Page 2 of 2
Re: CATT show Domoticz on Google Hub
Posted: Wednesday 17 June 2020 17:37
by Andyyyy
i am to using catt to stream domoticz to my Lenovo Smart Display. It works but i cannot use the pulldowns to switch between floorplans.
Did anyone solve this problem ?
Andyyyy
Posted: Wednesday 17 June 2020 22:02
by FireWizard
@Andyyyy
Do you use the standard interface, as I do not recognize, what you mean.
I my case, I have 5 floor-plan drawings, which I can call-up by touching the small "circle" under the drawing.
So I do not have "pulldowns". I stream to the Google Nest Hub.
See:
https://www.domoticz.com/forum/viewtopi ... hilit=CATT
Posted: Friday 19 June 2020 9:05
by Andyyyy
Hi FireWizard,
sorry i mean the room selector pulldown.
I use the ThinkTheme.
- Rooms.png (26.42 KiB) Viewed 1021 times
Andyyyy
Posted: Friday 19 June 2020 10:49
by Droid
Here an update.
I gave up on the dummy switch solution.
Instead I've installed Node-RED with NORA plugin. I've created a switch which then executes a shell script.
- node-red.JPG (25.07 KiB) Viewed 1015 times
Works like a charm
Posted: Friday 19 June 2020 21:32
by FireWizard
@Droid.
In principle, I do exactly the same.
However, because CATT and Node Red run on different hardware, I push the command with MQTT to the machine with CATT installed.
Indeed, that works like a charm.
Posted: Monday 12 October 2020 22:21
by gropi
I placed my script under the scripts folder in domoticz and I can activate it from Domoticz.
catt -d 192.1.1.1 cast_site http://192.2.2.2:8082/ &
sleep 60
catt stop
exit 0
