster
- Domoticz version: 2020.2
I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
Lokonli
Yes, thanks.Remelco wrote: Tuesday 29 September 2020 21:14 Is this what you meant?
I cannot completely reproduce your issue, but I've fixed some bugs that might have caused this.
Can you test latest beta? (3.6.2)
Lokonli
For the missing icons: which icons do you mean exactly? Can you attach a screenshot?Remelco wrote: Tuesday 29 September 2020 20:19 Yes , I have 2 graphs and both have the same problem.
If you use an icon from fontawesome check whether the icon still exists (fontawesome.com).
Sometimes you have to completely refresh the cache.
Lokonli
Yes, could be.Jimster wrote: Tuesday 29 September 2020 21:19 I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
As a small test, can you try the following:
In the file ./js/weather_owm.js, line 63, remove the first two slashes.
So change:
// _CORS_PATH +
_CORS_PATH +
Jimster
Yes, it works now.Lokonli wrote: Tuesday 29 September 2020 22:48Yes, could be.Jimster wrote: Tuesday 29 September 2020 21:19 I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
So change:intoCode: Select all
// _CORS_PATH +
_CORS_PATH +
Lokonli
hmm, interesting.Jimster wrote: Tuesday 29 September 2020 23:25Yes, it works now.Lokonli wrote: Tuesday 29 September 2020 22:48Yes, could be.Jimster wrote: Tuesday 29 September 2020 21:19 I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
// _CORS_PATH +
_CORS_PATH +
I have to check why it doesn't work on Android 4.4.2 without CORS proxy.
Lokonli
I've slightly changed the request to OpenWeatherMap, which might solve the CORS issue on Android 4.4.2.Jimster wrote: Tuesday 29 September 2020 23:25Yes, it works now.Lokonli wrote: Tuesday 29 September 2020 22:48Yes, could be.Jimster wrote: Tuesday 29 September 2020 21:19 I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
// _CORS_PATH +
_CORS_PATH +
Can you help with testing? I don't have an android 4.4.2 device.
The new new file can be downloaded from:
https://raw.githubusercontent.com/Dasht ... her_owm.js
or:
switch to the git branch 'testowm'
Jimster
I did git checkout testownLokonli wrote: Wednesday 30 September 2020 14:28I've slightly changed the request to OpenWeatherMap, which might solve the CORS issue on Android 4.4.2.Jimster wrote: Tuesday 29 September 2020 23:25Yes, it works now.Lokonli wrote: Tuesday 29 September 2020 22:48
Yes, could be.
// _CORS_PATH +
_CORS_PATH +
or:
Tested it, but unfortunately it doesn't work.
Lokonli
ok, thanks for testing.
I'll add an additional config setting ...
Lokonli
I've created a new beta.Jimster wrote: Wednesday 30 September 2020 16:34I did git checkout testownLokonli wrote: Wednesday 30 September 2020 14:28I've slightly changed the request to OpenWeatherMap, which might solve the CORS issue on Android 4.4.2.
or:
Add the following to CONFIG.js to enable the CORS proxy for OWM:
config['use_cors'] = 1;
Remelco
I have tested the latest beta date 30-9-2020 but stil no graph.Lokonli wrote: Tuesday 29 September 2020 22:31Yes, thanks.Remelco wrote: Tuesday 29 September 2020 21:14 Is this what you meant?
- Icon aanwezig.png (36.62 KiB) Viewed 2717 times
- Icon weg.png (3.89 KiB) Viewed 2717 times
- Grafiek leeg V3.6 (ook bij beta).png (25.96 KiB) Viewed 2717 times
Lokonli
hmm, annoying.Remelco wrote: Wednesday 30 September 2020 21:22I have tested the latest beta date 30-9-2020 but stil no graph.Lokonli wrote: Tuesday 29 September 2020 22:31Yes, thanks.Remelco wrote: Tuesday 29 September 2020 21:14 Is this what you meant?
Can you open DevTools in Chrome by pressing F12. Then refresh Dashticz. Do you see any error in the DevTools console tab?
or failed network requests on the DevTools network tab?
Jimster
Yes with the latest beta and adding this line it works now. Thanks!Lokonli wrote: Wednesday 30 September 2020 20:48
Add the following to CONFIG.js to enable the CORS proxy for OWM:Can you test the latest beta?Code: Select all
Lokonli
Found it. Totally forgot the following:Remelco wrote: Wednesday 30 September 2020 21:22I have tested the latest beta date 30-9-2020 but stil no graph.Lokonli wrote: Tuesday 29 September 2020 22:31Yes, thanks.Remelco wrote: Tuesday 29 September 2020 21:14 Is this what you meant?
The graph now support 'multidevices'
However, that means in the custom graph you have to add the device id to the value, as follows:
title: 'Gas',
width: 12,
height: '425px',
custom : {
"dag": {
graph: 'bar',
range: 'day',
filter: '24 hours',
data: {
Gas: 'd.v_57' //_57 added
"maand": {
graph: 'bar',
range: 'month',
data: {
"jaar": {
graph: 'line',
range: 'year',
data: {
legend: false,
displayFormats : {
minute: 'h:mm',
hour: 'h:mm',
day: 'DD MMM',
week: 'DD MMM',
month: 'MMM',
Remelco
For the gas the graph is is working.Lokonli wrote: Wednesday 30 September 2020 22:41Found it. Totally forgot the following:Remelco wrote: Wednesday 30 September 2020 21:22I have tested the latest beta date 30-9-2020 but stil no graph.Lokonli wrote: Tuesday 29 September 2020 22:31
Yes, thanks.
However, that means in the custom graph you have to add the device id to the value, as follows:That should do it ...Code: Select all
blocks[p1_grafiek_gas] = { title: 'Gas', width: 12, height: '425px', custom : { "dag": { graph: 'bar', range: 'day', filter: '24 hours', data: { Gas: 'd.v_57' //_57 added } }, "maand": { graph: 'bar', range: 'month', data: { Gas: 'd.v_57' //_57 added }, }, "jaar": { graph: 'line', range: 'year', data: { Gas: 'd.v_57' //_57 added } }, }, legend: false, datasetColors: ['yellow'], displayFormats : { minute: 'h:mm', hour: 'h:mm', day: 'DD MMM', week: 'DD MMM', month: 'MMM', } }
I am only struggling with the elecric graph. Where can I add the d.v. to d.v._56.
This is not working:
data: {
netto: 'd.v_56+d.v2-d.r1-d.r2',
gebruikt: 'd.v_56+d.v2',
Lokonli
try:
data: {
netto: 'd.v_56+d.v2_56-d.r1_56-d.r2_56',
gebruikt: 'd.v_56+d.v2_56',
geleverd: '-d.r1_56-d.r2_56'
