Re: Switch off, then hold up for 2 hours
Posted: Wednesday 26 August 2020 13:53
Larsoss wrote: Tuesday 25 August 2020 9:56 haha. indeed I was that far already. I only tried to darken the lux sensor to test, but the dummy switch (evening) did not turn on.
Can i send you a DM?
local LUX_SENSOR_NAME = 'Lux Hue Woonkamer' --Lux IDX / Sensor naam.
local SWITCH_NAME = 'Is het donker?' -- Dummy switch maken.
local OFF_LEVEL = 18 -- Boven de waarde gaat de Switch_Name uit.
local ON_LEVEL = 45 -- Onder deze waarde gaat de Switch_name aan.
devices = {
LUX_SENSOR_NAME
if device.isDevice and device.name == LUX_SENSOR_NAME then
local switch = domoticz.devices(SWITCH_NAME)
if switch == nil then
domoticz.log( "Missing device " .. SWITCH_NAME .. ".", domoticz.LOG_ERROR)
elseif switch.bState == true and device.lux >= OFF_LEVEL then
switch.switchOff()
elseif switch.bState ~= true and device.lux < ON_LEVEL then
switch.switchOff()
}Code: Select all
-- Specify the name of the 1st dummy switch here.
local DARK_TIMER_NAME = 'Is het donker?'
-- Specify the name of the 2nd dummy switch here.
local SLEEP_TIMER_NAME = 'Slaap Dummy'
-- Specify the names of the switches for your garden or porch lights
-- here. If you want to switch multiple lights specify them like
-- { 'light1', 'light2', 'light3' }
local BUITENLAMPEN = { 'Tasmota-Vitrine', 'Tasmota-Lamp_naast_kast', 'Woonkamerlamp' }
devices = {
DARK_TIMER_NAME,
SLEEP_TIMER_NAME
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
if device.isDevice and (DARK_TIMER_NAME == device.name or SLEEP_TIMER_NAME == device.name) then
local dark = domoticz.devices(DARK_TIMER_NAME)
local sleep = domoticz.devices(SLEEP_TIMER_NAME)
if nil == dark then
domoticz.log( "Missing device " .. DARK_TIMER_NAME .. ".", domoticz.LOG_ERROR)
elseif nil == sleep then
domoticz.log( "Missing device " .. SLEEP_TIMER_NAME .. ".", domoticz.LOG_ERROR)
domoticz.devices().filter(BUITENLAMPEN).forEach(
function(lamp)
if dark.bState and not sleep.bState then
if not lamp.bState then
lamp.switchOn()
if lamp.bState then
lamp.switchOff()
endThe last one is switch by the timers. Thats right. The ''Is het donker?'' not switch by the first script.
