Page 2 of 3
Re: Dashticz - v3.4.9 beta
Posted: Thursday 28 May 2020 23:26
by Lokonli
Vomera wrote: Thursday 28 May 2020 10:47
Okay i can see everything is working fine now , so in the next days i can check if every button responds now.
I was wondering if longfonds can also change by color if it get a certain value. Because many things changed in the last versions
https://www.domoticz.com/forum/viewtopi ... ds#p236662
First add a CSS class to the block when a certain value is reached, via custom.js. For inspiration see:
https://dashticz.readthedocs.io/en/beta ... -idx-block
Something like:
function getStatus_145(block){
var idx = block.idx;
var device = block.device;
if(parseFloat(device['Data'])>23){
block.addClass='warning';
else {
block.addClass='';
Maybe instead of device["Data"] you have to use another field. You can also change the icon if you want to.
After you've attached a specific CSS class depending on the value, you can define the CSS styling in custom.css.
Longfonds is a special block. See:
https://dashticz.readthedocs.io/en/beta ... ial-blocks
To set the color in the icon part:
.warning .col-icon {
color: red !important
Posted: Friday 29 May 2020 8:19
by Vomera
Lokonli wrote: Thursday 28 May 2020 23:26
Something like:
else {
block.addClass='';
Hi Lokonli, tnx for you answer, but i know how it works with the status blocks. I have almost 1000 lines coded for certain blocks, even the temperature changes with every color with every celius. But the "longfonds" is a plugin thats made. So i cant attach it to an IDX and there is no Data value. I provided the link
Because you responded to this earlier. Maybe you remember. Or is the code changed that it can work now ?
Posted: Friday 29 May 2020 14:08
by Lokonli
o yes, you're right. Good point.
I can add a getStatus_<key> callback for special blocks as well.
Some redesign is needed to prevent unnecessary rerendering and/or requesting data from the server.
I'll add it to the request list for the next version, after I've released a new master.
Posted: Friday 29 May 2020 14:26
by Vomera
Lokonli wrote: Friday 29 May 2020 14:08
Would be nice if you can do that too
so if you can write it on your todo list
haha
Posted: Saturday 30 May 2020 9:50
by madradrakie
i updated from 3.4.6 and experience some strange behaviour. After about an hour the bars and lines of my energy and water graphs are not displayed anymore. I did not experience this behaviour in the previous beta. Any idea?
Posted: Sunday 31 May 2020 12:06
by jaaap
Anyone else have the Open Weather Forecast not showing anymore? It has been working on 3.4.9 but since yesterday is doesn't anymore.
Posted: Sunday 31 May 2020 12:35
by Vomera
jaaap wrote: Sunday 31 May 2020 12:06
Did you change anything ? did you update tot 3.4.9.1 ?
Can you post some code ?
Posted: Sunday 31 May 2020 15:54
by toro
Yes, the same here. I'm still on 3.4.5 and didn't change a thing. Since yesterday, it's not showing anymore.
Tried to find out why, but couldn't find it.
OWM is still showing in the Master version, so the API itself it functioning.
Console isn't showing anny errors
Posted: Sunday 31 May 2020 16:00
by Jimster
My OWF works in 3.4.9.1. I use currentweather_big_owm and weather_owm.
Posted: Tuesday 02 June 2020 12:52
by fvdp80
After updating to v3.4.9.1 beta i can't get my dashboard to show in Chrome (windows 10).
If i use an incognito tab or Chrome on Android, it does work.
Already cleared the cache, but no luck.
Posted: Tuesday 02 June 2020 13:00
by Vomera
Jimster wrote: Sunday 31 May 2020 16:00
And in 3.4.9.0 ?
Posted: Tuesday 02 June 2020 13:01
by Vomera
fvdp80 wrote: Tuesday 02 June 2020 12:52
It stays black ? Or you get an error ?
And with CTRL + F5 ?
Posted: Tuesday 02 June 2020 14:08
by Jimster
Vomera wrote: Tuesday 02 June 2020 13:00
And in 3.4.9.0 ?
As far as I can remember it worked fine.
Don't know how to downgrade to retest.
Posted: Tuesday 02 June 2020 15:06
by HansieNL
Can you disable your Chrome extensions (if installed) and disable them and enable them one by one?
Posted: Tuesday 02 June 2020 16:38
by jaaap
And without any chance...it started working again this morning! Must be some temporary error at the Open Weather side I guess...
Thanks for the quick response everyone!
Posted: Tuesday 02 June 2020 17:31
by toro
jaaap wrote: Tuesday 02 June 2020 16:38
Just to confirm, here also OWM is back without any change. No clue why it didn't work, as is was still fuctioning in master version.
Well, maybe one of those things..
Posted: Wednesday 03 June 2020 12:00
by fvdp80
HansieNL wrote: Tuesday 02 June 2020 15:06
AdBlocker extension was causing the problem. Strange because it always did work.
Thnx HansieNL!
Posted: Thursday 04 June 2020 20:00
by madradrakie
madradrakie wrote: Saturday 30 May 2020 9:50
does anybody have an idea what the issue may be? After about two hours my graphs are not displayed anymore. I use an ipad with the latest IOS. Thanks in advance.
Posted: Sunday 23 August 2020 21:22
by Backlash
I'm working with the latest Dashticz V3.5-master. I cannot get open weather map working.
It is working in domoticz but just won't show in Dashticz. I used the fairly simple instructions from the manual
//Configuring the OWM parameters
config['owm_api'] = '7c4bd2526cc4b8ed811ddfead1a557c9';
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = '';
config['owm_country'] = 'de';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '3';
config['owm_min'] = true;
config['owm_days'] = true;
//Adding OWM to a column
columns[3] = {}
columns[3]['blocks'] = ['currentweather_big_owm','weather_owm']
columns[3]['width'] = 3;
I removed all extentions in Chome.
Any ideas?
Posted: Monday 21 September 2020 16:26
by Backlash
found the problem
changed from V3.5 master to V3.5.2 beta and problem solved
git fetch origin
git checkout beta
git pull
