Failing eth0 at Raspberry
Toulon7559
Domoticz version: <2025
Re: Failing eth0 at Raspberry
Post by Toulon7559 »
At the end of an earlier message I already indicated that probably the more pragmatic solution would be to redistribute the functions of this 'problematic' Raspberry-setup over other Raspberries, combined with a serious clean-up.
;-) Shifting the SD-card to a Raspberry3A+ is a pragmatically simple, functional way out.
Has wlan0 only, no eth0, and is fast. Adressing-structure remains same, both for IP and for devices.
Eth0-function lost, but further looks like really minimal effort, without loss of data.
Just checking that applications refer to correct accessible, active IP-adresses and URLs.
After that redistribution then this 'problematic' Raspberry3B+ is 'clean & empty' for new applications, incl. use of eth0.
Conclusion:
a pity that no simple solution could be found to activate eth0, but enough time has been spent to search.
;-) Better now start that redistribution & clean-up .......
Thanks for the support during the search for a solution!
Last edited by Toulon7559 on Wednesday 23 September 2020 19:29, edited 1 time in total.
Toulon7559
Side-effect (rather obvious) from 'Lessons-Learned' as indicated in the previous messages.
If you have an RPI-B or later with both LAN /eth0 and Wifi/wlan0 (= dual-channel communication), then
you are able to communicate with both LAN and Wifi.
If you have a processor with either LAN, or Wifi, you have no path to make direct connection between LAN and Wifi, but
you can 'misuse' the processors with dual-channel communication to assist you:
such processor can read a device in 1 processor LAN and copy/upload to another processor at WiFi, or reverse.
Toulon7559
Sometimes have to admit that ;) an idea is not working .....
Had a setup in mind with cabled LAN in IP-range 192.168.1.x and WLAN in IP-range 192.168.0.y, aiming a a 'simple & good' separation of groups of clients.
As described in previous messages, initially it worked, but after some time ran into problems with the RPI-3Bs loosing the connection to cabled eth0;
in past year not once but with several RPI-3Bs.
Considering the found practical solution, not a hardware problem, but perhaps some aspect in the software coming up during use of such setup?
Have 'surrendered' to a configuration in which cabled LAN-clents and WLAN-clients are in the same IP-range:
then both eth0 and wlan0 come into action and crosscommunication is very easy!
Except shifting of the LAN-cabling to another router as part of clean-up, most effort to tune all (W)LAN-related software to suite the common IP-range.
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Is sshd configured on port 22? And is sshd listening on all interfaces/listenaddress?
Check: /etc/ssh/sshd_config
Toulon7559
@AllesVanZelf
According to experiences, the 'eth0-problem' as described in the thread has no relation to ssh.
;) But eager to learn:
what line to check in the indicated config-file /etc/ssh/sshd_config?
AllesVanZelf
In /etc/ssh.sshd_config
set
ListenAddress 192.168.1.6
ListenAddress 192.168.0.185
Do you get a ping result if you ping 192.168.1.6 from another computer?
Could you make this rpi get an address via dhcp for testing? Or could you change the ipaddress?
Users browsing this forum: Amazon [Bot] and 1 guest
